Drills Logo
a
ancel govender Posted on Nov 07, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My metabo khe2444 stopped working while i was drilling, what could be the common cause?
The Vanguardian
Level 3:
Master:
  • Master 531 Answers
  • Posted on Nov 07, 2016
The Vanguardian
Master
Level 3:
Master:
Answers
531
Questions
0
Helped
180441
Points
2974
If it's fairly new, the electronic switch/speed control is the most likely thing to go out. Check and see if you can get full speed out of it. If so, then it's definitely the speed control.
If it's been used a lot, then it could be the brushes or bearings/bushings.
Here is one of the companies that sell parts for it. I'm including this so you can see a diagram. (I've never bought anything from this company, I'm not trying to promote them.)
http://www.mtmc.co.uk/Metabo-KHE-2444-/-06154000-/-EU-230V-Spare-Parts__p-103435.aspx
3helpful
2answers
1helpful
I have a 15.6v NiCad metabo drill can you replace 15.6v battery with the 18v which fits exactly the same in the drill
No the motor is only rated for the voltage that came with it it might work for a little bit but will burn it up
Where can I buy a forward/reverse switch for a metabo right angle drill BE 622
Service Centers are listed on the Metabo Web Site. go to Metabo.US, then Services/Support, repairs and spare parts and in the center of the page click "Service Center". input your 5 digit zip code and it will offer you a list of all local groups that support the Metabo line.
Red light comes on after a couple of seconds and the drill stops working
Hi did u get this fixed my one does the same battery say it's full but red light comes on drill stops cheers
Drill does not work when i press the trigger
Did you take a look at the carbon brushes?. Metabo has what they call Auto stop Carbon brushes. so if they are worn down they will pop away from the motor and the drill will simply not run. this happens when the brushes are basically worn out.
1/2" metabo hammer drill-
Did you check the carbon brushes?
2answers
It will not work with my power inverter in my truck, but it works when used on a regular 120v outlet. My power saw and my HILTI Drill work but the METABO UHE 28 Multi just will not work at all??? WHY ???
The inverter isn't putting up enough power to drive the metabo. You may be able to give it a "running start" by rotating the blade along a board while pulling the trigger. This isn't a good practice, however, as the board or the saw could slip, so be doubly careful if you try something like this. Your best choice would be to get a bigger inverter.
Best regards, (and be careful), --W/D--
1helpful
I need a battery for a metabo sb impuls hammer dril and charger drill perfect working order battery and charger lost in mooving house. has on bottom of drill were battery conects pa6-gf30 can you still get...
I saw them in the latest Metabo leaflet. They are serious producer and they shoudl keep spare parts for few years after they discontinue some product. Try to call to Metabo in your country. Juraj
Metabo SBE750 hammer drill trigger sensitivity
The only possible sollution for this failure in this particular tool is to replace the switch. There are no additional electronics that could cause this.
Hi, i hqave METABO 523 hammer drill that the
You're welcome to ship the unit to me for repair.
Contact me at [email protected] for more information
Top Metabo Drills Experts
john h
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a Metabo Drill Expert? Answer questions, earn points and help others
