Question about Olympus Office Equipment & Supplies
I have problem with instaling my drivers to printer, i'm with windows8 and trying to install olympus s-100 but i cant because i alwaysget sameeror "error 301(1805)" There is no windows 8 compatibility
I have the CD drivers, they give me same error, tryed to download new one from olympus website, and i get the same errors, please help.
Posted by Aleksandar... on
5 Related Answers
Anonymous
  • 151 Answers
SOURCE: Cant install drivers on Vista
Try installing the drivers in compatibility mode, check the vista help by pressing f1 and look for compatibility wizard then try installing it at this mode, if it still wouldn't install, you need to to the manufacturers website and get a new driver specifically for vista...
Posted on Dec 10, 2007
Anonymous
SOURCE: Installation of a downloaded driver for Lexmark X1290 All-In_One
I bought a Lexmark X1290 printer and installed a wrong driver (for WinXP) from the enclosed CD. Then I could not run the All in One program. After many reinstallation attemps, I finally found a solution (which is unfortunately quite hidden at the Lexmark website):
1) Unplug the printer's USB cable from the computer.
2) Download the cleaning utility from ftp://ftp.lexmark.com/driver/inkjet_drivers/Cleanup/.
3) Double-click on the cleanup utility and follow the on-screen instructions to run it.
4) Restart the computer.
5) Download all files from ftp://ftp.lexmark.com/driver/inkjet_drivers/Cleanup/reg/
6) Follow the instructions in the "Vista BackDoor Instructions.txt" and delete all remaining Lexmark
keys in the registry.
7) Restart the computer
8) Download a proper driver for Windows Vista from the Lexmark website.
9) Install the driver accordingly to the instructions (it's important to plug the printer's USB cable when you are ask to, not before)
The problem with Lexmark Unistall and CleanUp Utility is that you cannot delete all Lexmark registry keys while you arelogged in the system. This is anellegant way how to circumvent the problem.
Posted on Sep 14, 2008
Geoff
  • 562 Answers
SOURCE: driver on original CD is 32-bit Intel compatible platforms only, and I use Windows XP 64-bit
goto > http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=357&modelid=17105
Enter the Operating system.
Download the new driver
Posted on Apr 25, 2009
Anonymous
  • 6 Answers
SOURCE: webcam driver
You can download drivers directly from their website. Follow this link http://www.zebronics.net/driverdownloads.asp and just put in the details product, model and operating system and then click on the download. This definitly works on mine.
Posted on Jun 01, 2009
Anonymous
SOURCE: UB Funkey installation errors - Windows 7 64 bit.
I have called mattel on this matter.
They said that Win7 64bit is currently not supported by ub funkeys software. sorry
Posted on Apr 05, 2010
Testimonial: "Thanks for investigating this!"
I bought new laptop Compaq CQ62 103TU. When I started the laptop it is giving the error " error can't open CD driver FDCD0001" and "SHSUCDX Can't Install". How can I fix this prblem
Is it Booted perfectly and giving the error after login? Please try to update the CD/DVD Driver. You can use chipset CD which comes with your laptop.
Sep 23, 2010 | Computers & Internet
Can't download CD to computer for new Olympus x-42
Go to the website LINK. Find your product and download the correct drivers.
Hope this helps, give me thumbs please!
Aug 23, 2010 | Olympus Computers & Internet
Olympus DSS Player ver 7 installation, use and file backup proble
simple convert them all to .wav or mp3 then can play anywhere.. thats what i do... now can some one help me.. my dss 2 doesn't work right in the very nnoying new win 7 computer.. keep getting a dll error and olympus has the drivers all archived and not updated for win 7
hope this helped you
Feb 22, 2010 | Olympus Audio Players & Recorders
Modem driver probleb
There seems to be conflict with IE8 - try unistalling IE8 and try again.
Apr 19, 2009 | Computers & Internet
The priter shows error & donot print any thing.(x4270)
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
Hope this help. Please Rate My Response! Thanks!
PREM
Mar 13, 2009 | Lexmark X4270 All-In-One Printer
Hp photo smart c5180 printer error Oxc18a0006
Try updating your print drivers:
Create a new folder on your desktop and name it newhpdrivers. Un-intall printer and printer software completely. Go to manufacturers website and navigate to their drivers/downloads or support menu. Select your model, choose the relevant software and download to the new folder you created on your desktop. Power down your computer. Reconnect the printer to the computer and turn printer on. Windows will detect new hardware and ask if you have the manufacturers install cd or a location to check for install files. Direct the wizard to your new software, follow the rest of the setup instructions and your done
anaanymous
Oct 12, 2008 | HP Photosmart C5180 All-In-One InkJet...
Master Software 2 help!
Ditto. Installing on XP w/SP1. Plenty of hard drive space. Pentium 4 w/2GB RAM. Tried different drives. Tried copying CD-ROM to hard drive to verify it was reading of the CD ok. No problem copying but still failing on installation. I also tried by-passing the initial Olympus menu and launching the .msi directly, but that fails in the same way. I haven't found anything on the Olympus website about this, but note their website generates tons of Javascript errors which is not encouraging with respect to Olympus's attention to quality. (This is my first and probably last Olympus.)
Tried pulling the XD media and reading it on the computer but my computer wanted to format the thing (never seen that with SD or Compact Flash, what gives?) so that was a no for the moment.
Finally, I went to the files that I had copied from the CD to my hard drive and double-clicked the OM2_Pack_Framework_2_0_4.cab file found in the OLYMPUS\OLYMPUS Master 2 directory. That contains a bunch of .cab files, that I extracted to another directory. In there, I found a application.cab, which I then extracted to yet another directory. In there, I found OLYMPUS Master.exe. That ran fine when I double clicked on it, but I still had the problem of not being able to read the XD directly, so I hooked the USB up to the camera with the XD back in the camera and was able to transfer the images in that manner.
Apr 25, 2008 | Cameras
Need to download driver
To learn about the new and free version of Olympus Master 2 software go to:
For Windows:
http://downloads.olympus-europa.com/OM2/win/OM211Setup.exe
For MAC:
Olympus Master 2.11: http://downloads.olympus-europa.com/OM2/Mac/OM211EN.dmg
This software replaces all previous versions of Camedia Master 4.x and Olympus Master 1.x.
Feb 21, 2008 | Olympus D-535 Zoom / C370 Zoom Digital...
Driver for windows vista home premium
I have Windows Vista Home Premium. I do not have my original Olympus disc. I downloaded the driver from driver guide (http://members.driverguide.com/driver/detail.php?driverid=583812) > installed driver (in this case pencam.exe. After installing the Olympus software I hooked the USB cable up, turned on my w-10 recorder and let Windows begin it's search.
I manually pointed it to the pencam folder where it proceeded to load the drivers successfully. I am now able to transfer my files successfully. Hope this helps in some way.
Oct 17, 2007 | Olympus W-10 Digital Voice Recorder
37 people viewed this question
Top Olympus Office Equipment & Supplies Experts
James Cagle
James Cagle
John Tripp
John Tripp
Are you an Olympus Office Equipment and Supply Expert? Answer questions, earn points and help others
