Washing Machines Logo
Question about Electrolux Washing Machines
John lewis washer dryer made by electrolux error code e91,72,se melted wires inside, just over year old. Electrolux want to re-wire but they don't know why the wires melted?
Posted by Penny Frith on
5 Related Answers
Anonymous
SOURCE: Error code E10 on the
E10 is a timeout code. I found the answer on google by refining my search criteria. The tap was not turned on enough for the washer to fill up in time before the timeout was reached. After restarting the washer and turning the tap on further, the washer cycle completed without error.
Posted on Jul 22, 2008
Anonymous
SOURCE: Frigidaire Washer Dryer Combo: Dryer Only works on washer spin
Are you connected to a 30 amp breaker w/ 30 amp wire?
Posted on Feb 23, 2009
Anonymous
SOURCE: Electrolux EWF 1087 error code E60
My Electrolux washer always come up with an error code of E60, Why? can any one help
Posted on May 20, 2009
Anonymous
SOURCE: Electrolux EWX14540W washer dryer error code E72
have power but does not rotate I NEED SERVICE ASAP
Posted on May 28, 2009
Anonymous
  • 27 Answers
SOURCE: error codes for Electrolux front load washer EWF 1087
E40 error is door interlock faulty, could be the lock or it could be the pcb u have to test them.
Posted on Jun 25, 2010
How do I get rid of code? I have an Electrolux front load dryer model #EIMED55IIWO, with E 64 error code. When initially starting the dryer I cancel the code and start the dryer.
E64 error code Electrolux dryer! E64 fault code on your home Electrolux clothes dryer. What this code stands for is that you have a shorted heating element. Other Possible fault: Heater thermostat faulty: Wiring faulty; Electronic board faulty.
https://advancedappliancesolutions.com/e64-error-code-electrolux-clothes-dryer/
https://www.youtube.com/watch?v=ErDSsjVywwg
What does error EHO in electrolux EDC2086GLW drayer with condensor refers to
The EH0 error indicates a problem with the incoming voltage or the power supply or wiring inside the dryer. If there has been a problem with the electricity coming into your home (brown out or similar), the error will resolve when the power company fixes the issue. Otherwise the control board is not receiving the expected power from the power supply.
First unplug the dryer or shut off the power at the circuit breaker. Unplugging the dryer for at least 30 seconds will reset the error message. If you can, plug another appliance into the outlet and check if that works. If there is a wiring fault, get an electrician to check the outlet and wiring.
If the problem is inside the dryer, the power supply, the control board and the wiring to the control board will need to be checked. There could be a loose wire, a broken wire or a spot where the insulation has been damaged and two wires are touching. Check all of the wiring harnesses where groups of wires plug into the control board. Replace or fix any damaged parts or wires. The parts diagrams are available here: https://www.ransomspares.co.uk/parts/brands/electrolux/tumble-dryers/edc2086glw%20(91609724100)/ . If the dryer is under warranty, contact Electrolux to have the unit serviced.
I hope this helps.
My electrolux type EWF10842, on display find error EHO, what mean this error,and how to resset, thanks
The EHO (or EH0) error indicates a problem with the incoming power or an electrical problem inside the washer. Unplug the washer for a while to reset the error code. Next check your wiring and make sure that the outlet doesn't have a fault. If you live in an area with brown-outs or wires that touched during a storm, wait until the electricity is repaired. Then check if the power supply to the washer was damaged by the surge or changing power levels.
If these aren't responsible for the problem, you'll need to check the wiring for shielding damage, the wire harnesses and the rest of the washer. There is a parts diagram here: http://docplayer.net/60693214-Spare-parts-list-household-washing-machines-pnc-elc-brand-model-market-electrolux-ewf10842-th-washing-machines-front-loaded.html .
I hope this helps.
What Does Error Code E90 mean on a John Lewis Washing Machine JLWM1202 made by Electrolux
How should anyone know? Go to the web site and find out so you can be guided accordingly.
1helpful
I have Electrolux front load wahser Model EIFLW55HIW0 that is about 6 years old, Has worked without a problem for many years. recently started giving E35 error codes. the water doesn't ap
Hello friend, thank you very much for your inquiry!
After reviewing the information you have provided regarding your Electrolux front load washer EIFLW55HIW0 having an E35 error code, I have found E35 is an indication of a water over fill problem. If the water fills above 4.5 inches please follow the below trouble shooting steps I have provided for you. If the water is not above 4.5 inches you may need to change the pressure sensor switch.
If the water enters continuously please unplug the washer to see if the water stops. If the water does not stop your issue may be the water valve assembly. If the water does stop the wiring to the water valve assembly needs to be checked. If the wiring is good the control board may need to be replaced.
I do suggest you seek a professional technician to look into this issue further to avoid any unnecessary part purchases. - T
1helpful
How do I access the fault codes on an electrolux 1200
I see many posts about Error Codes that aren't in the user manual. Here's what I found: Go to Google and type in "Electrolux Error Codes" and you will find the following site. It details an Electrolux Service Flash that helps with error codes that don't appear in your user manual. Good Hunting!
Customer Error Codes On All Digital Display Frontload Washers - [ Terjemahkan laman ini ]Electrolux Service Flash LN071 02.13.07. NOTE. These customererror codes are not included in the error code chart on the technical data sheet located ...
www.applianceblog.com/...electrolux/886d1212672468-frigidaire-front-load-washer-doesnt-start-frigidaireerrorcodesonalldigitaldisplayfrontloadwasher...
Electrolux Gas Dryer: E66 error
Should the heater wire have electrical continuity to the housing
20helpful
6answers
Open Questions:
Top Electrolux Washing Machines Experts
nu267
tina gallow
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
