Hi Sadaqat Ali, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
What model?Hi Sadaqat Ali, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
What model?
You can't post conmments that contain an email address.
The C 3502 error code in Konica Minolta c 6100, 1100, 1085, and 6085 machines is related to the fusing unit. The error code indicates that the fusing unit is not heating up correctly. There are several reasons why this error code might appear, including a malfunctioning thermistor, a broken fuser heater lamp, or a damaged fuser thermostat .
Turn off the machine and unplug it from the power source.
Remove the fusing unit from the machine.
Check the thermistor and fuser heater lamp for any damage.
Replace the damaged parts if necessary.
Reinstall the fusing unit and turn on the machine.
If the error code persists, it is recommended to contact a Konica Minolta service representative for further assistance
First Sir/Mam, Please let me explain the Di 200f series is not a color copier! What is the model the code C-3710 is not associated with the Di200f series.
Feb 2, 2013 - Code c0510 in dialta 520 how to reset - Konica Minolta MINOLTA ...Home · Forum · Fax Machines · Konica Minolta · MINOLTA BRAND DIALTA 8935-902 BLACK TONER TYPE 603A FOR USE. ... BLACK TONER TYPE 603A FOR USE INMINOLTA DI-520 ... My minolta dialta copier has a c-of24 error code,.
You have to see how the led is blinking and to compare with the table that
explains every blink what means. If you don't have this table, contact me and
I'll send it to you.
Chip reset device
for Konica Minolta Bizhub and CF imaging units http://www.chipreset.eu
Update Firmware on machine to latest level ,you will need the print driver and scanner driver installed
use the USB connection
Here is a link to the ftp site for firmware download ftp://ftp.minolta-qms.com/pub/drivers/other/MC2490MF/
There is apdf that explains how to update the firmware correctly
to get started turn on machine with the menu key held down the display will change to BIOS mode
then send firmware from program downloaded
What model?
