Question about Sharp AR-5320 Black and White Copier
Hi! My SHARP AR 5320 can't operate I turned on the switch then the 3 codes --- is flashed and after that, L and 4 is blinking what shall I do? Thank you.
I used these method and it works that it clears the error but when I turn it back on it appears again the L and 4. 1, press"#" "interupt" "c" "interupt" these 4 keys. 2, enter 14 , then press start 3, turn power off and back on .
1 Related Answer
wheatlandsvc
Edwin Martens
  • 1110 Answers
SOURCE: U2 FLASHING ERROR. THIS HAPPENED AFTER TONER WAS
key in 16 instead of 14 for U2 clear
Clear, Interupt, 0, Interupt, 16 then print
Posted on Oct 20, 2009
My sharp ar-5320 copier has an error code blinking it flashes h and 4.
The H4 stands for a problem in the heater circuit for the fusing unit, It could be a thermo fuse, thermostat, thermistor, bad heat lamp or worn fuser rollers. The H4 will not reset until either of these components is repaired or replaced. Hope this helps.
Sep 29, 2011 | Sharp AR-5316 Advanced Digital Imager...
My AR-5320 Sharp Copier is Blinking h-4 please send me the code to repair it.
Push the 'clear' button and then the 'auto' button then the 'clear' button and then the 'auto' button again.This should be done as quickly as you can and the console will go blank.Next,select 14,which is the low temp clearing code, and then push 'start' and then turn the machine off and back on again.
Sep 14, 2011 | Sharp AR-5320 Black and White Copier
My sharp ar5320 has an error code blinking it flashes h 4 what would i do?
On your keypad press in order # * C * .That will put the machine in diagnostics. Then enter 14 like you were making 14 copies. then press 1, then start, that will reset the machine.
Aug 09, 2010 | Sharp AR-5320 Black and White Copier
Code Error H 4 in sharp photocopiers Model AR 5320
please try to reset .here the programme you have to do ..# interrupt c interrupt. mechine will go shutdownmode then press 14 and press start. u will solve the problem
Dec 21, 2009 | Sharp AR-5320 Black and White Copier
Error L4
l4 if sub code is 01 .check sub code by pressing start key .that is for main drive motor and gears .just check all main drive properly mian jee
Jan 15, 2009 | Sharp AR-5320 Black and White Copier
Sharp AR-5320 Driver
Appreciate the direct "Ask Me". For Sharp AR5316/AR5320 drivers, pls click here. The drivers are for Windows 95, Windows 98, Windows ME, Windows NT, Windows 2000, Windows XP only.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Nov 17, 2008 | Sharp AR-5320 Black and White Copier
Sharp AR-5320 giving me L 4 error some time
Usually the error is caused by a main drive over load. The machine needs to be looked to determine if its the motor, power supply, or a board.
Sep 19, 2008 | Sharp AR-5320 Black and White Copier
Error code
Hi, H4 is a heater error. Try resetting it by the following; Enter #, interupt, Clear, interupt, display goes dead, enter 14 then print. That will clear the error code, however if you have a problem with the heater it will return. It is probably the thermal fuse has tripped, which is resetable by removing the fuser unit
Regards
Andy
Jan 22, 2008 | Sharp AR-5320 Black and White Copier
Sharp AR-5320 Black and White Copier Logo
160 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
