Cars & Trucks Logo
Richard Elliott Posted on Nov 07, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My left eye keeps twitching - Cars & Trucks
james laughton
Level 3:
  • Cars & Trucks Master 2,195 Answers
  • Posted on Nov 07, 2016
james laughton
Level 3:
Answers
2195
Questions
Helped
411228
Points
6636
You may have a nervous tick but visit a doctor to rule out anything else
Wipers just twitch up and down one inch
Have you physically cleaned the windows? Wipers won't take ice off and will sometimes break when used that way.
If you can't remove the ice, run the car with defrost on high heat until it melts before using the wipers.
The wipers continue to "twitch" you may have popped a gear apart or broken part of the apparatus. Let me know!
My leg have felt as though thing Pulsating thetththere is a pulsating feel is soing as though sommethis going upmand down my leg Insometimes feel this in my arm. What is the answer please?
hi pamela.
Throbbing from vascular origin
A vein can produce this sensation because of the increased blood flow to a particular area due to physical activity - this can happened when you jog in the morning or after bodybuilding exercise or any other physical activity. When somebody tackles you during a football game and traumatizes your leg, the swelling can push on the vessels and this can produce a throbbing sensation. A trauma can also produce an abnormal communication between an artery and vein - this is called AV fistula.
Usually throbbing from vascular origin is not a reason to worry. You may visit a general practitioner who will probably examine the blood flow and may even order a test to look at your vessels.
Rarely the cause of throbbing is aneurism which produces a wide pulsatile area - aneurisms are often treated surgically.
  • It is useful to know that common conditions such as deep vein thrombosis, blood clots or peripheral artery disease usually do NOT present with throbbing sensation but usually present with pain and swelling.
Throbbing caused by muscle twitching
Turn off the lights, sit on a chair and use a direct light from a lamp and try to make the light beam horizontal so you can see the throbbing area clearly.
If you see tiny twitches you should know that your throbbing sensation is produced by your muscles.
Conditions causing muscle twitching
Although muscle twitches are often idiopathic or as a result of muscle hyperactivity or hyperexcitability because you had too much coffee or you had a heavy exercise earlier, muscle twitches can be a symptom of a serious medical conditions.
B12 deficiency. This is found especially in alcoholics or vegetarians. Muscle twitching is not an early symptom, usually B12 deficiency presents with anemia and decreased or altered sensation.
Multiple Sclerosis. Usually presents with pain behind one eye. Muscle twitching is a common symptom.
infection and Amyotophic Lateral Sclerosis also known to cause muscle twitches. It is advisable to see a neurologist for further evaluation, the neurologist is most likely to order MRI and blood test
read up more at this link.
https://www.steadyhealth.com/medical-answers/causes-of-throbbing-or-pulsing-sensation-in-arms-or-legs
Understanding Symptoms of Aneurysm
https://www.steadyhealth.com/topics/strange-throbbing-pulsing-in-my-thigh-just-above-knee?page=2
what is the cause of Pulsating in my leg Google Search
1.4 sxi corsa 4 door. 2 doors on the left side doesn't lock. Could this be a fuse ? The 2 doors on the right & boot lock. Thanks
there is a selector switch on drivers side...the locking mecanism can be faulty...do they twitch at all when others are locking?...
1993 Dodge Spirit Speedometer twitches
Hey maybe its time to replace the sensor?
The best way to change the side light bulbs
  1. Turn left directly from the bike lane.
  2. Keeping a weather eye on traffic, move into the left-hand lane and turn from there.
  3. Veer right onto the sidewalk (avoiding buses, obviously); wait for the pedestrian light to cross
2answers
Why my top left lip twitching
go to a medical dr. unless it has been going on along time ,could just be a tic..lots of things can cause this nerves old age in general.. mudman1966
Dash twitching and stero no power
Check your fuse boxes, usually one under the hood and one under the steering wheel, might have just blown a fuze somewhere along the line.
I replaced my speedometer cable with a new one, but the speedometer\r\nstill twitches until about fourty miles per hour. I do know after it stops twitching, it is very acurate. How can I stop the needle...
when replacing you forgot to put oil into the cable.remove from the top and put some oil into the cable let it run down the inner cable .problem solved,[its sticking]adrian.
3helpful
Problems starting my 2005 nissan frontier
Sounds like the battery is weak which will cause the gauges to twitch.
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
