Kitchen Appliances - Others Logo
Question about Gold Medal Kitchen Appliances - Others
Gold medal popcorn maker Model#2388,the plug on the kettle lead assembly has broke ca it be replace with a non ome plug or should i replace the whole assembly
Posted by Randy Hedrick on
Preston Blair
    Habit-Forming:
    New Friend:
  • 39 Answers
Replace the whole assembly
Posted on Nov 10, 2016
Testimonial: "Thank you Preston"
Adjusting the thermostat for best temperature
There is a adjusting screw on the thermostat. So your not guessing you should heat it on a. Bench with a amp meter on the line . Then check temp and adjust from there. The factory thermostats are. Preset . If you installed the correct one adjustment should not be necessary? Is the element tight on the bottom?
Why is my gold medal popcorn model # 2552 machine not heating to pop popcorn anymore?
A kettle not heating is either a switch, kettle wires, thermostat, or kettle heater.
Check that the kettle is plugged in tight, notice if the switch lights up when switched, then contact your local gold medal dealer for repairs. It is always cheaper to repair a gold medal kettle than replace.
http://www.gmpopcorn.com/domestic-dealers.cfm
Popcorn maker worked great for a matinee then for the evening show the kettle no longer heated up
Your kettle has had a ground fault, and damaged the switch in the process. Do not Continue to Try and use.
Take the kettle to a gold medal dealer, and replace the switch in the cabinet.
Gold Medal Deluxe Pinto Pop Popcorn Machine Model 2147 will not heat up
If the switch is OK and you have. Power at the kettle plug and you are not getting any heat it's one of 3 things. Burned wire inside the kettle. this is common. Or it could be the thermostat is bad or the element itself is out?
1helpful
Kettle not heating up
First check that the kettle is plugged into the cabinet. Then check if switch, (or red power light) lights up when you flipped the switch back and forth. If it does the problem is inside the kettle.
Contact a Gold Medal dealer for service options, repairing it is the best options as a replacement kettle for that model is very expensive.
Gold medal 2404 won't heat
Double check that the kettle is plugged into cabinet.
Does the Switch light up? if not it is the switch is bad.
If it does, than either it is the kettle lead wires, or themostat, or the heat element that is bad. In that order.
2helpful
3answers
Need model number for Gold Medal popper
http://www.concessionpalace.com/concession-tutorials/P-60_60_Special_Uncle_Walts-1866_2085_2086_2656-popcorn-machines.pdf
2answers
I have a Gold Medal Popcorn Machine 2086. The kettle is uncleanable. Where can I purchase a new Kettle?
I hate to put this as a solution because it really isn't. I have an old popper needing a new kettle and was told it was almost as much to purchase a new kettle than the whole machine. The kettle is almost the entire cost of the unit. I will be purchasing a new unit.
Trips circuit when you turn on the Kettle heat
When the fuse blows see what else in the house is out, maybe you have the circuit overloaded. Try putting the popcorn maker on a different unused curcuit to see if it still blows. Then you will know if it is the popcorn maker.
2answers
Replacement Kettle assembly for Gold Medal 2121 Econo-pop 14
gold medal products co.
800-543-0862
10700 medallion dr
cincinnati,oh 45214
www.gmpopcorn.com
Top Gold Medal Kitchen Appliances - Others Experts
john h
ADMIN Andrew
ADMIN Andrew
Tom Chichester
Are you a Gold Medal Kitchen Appliances - Other Expert? Answer questions, earn points and help others
