Question about Lanier Office Equipment & Supplies
When i print pdf documents on my lanier ld016 the don't print correctly.
Posted by Ghaheed on
  • Marvin
    Marvin Nov 11, 2016
    Hi
    Please explain in detail what you mean by "they don't print correctly"?
  • Ghaheed
    Ghaheed Nov 12, 2016
    Hi Yadayada: I figured out what the issue was. Live areas were printing will lines because it was using Microsoft Edge and not the Adobe Acrobat. Once I installed Adobe Acrobat... All documents are printing fine now.
    Thanks for all of your help.
5 Related Answers
Anonymous
  • 19 Answers
SOURCE: Printer cuts off top 1 inch of PDF document
Go to the printer properties and try setting it up with border less printing.
Cheers
Posted on Aug 30, 2008
Anonymous
SOURCE: Poor print quality of pdf documents on Epson LX-300
PDFs are designed to print using Postscript language.
The problem will occur with any non-Postscript printer. You can get better results on Windows printers by clicking on the "Advanced' button in the Print dialogue window. Then check 'Print as Image'.
This has worked well for me.
Posted on Feb 20, 2009
Anonymous
  • 39 Answers
SOURCE: can't print entire pdf documents only first page.
Try this
For Adobe Acrobat Professional 9:
  1. Choose File > Print.
  2. Click on Advanced.
  3. Choose Postcript Options.
  4. Under Font and Resource Policy, select "Send for Each Page".
  5. If "Print as Graphic" is checked, it must be unchecked, as well as "Send As Group" if it does not uncheck itself when you select "Send for Each Page"
  6. Save it as a custom configuration.
Posted on Oct 06, 2009
Anonymous
  • 311 Answers
SOURCE: my hp f 380 printer wont print pdf documents
in this case
open pdf
the click on print
now you need to look for the option that says print as image and this option has to be checked
you can get the option by clickon on advanced or prefrences
Thanks
Posted on Mar 05, 2010
Anonymous
SOURCE: HP C6180 will not print a PDF document, causes paper jam.
The problem is an incompatibility between Adobe Acrobat and HP Photosoft software... the solution is to stop using Adobe Acrobat software as your primary PDF reader... to see why and what is the alternative continue reading...
I had several Windows XP laptop/netbook/desktops running on my home wireless network perfectly. Then I had to replace the desktop with Windows Vista, and that's where the problems started. Despite updating the HP driver software, the Photosmart printer would not work with the Vista machine unless it was physically connected through the USB port. But this solution created a new problem with the wireless XP machines, they would now cause a print jam every time I printed a PDF. I had Acrobat Reader on one machine and Acrobat Pro on the other. Any other file format would print fine... I could print a PDF from within Adobe Photoshop... and re-installing the old HP driver software eliminated the problem (but then the Vista machine wouldn't print anything)... thus the problem had to be Acrobat.
With the newest updated HP software in place I uninstalled Acrobat Reader and installed a freeware readers. THE PROBLEM WAS SOLVED. I tested three and all printed PDFs to the HP Photosmart printer with no problem. I tried Adobe Acrobat again, and it jammed. These freeware PDF readers are all small and fast compared to Acrobat which is big, bloated, and slow.
My suggestion is to use Foxit, which is the easiest and fastest, and seemes to work as a plugin with all the browsers (IE, Firefox, Chrome). You can get it from trusted sites like CNET ( http://download.cnet.com/Foxit-Reader/3000-10743_4-10313206.html ) or from the company ( http://www.foxitsoftware.com/pdf/reader/ ).
BTW, I do maintain Acrobat Pro on one machine because of the advanced features I use, but I configured it to not be the default PDF reader and print through Foxit on my home network.
By the way, ANYONE WHO SUGGESTS CONTACTING HP SUPPORT ABOUT PRINTERS THIS OLD IS BEING LAZY OR NOT PAYING ATTENTION... HP WON'T HELP UNLESS YOU PAY FOR THE INCIDENT, AND THEN THEY TELL YOU TO DO THE OBVIOUS (i.e., install new drivers) WHICH DOESN'T WORK, WHEREUPON THEY WILL SAY IT'S NOT AN HP PROBLEM BUT THE "OTHER GUYS" PROBLEM. Many people have played this game with HP before so don't waste your time and money expecting a different result.
Posted on Jun 10, 2010
Can the SP 204 SF scan to pdf?
Here's a workaround while you're searching.
Download CutePDF or PDF redirect and install.
Now after you scan to picture, copy and paste to a document and print or just print the image and send to the new 'printer' to PDF thingee and voila ...
PDF reDirect The free PDF Creator alternative to pdf995 cutepdf and freepdf
Feb 10, 2015 | Lanier Office Equipment & Supplies
Grinding noise LD016
Lubricated the bushings on the black foam roller on the inside of the right hand door. Toner leakage is unrelated unless the drum unit gears are causing the noise, in which case, it must be replaced.
Apr 16, 2014 | Lanier Office Equipment & Supplies
Page isnt prining out Have new ink in printer
Before you can troubleshoot the problem, determine its cause. Do the following steps in order:
1. Print another PDF, such as the first page of Acrobat Help.
  • If a separate PDF file prints correctly, the PDF that doesn't print correctly could be damaged. See "Can't print a specific PDF file" later in this document.
  • If the separate file doesn't print correctly, go to step 2.
2. Print another type of file (for example, a plain text file) from another application (such as Microsoft Word or WordPad).
