Question about IBM ThinkPad T40 2373 Notebook
I have a iBM t40 2373 Thinkpad note pad when i turn it on i get 2 codes one is 0176 and the other is 0271 how do i fix it
Posted by marilyn mansur on
5 Related Answers
Anonymous
  • 558 Answers
SOURCE: i forgot my bios password
Hi Marbz,
Read this article may be helpful to you
http://www.dewassoc.com/support/bios/bios_password.htm
And not to forget rating me.
Regards
ELLIN
Posted on Sep 17, 2008
Anonymous
  • 20 Answers
SOURCE: IBM ThinkPad 600E 2645 PC
the following data is from the hardware maintenance manual for the thinkpad 600 series and is readily available from http://www.lenovo.com/support
Symptom or error FRU or action, in
sequence
161
Dead battery.
1. Go to “Checking the
backup battery” on
page 12.
2. Backup battery.
3. System board.
163
Time and date were not set.
1. Set time and date.
2. System board.
173
Configuration data was lost.
1. Select OK in the error
screen; then set the
time and date.
2. Backup battery.
3. System board.
192
Fan error.
1. Go to “Testing the
computer” on
page 7.
2. Measure the voltage of
the backup battery. If
the voltage is not
correct, replace the
backup battery.
3. Fan.
4. System board.
Posted on Oct 10, 2008
Anonymous
  • 2712 Answers
SOURCE: IBM THINKPAD T30 KEYBOARD
Make sure NumLock is OFF.
Posted on Oct 25, 2008
Anonymous
  • 748 Answers
SOURCE: How do I get pass IBM Thinkpad A31 Lock Code?
Laptop BIOS passwords are kept in a special password chip. On some laptops these chips are replaceable and there are a number of places you can buy this. PWcrack.com for one.
Posted on Mar 25, 2009
Geekman
Chris Hingee
  • 32281 Answers
SOURCE: ibm think pad r51 nodisplay 4 beeps commaing
This indicates a possible memory problem. Reseat the RAM modules and boot up, if OK then the laptop is OK.
If not then :-
If you have two RAM modules, remove both and insert one and boot up, if it is OK then repeat with the other one - this will determine which memory module is faulty.
Posted on Mar 30, 2009
Touchpad not working ibm thinkpad
ibm think pad T43 is bess loptop for student
1helpful
2answers
My thinkpad t61p is not booting/no video. Giving 3 beeps, 1 long and 2 short beeps.
Hello
1 long, 2 short is an error with the video adapter. This isn't specific to IBM systems either, that code is the same for pretty much every BIOS out there.
It seems your video card may be at fault. has anything changed? do you have any picture on the display at all? If you have zero picture it will be hard to get into safe mode and try to roll back drivers etc. It may be that the video adapter is just defective. You can contact IBM/Lenova and see about getting a replacment or you can take it into an authorized repair place. You can also attempt to obtain a replacement video adapter for the T61 and install it yoursel fif you have the knowhow
Hope this helps Good luck!
Laptop mouse problem
This is a common problem with laptops, unfortunately, there is no real solution of fixing the touch pad.
The best solution is to use an external usb mouse.
I recomend an optical mouse, they cost about 5 US dollars.
5helpful
How do I turn on the wireless on an IBM ThinkPad 2628 A20m Thanks in advance
To turn on the wireless on IBM Think Pad 2628 A20m you can try the below options
IBM
IBM General - Some models have the wireless slide button on the side of the laptop.
IBM DV series - use the antenna-like button found on the upper section of your keyboard.
IBM R40 - Use the Fn+F5 key-combo.
IBM Thinkpad (General) - Most have software switch or button on Left hand side.
IBM Thinkpad (model not further identified) wireless switch on Front edge of case.
IBM T43/X32 - Fn+F5 -Click "Turn On"
IBM ZD series use the antenna-like button just below the “Lock” key.
Let me know fi this will help
1helpful
Problem with ibm thinkpad r40
The IBM beep code error 1 long 2 short beeps means there is a video card fault. Reseat your RAM because the video card uses some of the RAM. If it doesn't work then the video chip on the motherboard is faulty, the only way to fix is to replace the motherboard - this may not be a cost effective solution.
Connecting an external monitor to the laptop won't work because the video card also sends data to the video port.
1helpful
2answers
IBM ThinkPad T40 2373 Notebook Logo
Top IBM Computers & Internet Experts
Ekse
Mehandi Husain ...
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
