Question about Panasonic KX-T7731 Corded Phone
How do I view the time on my Panasonic KX-T7731? At this time I am able to view the date and the day only. On my other two Panasonic KX-T7731 I am able to view the time and the date. Please help!
Posted by Yaniv Dvora on
5 Related Answers
Anonymous
  • 4 Answers
SOURCE: Changing date on Panasonic KX-T7731
If it is displaying "101:" that is your extension. You can press the * key (with phone on the hook) to scroll your display through date and time formats and to display your extension.
When it says "PITS-PGM NO" you will need to press one of the buttons on the numerical key pad to choose a function to change.
Hope this helps!
Posted on Apr 09, 2008
cnavarro
Carl Navarro
  • 2460 Answers
SOURCE: Time Change
It can be changed from any phone that lets you into programming. We usually give everybody access to make changes like this, but by default, the phone designated as the Manager or Operator is usually given that access. Try ext 101.
When you get there, press PROGRAM **1234. If your display reads SYS-PGM No?, then it will work. Dial 000 and STORE. You will see the Date. Press SP PHONE! Now you will see the time. Dial the new time and press STORE. Press HOLD and PROGRAM to exit or just pick up the handset and drop it back down.
If for some odd reason you can't get into programming from ext 101, then you might have to search for the manager's phone, or call your installer to make one or all of the phones have access to programming.
They can allow you access to other programs, or even give you the installer password to get into all the programming.
Carl
Posted on Oct 29, 2009
Testimonial: "Thanks, great help"
Anonymous
  • 113 Answers
SOURCE: Panasonic kx-t7731 phone.... How do you set the
While the hanset is on the cradle press # or * until the desired display is shown. If that does not work press the info key below that is shown on the screen.
Posted on Mar 18, 2010
Anonymous
SOURCE: how set time for panasonic kx-t7731? thanks
This worked on mine:
Press Program, then 0
Make note of the numbers on the display (should read something like 100514 5 12:30PM).
Enter two digits for each in this order year month day.
Enter the same number that appeared on your display between the date and the time.
Enter the time.
Enter 0 for AM, 1 for PM
Press Store (phone should beep twice)
Press Program
Posted on May 14, 2010
Anonymous
SOURCE: Panasonic KX-T773 reads "102:" instead of date/time
Your extension reads 102 because that is the extension #.
Press either the tranfer key or the " * " star key and your display will change to time and date or just the date.
Posted on Oct 29, 2010
Change in display
Go to options - display - date/time format. Change it to short
Nov 27, 2013 | Panasonic KX-T7731 Corded Phone
Panasonic kx-t7731 phone.... How do you set the screen on the phone so it reads the date and or time?
Mar 16, 2010 | Panasonic KX-T7731 Corded Phone
Oct 28, 2009 | Panasonic KX-T7731 Corded Phone
The display reads "102:" on my T7731- how do I go back to time?
That is your phone's extension number (102).
Hang up phone and press the star key * one time.
Hope this helps!
Sep 09, 2009 | Panasonic KX-T7731 Corded Phone
DIsplaying date and time on KX-T7731 phone
While the handset is still on the cradle/hook press * or # until the desired view is diplayed.
If this was helpful please rate / vote
Thank you
Jul 21, 2009 | Panasonic KX-T7731 Corded Phone
How do I get the date to display on my phone?
While the handset is still on the cradle press * or # until the desired view is displayed.
Please rate this answer if it was helpful
Thank you
Nov 18, 2008 | Panasonic KX-T7730 Corded Phone
Hope this helps!
Feb 07, 2008 | Panasonic KX-T7731 Corded Phone
How do I set the time and date?
You must be on the main phone on jack 01 to set time. You can determine if your phone is jack 01 by pressing PROGRAM and then pushing the number 6 on the dial pad. The phone will read the jack and extension number. When you have determined the jack 01 phone, do the following. 1. Push PROGRAM key 2. Dial "0" 3. Enter year (last 2 digits) 4. Enter month (01-12) 5. Enter day (01-31) 6. Enter day of week (Sun 0, Mon 1, Tue 2, Wed 3, Thu 4, Fri 5, Sat 6.) 7. Enter Hour (01-12) 8. Enter Minute (00-59) 9. Press 0 for AM 1 for PM 10. Press "AUTO DIAL/STORE" key 11. Push PROGRAM key to return to normal mode.
Sep 14, 2007 | Panasonic KX-T7731 Corded Phone
Panasonic KX-T7731 Corded Phone Logo
1,725 people viewed this question
Top Panasonic Lands Phones Experts
Muntejaya Ginting
Muntejaya Ginting
Henk de Ruiter
Henk de Ruiter
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
