A boat with a flashing red light at night what does it mean
Posted by Robert tuck on
  • Televison & ... Master
  • 18,519 Answers
The only requirement for a sea going vessel to use a light that is flashing red at all is for a wind in ground craft. (a pontoon enabled aircraft) that is flying close to, landing on or taking off from water.
Posted on Nov 06, 2016
Jvc car stereo KD-R570 flashing red
To test radio to see if its working you can bench test it. This means to combine red and yellow and run to 12V positive and Black to 12V negative. IF radio turns on, it would mean its working.
Aug 04, 2014 | JVC Car Audio & Video
How do i use the flash so it will take pics at night? and what does PIR mean on the menu shouldi set Hi Lo or Med?
hi ,ill be suprised if theres a flash , it should just automaticly switch to night vision using infra red light,, as for PIR,,p.i.r stands for
passive infra red,, its like a beam that when disrupted will switch something on , in your case, "take a shot"the high medium and low just refer to sensitivity,,mouse , cat, dog . elephant ,
Oct 15, 2013 | Wildgame Innovations Axe 2 2Mp Game Camera
Flashing red light batt. fully charged
Flashing red light usually means low batteries. Check the batteries after charging all night with a volt meter through the charger port you should read 26-24 volts dc. If you get a lower reading and you are sure the charger is working correctly then you will need to replace both batteries Hope this helps
Aug 21, 2010 | Jet 3 Ultra Power Chair
Flashing Red Light....
The flashing "boat" in the middle of the viewfinder just means the button battery is dead. Camera will still work. It's the little pull-out light grey plastic thing that's next to the heel of your right hand when you're using the camera normally. You need a CR2025 cell.
Jan 27, 2009 | Canon XL1S Mini DV Digital Camcorder
My Sony HD-TV KDF-50E2000 is about 18 months old. The picture went out. The green on light stays on for only a few minutes then goes off and the red lamp light flashes. You can turn the Tv on again and the...
How many times Red Lamp flashes, its important as it shows problem and its location in tv. Below is detail of lamp blinks and you may know the problem area in tv by counting lamp flashes.
Need further help, let me know.
Sep 13, 2008 | Televison & Video
Flasing red light
The flashing red indicates that either the fileter cover or the lamp cover is not installed correctly. If both are installed properly and secured, the unit will require service.
Dan
May 09, 2008 | Sharp XR-10X Multimedia Projector
Whirlpool s20b fridge/freezer
858615215011 temp. indicators and night light flash continuously.
Mar 27, 2008 | Refrigerators
Televison & Video Logo
148 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
