My Hobart glass wash machine model:FX.A.SEF 12/u73 keep reading put drain strainer correctly in place even though I can conform that the strainer is in place with the use of a true RM multimeter
Posted by albert watson on
Joe Allison
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 7 Answers
Hi You may need to pull strainer out and clean basket better, check interior aspects of strainer housing to see if build up of any kind is blocking sensor contacts of strainer.
Posted on Nov 10, 2016
Testimonial: "the strainer is new the sensor contact is working fine with strainer its just not reading through the pcb"
We have an ft900 with error code E516 can we reset to get unit going?
Operation and Care of FT900 SERIES DISHWASHERS SAVE THESE INSTRUCTIONS OPERATION MACHINE PREPARATION - Check before beginning operation. Open the machine doors and make sure all components are in their proper operating positions Pump Intake Screens must be put on holders at each pump intake (Fig.1). Fig. 1 Strainer Pans must be in place on top of each tank (Fig. 2). Fig. 2 End Caps must be correctly installed at ends of all Wash Arms (Fig. 4). Fig. 4 Wash Arms must be properly installed and latched in place (Fig. 5). Fig. 5 The Final Rinse Arm (and Dual Rinse Arm when present) must be properly installed (Fig. 7). Fig. 7 Curtains and drainback pans must be in their proper places, refer to pages 11 - 14. Strainer Baskets must be in place in Strainer Pans (Fig.3). ANK FILLING Assure proper water hardness. Recommended water hardness is 3 grains or less per gallon. Higher hardness may cause excessive formation of lime scale. Chlorides must not exceed 50 ppm. All water (and steam, if equipped) supply valves must be opened and the electric supply turned on before the machine will function. Close all drains and doors. The drain handles are located near the floor at the front of each tank. Rotate drain handles clockwise to the vertical position. The prewash tank,
Sep 29, 2016 | Dishwashers
Avanti w797 does not drain. impeller keeps falling off.
Go to the following link:
http://www.avantiproducts.com/products/id/489
at the bottom of the page, click on the pdf "parts and accessories"
Nov 24, 2013 | Avanti W797 12 lbs Top Load Washer - White
My washer does not fully drain when it is done. The only way that I can get the water to drain is to go to the 2nd rinse cycle and press spin and drain only. I constantly get readings of F21 also.
There is a strainer on the drain pump that is clogged. The manual does not mention this at all, it merely states the drain hose is kinked or clogged.
Under the front door there is a panel that is the width of the machine and is held in place by two screws, one on either side.
When you remove that you will see the pump and the the strainer attached to it. Unscrew the strainer (put a small pan under it to catch excess water) and remove to remove the junk accumulated.
Also, attached to the panel is another manual that refers to the error codes you are seeing.
Jan 03, 2010 | Kenmore HE3T Washer
Regarding the kenmore he2 plus front loader washer.f-21 keeps coming on.actually worked for a couple loads today but f-21 started coming on again after i started washing a 3rd load of colored clothes.seems...
Dec 20, 2009 | Kenmore HE2 Plus Front Load Washer
Terrible smell coming from our washing machine
remove bottom cover at back of machine, loosen large jubilee clip on hose between drum and pump. pull hose down and off, take out strainer basket and pull top off, clean top, ball and basket by running under tap. clean out hose with an old rag. reassemble strainer and put back into hose, in the correct position. fix hose back on to drum and tighten clip. run machine on a hot wash and all should be fine.
Nov 04, 2009 | Hotpoint Ultima WF860 Front Load Washer
I keep getting a code F21 how do I unclog the washer
-or- you'll need to replace the pump.
Oct 10, 2009 | Kenmore Elite HE5t Washer
F02 with good pump and clear filter... now what?
"F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.$%^%#$
Jul 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Hobart LXiH preesure gauge is to low - 7 PSI
Todd - A pressure regulator will REDUCE pressure only. There is no back pressure - the machine's gauge is reading the incoming water pressure as it fills/rinses. Assuming the gauge is OK, the machine is only seeing 7 psi. There is an inline strainer in teh machine, check that for blockage. You said the machine was operating on 45 psi with a reading of only 12 psi. There may be some kind of pressure reducer - I have seen Hobart use special supply hoses with builtin orifices.
hope this helps, if not email me, i service commercial machines and came across your question as I was looking for help myself!
[email protected]
dishwasher in subject line
Oct 18, 2008 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Horbart dishwaser wont dran
Its a hobart correct?The data plate is on the bottom right front or on the door when opened on the left.If you dont see it then its been removed.Regardless does the display show a wash then rinse cycle?If so and it doesnt drain you either have a clogged drain hose or the drain valve is bad or stuck.If you use this just to wash glasses your model is probably a lxigc.If glasses are broken in the dishwasher which they probably are the glass has gotten into the drain body and is obstructing the valve from opening and closing.I work for hobart and services dishwashers alot.let me know.
Feb 21, 2008 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Washing Machines Logo
Top Washing Machines Experts
Marvin
Marvin
