Question about Samsung Washing Machines
Samsung front loader washer will not run but has power
Posted by Samuel Muniz on
Payam Yazdani
Check the motor carbon Brushes
Posted on Sep 12, 2021
Marvin
    Top Expert:
  • Samsung Master
  • 85,239 Answers
Please read the repair guide at link.. Washing Machine Will Not Start What To Check How To Fix
Posted on Nov 09, 2016
3 Related Answers
Anonymous
  • 635 Answers
SOURCE: my front loader door wont lock
Believe it or not, you may be able to fix that yourself with some spray lubricant applied to the shaft of the electric lock mechanism, but you will have to remove the lock to lube where it's stuck. Then you will need to work the locking jaw back and forth till it breaks free then reinstall.
Posted on Mar 18, 2010
  • 6356 Answers
SOURCE: is samsung pedestal model number
The correct pedestal for the WF220ANW washer is WE357A7W . The WE356A5W is a slightly different size to secure it to the washer (14 2/5 X 27 X 28 7/10 In). The WE357A7W is 27"(W) x 14"(H) x 28.5"(D). The holes for the screws will also not quite line up.
I hope this helps.
Posted on Jul 11, 2011
Anonymous
  • 6277 Answers
SOURCE: I have a front loader Washer Model P1203J. The
That's a good indication as the drain motor is independant of the main motor and belt.
Quick way to see/confirm- REMOVE POWER FROM THE MACHINE AND HAVE THE BACK REMOVED.
Belts are not expensive- sorry I do not know how much yours would cost- and are easy to be changed by a competent person:-
The motor support bolts should be loosened and the old belt removed. Often putting the new belt on is a bit of a struggle, even with the motor 'loose', because it is new and smaller!
Once on it should be tensioned by pulling the motor against the belt firmly- but not over tight- and the motor support bolts tightened.
ON NO ACCOUNT SHOULD ANY FORM OF LEVERAGE BE USED TO TENSION THE BELT. THAT COULD LEAD TO DAMAGE TO THE BELT, MOTOR AND BEARINGS- EXPENSIVE!
If it turns out not to be the belt but the motor, it is false economy to just have the brushes changed although financially very attractive. Experience of others is that the brushes may only last months unless, that is, the motor is totally refurbished at the same time. It depends on how old the motor is and how much wear the commutator has had. New motors are not cheap, though. Ours for a Bosch cost GBP250- but it's your choice!
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Aug 01, 2011
Samsung front loader smokes
Please do not run machine with smoke coming from washer. You could create a fire. Unplug power cord, and call a qualified service person.
1helpful
2answers
Samsung front loader washer Model: WF306LAW
The "3E" error code indicates that a high current is detected.
A "3E" error in a Samsung washer indicates that there is an issue with the motor. Restarting the cycle may clear the error, but a service technician should be consulted if the error code appears again.
Samsung washer error code f1
What kind of detergent are you using? F1 in most cases means that the wrong type of detergent is being used. If it's a front-loader, you should be using h3 detergent.
2helpful
Samsung front loader washer gets about 3 i nches of water over 12 to 14 hour period
This is symptomatic of a malfunctioning water control valve- not closing completely which is its default/no power position. Turn each tap off overnight in turn to see which one is the culprit. It needs replacing ;-0(
Good luck,
John C
Please score this solution accordingly- thanks!
Washing Machines Logo
Top Samsung Washing Machines Experts
Joaquim Martins
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
