Question about Toys
Can a PIN number be reset at any ATM machine?
Posted by Joan Moat on
  • Max Muller Jun 26, 2020
    nope
  • Colin44
    Colin44 Jun 26, 2020
    I think that you have to go to the bank to change your pin. You will probably need to get a new credit card because I think that every card has it's own pin. I am not sure why would you want to change your pin. If you have forgotten it I think that you can get it in the bank also. I really like the new ATMs that are being installed in my city, look here to see the model. Hyosung ATM Machines are really good and easy to use. It is much nicer and quicker so you won't spend too much time on it.
Ted Chiwaula
No, it is not possible. Since the records is with your bank - the other bank ATM will not accept this option. Therefore, you cannot use other bank ATM to change the pin. Even when you receive the debit card first time, you have to activate your card in the ATM of your bank only initially and not with another bank ATM
Posted on Jun 27, 2020
The pay pal account registration form asks for a pin number ,I provided all the other information ,but I do not have a pin no. and that is preventing the copmpletion of the account. ?? I spoke to the bank...
Pin numbers are all different and not all will work with your bank's atm for security reasons. This is why you should write everything down. Call PayPal back and ask them to help you reset your PayPal account.
Feb 13, 2015 | Computers & Internet
ATM PIN Number Reversal - Good to Know !!
Yes from what I hear this is the case .
Mar 02, 2017 | Computers & Internet
I wan to know my atm pin number
There is no way I can pluck this out of thin air.
You need to contact your bank and get them to reset your ATM pin number, then you need to change it straight away so you are the only one that knows your PIN number.
Record your PIN number and keep it in a safe place, if someone knows your PIN they can empty your bank account.
Nov 18, 2010 | Computers & Internet
Forgot PIN
Answer: 1. Insert your ATM card into the slot with the holes pointing down
2. The auto teller will ask you to enter your PIN code.
3. Press and hold keys 1 and 2 until the screen reads, "Reset PIN."
4. Enter a new four-digit PIN code, and then press the "e" key.
5. Enter your new PIN code again to confirm. Press the "e" key.
6. The ATM Safe will restart.
Aug 08, 2010 | Wild Planet Room Gear Atm Safe Bank
I reset my zillionz atm machine but know i need help finding the pin number.
type in your password and hit enter twice. then type in your new password
Mar 11, 2010 | Summit Appliances Division Youniverse...
Need to change pin
I forgot the pin number for the atm and now I have no idea how to reset it. I tried to press the reset button, but it still refuses to let me change the pin.
Aug 20, 2009 | Summit Appliances Division Youniverse...
Changing pin number for zillionz atm.
To reset pin - When you tun it on and press 1234, then press enter twice. Then type the number you choose!
Aug 04, 2009 | Summit Appliances Division Youniverse...
Resetting Pin on Blue Hat ATM machine
Hi abbeybath,
We have the same atm/bank for our son. Here's the fix:
1 - push the reset button on the back of the ATM near the battery compartment.
2 - insert the ATM card and press the BALANCE button to change the user name (need to do this before getting to the pin)
3 - enter your childs name and push enter when complete. Cancel will delete an incorrect letter.
4- enter the default pin (1234) - this will bring up the DEPOSIT, WITHDRAWL, BALANCE screen.
5 - Press ENTER and it will show the current/default pin. Input the new pin number you desire and press ENTER again.
All set. Hope this helps!!
Jan 17, 2009 | Blue Microphones Blue Hat Little Shots...
Blue Hat Toy Company ATM - help! No setup instructions!
ok i hit the rest button on the back of the machine and it erased all my memory off of it so i had to reprogram it .If u put 1234 in as a pin # it will open then press balance and hit enter and u can change your pin # there .
Dec 25, 2008 | Blue Microphones Blue Hat Little Shots...
SUMMIT PRODUCTS YOUniverse Deluxe ATM Bank Machine
We had the same issue -- the name could be reset, but not the pin could not.
Finally, I realzed that when it is reset by using the reset button or the batteries, the PIN is reset to the factory default of 1234. Don't try using your old pin at this point -- enter 1234 as the pin.
Once you have the bank working again, theoretically you can reset your pin to whatever you like by hitting enter twice. I say theoretically because we're sticking with the factory default for now.
Hope this helps.
Nov 07, 2008 | Summit Electronic Money Jar
Toys Logo
83 people viewed this question
Top Toys Experts
Marvin
Marvin
Tom Chichester
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
