Televison & Video Logo
Iqbal kabir Posted on Nov 10, 2016
My tv samsung plasma ps50c430a1mxxs made bu samsung. Display screen boroken cracked, my freand have samsung plasma ps50b430b2.nade china. This tv display screen what a suport Ps50c430a1 ..pls. sug:me
5 Related Answers
Anonymous
  • 440 Answers
  • Posted on Feb 06, 2008
SOURCE: samsung ps42c91h plasma screen pc connection
u must use 60 herts 1024x768 on screen out ok try this
Anonymous
  • 5 Answers
  • Posted on Feb 20, 2008
SOURCE: PLASMA DISPLAY STARTING UP. PLEASE WAIT
Un plug the power to the Plasma Screen and also to the Media Receiver for ten minutes. Disconnect the off the air antennas both A and B. After ten minutes plug in the plasma screen then the media receiver and turn on wi the remote control. You should now be back in operation. I was.
Also It may not be a bad digital tuner. The TV Guide feature is active even when the zip code is set to all 0s so if you have an over the air antenna attached the TV will look for the TV Guide info and if it can not find it because of a weak signal or the chanel it is tuned to does not carry that information the TV thinks that tuner does not work which triggers the 12 flashes. Also on power up the gray box with the waring message "Plasma Display Starting Up, Please Wait" appears and the screen is blank.
jerryg50
Jerry Greenberg
  • 1691 Answers
  • Posted on Jun 03, 2008
SOURCE: Cracked plasma
The screen unit is not repairable. You would need a new replacement screen unit. The cost would be greater than buying a new TV set!
Jerry G.
jerryg50
Jerry Greenberg
  • 1691 Answers
  • Posted on Sep 26, 2008
SOURCE: 50 " Samsung Plasma TV
Get the tech supplier to tell to the manufacture and the store what he told you.
Physical damage on any electronic device is very hard to have serviced under warranty. I have never seen a plasma display crack on its own. But, anything can happen.
I once saw a man drop a newly bought plasma TV in a parking lot outside from where he bought it and the screen broke. He never even made it home from the store!
Maybe you should contact a lawyer or someone who can give you legal advice about how to proceed with this. In different countries and different states the consumer protection laws are different.
Jerry G.
Anonymous
  • 5 Answers
  • Posted on Mar 05, 2009
SOURCE: rolling horizontal lines on the display of my plasma tv
if u r connected to an ant. it is due to poor signals from the ant so get a booster or amplifier for the ant.
O just want know samsung plasma ps50c430a1mxxs 50inc tv mde by samsung with samsng plasma ps50b430b2 50inch tv mde china .display panel screen do the fiting/support what posible ,what a i cnt fitng
if b2 hardware would fit a1 one tv ????
Most likely answer is YES .
They are probably made to go together, they cant have the same number or they would be the same product. so I would reason that they are meant to go together .
Please try to be more clear about what your asking
Samsung Plasma Tv PN50B550T2F, cracked glass filter; Is The plasma module any good?
LIKELY NOT, SCREEN IS VERY FRAGILE, if screen or display panel is damaged just retire it and get a new set.
1helpful
Can I get a new screen for my Samsung tv
If you have a cracked or damaged Plasma you are done--called a PDP or Plasma Display Panel (set indicated here is Plasma) the cost of that part always well exceeds the cost of a new set--damage to the panel is fatal.
Problem with the screen is cracked
For a Plasma or a LCD a cracked screen is the end of the set.
In Plasma sets the "panel" or Plasma Display Panel the cost of the part is as much and usually more than the set cost new.
Time for a new set and some major stores at purchase also offer insurance policy for this kind of event.
1helpful
I have a Samsung HP-T4264 plasma tv with a badly cracked screen. Can this screen be replaced with one from a Samsung HP-R4252C plasma TV.
No way, Jose!
Those bastards manufactures are always making sure you won't be able to use parts from one model to the other. Especially-display! LCD panels could be rigged, but no plazma's. Sorry!
Sell it for parts to some repair shop and get yourself LCD or LED panel. Plazma is gone!
Jerry G.
33helpful
8answers
Broken Screen on Plasma TV
samsung 37 inch plasma screen cracked by my grandson. Can it be fixed
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
