After switching on the Induction stove on the display it shows E9 error and its switching off automatically
Tthis is a generic fault code for induction cook tops, I am assuming this is the same for your Prestige unit.
If these steps do not resolve the issue, you will need to contact an authorized service shop.
SOURCE: whirlpool induction ceramic cooktop error E6
my induction ceramic cooktop is showing an error code E6 on two of the elements...what is the problem and how do I get it fixed
SOURCE: My Zanussi Induction cooker model ZKT 621LX is not
Hello Horus,
The child-lock has been activated - probably accidentally, but someone may think you're not safe to use it. The de-activate the child lock . . .
1. Switch the cooktop on so all zone show "L"
2. Press both the + sign for the right-front zone and the - sign simultaneously. All four zones will show "0" with flashing decimal points.
3. Press the - sign again. The cooktop will switch off.
You can now switch the cooktop on and use it normally again.
Hope this helps. If you have any difficulty de-activating the child-lock or need further assistance, please let me know.
Regards,
BElectric.
SOURCE: Recently i have purchased Prestige induction
e 3 is error because of high voltage may be more than 30 kW at your house......it will not work with it u have to buy a voltage regulator for it........
SOURCE: I Bought Prestige induction stove
E5 or E0 means that the stove is getting overheated. You have to reduce the temperature for it to stop. It goes on with few beeps and then stops.
