Question about Refrigerators
Error code for FF for KingAir air conditioner?
Compressor not coming on error code FF showing on evaporator.
Posted by royston mitchel on
5 Related Answers
Anonymous
  • 104 Answers
SOURCE: Error code ER FF
The error indicates the freezer fan is not functioning properly. The fan supplies cold air to the refrigerator that is why it seems warmer.
The fan may be frozen, try unplugging it for a few hours to let it thaw. Also check to see if something may have gotten into the vent holes in the freezer that could be blocking the fan from turning.
Posted on Mar 11, 2008
lilytoy
SOURCE: error code er ff on my kenmore elite bottomfreezer model 795.7756
I fixed it. ER FF is "Error Freezer Fan." Once the evaporator fan stops turning for more than 115 seconds, this error message will be displayed. This fridge is poorly designed and is not designed with air gaps or enough air gaps to allow air behind the back panel of the freezer where the fans and condenser coils are located thus causing ice to build up around the fan and it's ability to spin. The evaporator fan helps cirulate the cold air generated by the condenser coils.
The fix is (1) defrost your refrigerator which means you'll loose all your food if you don't have another unit to keep the food in until it's done defrosting or (2) to dismantle the entire freezer by removing all the trays and railing so that you can pull the back panel far enough to get the front end of a hair dryer over the top lip of the panel to melt the ice. My unit had ice build at the top right and left corners behind the panel. I opted for the latter and didn't have to throw any food away.
This is going to be an annual chore if I want to keep this refrigerator. We should all ban together and call for a recall.
Posted on Dec 24, 2008
Anonymous
  • 400 Answers
SOURCE: LG Inverter Air Conditioner showing CH 02 what can I do?
The model number would be on the right hand side of the outdoor unit and same on the indoor unit if it is a midwall split. If it is a flat cassette cieling type you may need to open the grill, which is simply two little levers either side of the grill, and the grill will swing open. Without the model number it is difficult to give accurate info. However, I can offer the following. One, check the condensate drain. You can just blow into the drain pipe from the outside and this sometimes clears clogged mud in the drainpan. Or two, error reading can also come from phase failure (in the case of a three phase unit) or power related problem. This can be solved by switching off the mains and then switching on again to reset. If you have a phase failure you would need an electrician to confirm that the power supply is good. Unless you have a volt meter.
Posted on Mar 04, 2009
Anonymous
  • 68 Answers
SOURCE: Error code of E4 on Dometic HP air conditioner ??
16. SYSTEM RESET
a. Turn the ON/OFF switch to “OFF” position.
b. Simultaneously depress and hold the MODE and ZONE
push-buttons while turning the ON/OFF switch to “ON”.
FF should appear in the LCD display until the MODE
and ZONE push-buttons are released.
c. When a dip switch is turned on or off after initial configu
ration, a system reset will need to be done before the
Comfort Control CenterTM will recognize the updated selection. Try this. This is for the five button thermostat. Did you check the dip switches to be sure the proper ones are turned on? I need to know which stat you have 4 or 5 button. I have trouble shooting for both.
If you notice reset needs to take place after a dip switch is turned on or off. The dip switches are on the circuit board. You need to drop the lower cover. the dip switches will read in this order #1 heat strip/ #2 zone2/#3zone3/ #4 zone4/#5 furnace/#6 differential/#7stag/#8 gen start. Check this out and be careful. Turn off the stat to change dip switches. On will be toward the description. If you don't have remote start gen set the dip should not be on. If you dont have a Zone 3 the dip should not be on, etc.
Any questions feel free to post back
Thank you for using fixya
Jerry
Posted on Mar 26, 2009
Anonymous
  • 311 Answers
SOURCE: LG display error code FF IF
The FF error code is the freezer fan motor error. It could be a problem with your freezer fan motor or an issue with the control board not sending proper power to the board. If you remove the back panel you can check to make sure there is no ice restricting the fan motor from turning. If there is ice then check the icemaker fill tube and make sure its in place properly and not leaking down on the evap fan blade.
Hope this helps _MJ_
Posted on Feb 07, 2010
What should I do? Freezer is not cooling, inside light is on, control panel is off temp shows blinking OF and FF
usually means low freon... (of) and evaporator fan failure. can you hear the fan running in the freezer portion?...
Jun 05, 2015 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
What can I do? Freezer is not cooling, inside light is on. control panel is off, Temp shows blinking OF and FF
Might need a freon top up. If the compressor is functioning there may be in sufficient freon . This can be topped up. A repairman/technician can diagnose this fairly quickly
Jun 05, 2015 | Frigidaire Freezers
Our refrigerator constanly has ER FF in the ice & water display area. What does that code mean.
This error code ER FF indicates a problem with the evaporator fan motor but it can also be with the main control board. When the power cord is disconnected for 30 seconds and then reconnected, it resets the board. But resetting the board does not solve the problem always. The Defrost Control Board being defective will also show this error. The best solution would be to look for your complete model number and contact me HERE and I will send you your models Service Manual and parts to look for, I will continue to publish manuals HERE, Thanks, Sea Breeze
Feb 20, 2011 | LG Refrigerators
LFC 25760St Refrigerator displaying a code FF Er what is going on
Er FF code is a freezer fan motor error. Check too see if there is a loose connection to the freezer fan. If not you may need a new fan motor.
Oct 07, 2010 | LG LFC25760ST 25 Cu. Ft. Panorama French...
Kenmore trio 2 yrs old...my motor is on the freezer is working but the frige is not cooling very well...display shows "er ff" if I unplug and plug back in display is ok for a minute or so..then return to...
This is an error code that pertains to the evaporator motor but could also be the main board.
If the evaporator motor is running, the main board will probably need to be replaced.
It could be a wiring problem but it's not very likely.
If the motor is not running, some voltage checks will need to be made, at the motor and board, to determine which component has failed.
These checks require a meter and can be difficult to make, even for a technician.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 21, 2010 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
I have a Kenmore Refr. Model # 795.77563600 has a Error FF
The FF error code indicates that the freezer fan motor is defective.
You need a new main control board and evaporator fan motor.
The fridge is made by LG, but rebranded as Kenmore by Sears. First 3 digits is the tell. You can call Sears for parts.
LG refrigerator repair in orange county, ca
Feb 05, 2010 | Refrigerators
ER FF code
Apr 12, 2009 | Kenmore 77719 Side by Side Bottom Freezer...
Er FF ON THE BORD
FF usually means the freezer fan is not working. If the fridge is cooling poorly, check to see if the fan inside is running while the compressor is running. If not, and if there's no ice jamming it, then you need a new evaporator fan. If the fridge is cooling normally and the only symptom is the error code, then it could be a problem in the electronic control.
Oct 11, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerators Logo
797 people viewed this question
Top Refrigerators Experts
Marvin
Marvin
john h
