Kenmore elite washer
Will not spin Makes a wining noise. Just all of a sudden
Posted by mullinmoon on
Anonymous
  • 213 Answers
If the water is draining but its not spinning more than likely the belt is broken
Posted on Nov 19, 2007
Whining noise from kenmore elite washing machine during spin cycle
it is poss. the bearings are going. if you can spin the drum by hand and it makes the noise it is the rear bearing...
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
May 06, 2014 | Kenmore Washing Machines
My Kenmore Washer Elite HE3, front loaded, makes a very loud knocking noise when it spins ?
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Nov 09, 2010 | Washing Machines
The washer shakes to much and make to much noise
Check out this tip I wrote about that...
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
Jul 21, 2010 | Kenmore Elite 45986 Front Load Washer
My washer wont spin
Most likely it's a motor coupling. (Between motor and transmission - brakes when you overload it.)
Kenmore washer repair in orange county, ca
appliance repair orange county, ca
Feb 07, 2010 | Washing Machines
Kenmore Elite HE3t 11042922200 Front Loading. F02 drain Problem
We experienced the same thing. I was able to restart and locate the noise to the water pump. After disassembling the water pump found the impeller shaft sliding out. For some reason this shaft will not stay in place. Had to order a complete pump assembly as the electric motor is not available.
Jan 15, 2010 | Kenmore Elite 45986 Front Load Washer
It has stopped spinning. Still makes a noise that
sounds like the motor coupling has broken,anytime a washer gets out of balance it usually breaks the coupling!
Jan 09, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE3 washer won't spin during rinse cycle...
possible door lock failure fdl/error code f-11- maybe f-2 pump,,,
Dec 27, 2008 | Kenmore Elite HE4 Electric Dryer
Clicking sound.....
must likely something in between drum & basket or rear bearing going bad.call sears ask for service smart agreement it will cover rear shell with bearing &basket in warranty
Nov 13, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore elite washer 26922
I would take body of washer find out where noise coeing from.. got 2 screws in each side of head, flip head up and take clamps off .. pull whole body off washer run thu cycle and see if ya can locate the noise.. sometimes water pumps get something in them that well make weird noises.. but are in all cycles.
Sep 07, 2007 | Washing Machines
Washing Machines Logo
196 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