  • If that other type of file prints correctly, the problem isn't system-wide--it's specific to the Adobe Reader or Acrobat product. However, the problem could come from Reader or Acrobat interacts with the system. Go to step 3 to eliminate some system-related causes of the problem.
  • If that other type of file doesn't print correctly, the problem is system-wide--it isn't specific to Acrobat or PDFs. The problem could be low system resources, insufficient memory on your printer, or a poor connection between your computer and the printer. Go to step 3 to eliminate some likely causes of the problem.
3. Restart your computer, and then print a PDF.
  • If the file prints correctly, your system may have been out of memory or resources.
  • If the file doesn't print correctly, go to step 4.
4. Turn off your printer for at least 15 seconds to flush its memory. Then turn it back on and print a PDF.
  • If the file prints correctly, the printer's memory was too full or had become corrupt.
  • If the file still doesn't print correctly, go to step 5.
5. Print from another computer.
  • If the file prints correctly from another computer, the computer you first used may be unable to connect to the printer or the network correctly. Consult your network documentation or contact your network administrator.
  • If the file still doesn't print correctly, go to step 6.
6. Print a PDF to another printer.
  • If the file prints correctly to a different printer, the computer you first used may be unable to connect to the original printer. Communication, hardware, or memory problems can cause this kind of connection problem. Make sure that the printer is turned on and connected properly. Then run a self-test on the printer to make sure that it's working correctly. Consult your printer documentation for self-test instructions or contact your network administrator.
  • If the file doesn't print correctly, see "Can't print any file from any application" later in this document.
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Sep 01, 2010 | Lexmark Z611 InkJet Photo Printer
Maint. reset for lanier ap-2610 printer
Please go through the link mentioned below, it has all the details............
http://www.lanier.com/downloads/manuals/Printers/ap2610_printer_ref.pdf
Aug 11, 2010 | Office Equipment & Supplies
Lanier LD016 can't scan to server using server name but can scan to server using IP address on server 2003.
Your DNS information may be incorrect use a ipconfig /All to check your DNS setting from any workstation on your current network. If you ping the name of the server it should reply with the IP address
Feb 13, 2010 | Office Equipment & Supplies
Tray 1 is not set correctly, yet everything is set right. Help
81/2 x 11 is not a custom paper size. Set tray 1 to 81/2 x11 plain paper and set your print driver the same way. the descriptions have to match or it will not print.
Jan 05, 2010 | Lanier UNKNOWN
Lanier MPC 3000 copier won't print faxes
Try opening up your web browser and type in the ip address of your lanier.
You should to access the facsimile function located on the left side. Once youre in the facsimile function, you should see a thumbnail view of the faxes stored in your lanier. Simply click on the faxes and delete them.
Sep 22, 2009 | Lanier Office Equipment & Supplies
I have a Lanier LD 232c. Every print job we try to send through is resulting in a paper jam. What should I look at?
Make sure that all the paper trays have the correct size and direction (portrait or landscape) in both the copier and print driver.
Jul 06, 2009 | Lanier Office Equipment & Supplies
Printer LCD says Cartridge Problem - Tri-Color. Refer to device documentation to troubleshoot.
Before you can troubleshoot the problem, you need to determine its cause.
To determine the cause of the printing problem:
1. Print another PDF file, such as the first page of Acrobat Help:
-- If that file prints correctly, the PDF file that doesn't print correctly may be damaged. See "Resolve problems printing a specific PDF file from an Acrobat product" in this document.
-- If the file doesn't print correctly, go to step 2.
2. Print another type of file (for example, a .txt file) from another application (such as Microsoft Word or WordPad):
-- If that file prints correctly, the problem isn't system-wide--it's specific to the Acrobat product. However, the way Acrobat interacts with the system may affect printing performance. Go to step 3 to eliminate some system-related causes of the problem.
-- If the file doesn't print correctly, the problem is system-wide--it isn't specific to Acrobat or PDF files. The problem could be low system resources, insufficient memory on your printer, or a poor connection between your computer and the printer. Go to step 3 to eliminate some likely causes of the problem.
3. Restart your computer, and then print a PDF file:
-- If the file prints correctly, your system may have been out of memory or resources.
-- If the file doesn't print correctly, go to step 4.
4. Turn off your printer for at least 15 seconds to flush its memory, and then turn it back on and print a PDF file:
-- If the file prints correctly, the printer's memory was too full.
-- If the file doesn't print correctly, go to step 5.
5. Print from another computer:
-- If the file prints correctly, the computer you first tried to print from may be unable to connect to the printer or the network correctly. Contact your network administrator or consult your network documentation.
-- If the file doesn't print correctly, go to step 6.
6. Print a PDF file to another printer:
-- If the file prints correctly, the computer you first tried to print from may be unable to connect to the original printer because of a communication, hardware, or memory problem. Make sure that the printer is turned on and connected properly, and then run a self-test on it to make sure that it's working correctly. For instructions, see the documentation that came with the printer. You may want to contact your network administrator for assistance.
-- If the file doesn't print correctly, see "Resolve problems printing any file from any application" in this document.
you can try these option and then try to resolve them and you can find the solution on follwing link==http://kb2.adobe.com/cps/316/316508.html
For more free tehnjical support you can visit-----http://tinyurl.com/lkrpwy
Jul 06, 2009 | HP Officejet J4680 InkJet Printer
Lanier 5235 Stapler Problem
Try a new staple cart. as the staples are not advancing. -Carl
Feb 09, 2009 | Lanier 5235 Printer
Top Lanier Office Equipment & Supplies Experts
Ekse
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Lanier Office Equipment and Supply Expert? Answer questions, earn points and help others
