Question about Canon CanoScan LiDe110
Release the lock switch code 2,179,10 in Canon Canoscan LiDe110 ?
Posted by Anand Shastri on
nabil
    New Friend:
Hi my printer this problem.
release the lock switch detach the usb cable and reconnect. scanner driver will be closed code: 2,179,10
Posted on Aug 23, 2018
1 Related Answer
upbeatjunk
Tim Levesque
  • 231 Answers
SOURCE: Canon LiDE 110 gets error code "release the lock
Unfortunately if the scanner is unlocked and you have reinstalled the software with no luck, then the scanner is defective.
If your scanner is still under warranty you can get a free repair or replacement form Canon...your best bet would be to contact them via one of the methods listed here:
http://usa.canon.com/cusa/consumer/standard_display/contact_us_consumer
The LIDE scanners are nice, I understand your frustration.
I hope this helps! If this did help you, please give a thumbs up!
Thank you for choosing FixYa!
Posted on Jul 24, 2011
If I do the scan, the scanner is warming up for about 10 minutes. after that it said internal error occured. Scanner driver will be closed. Code : 3,202,19
try to uninstall the driver then install it again
note:
1-after you uninstall make restart for computer.
2-don`t connect the scanner USB until the driver installer required this.
Mar 17, 2016 | Canon CanoScan LiDe110
How can unlock switch error code: 2,179,16
you have to run wire from you main router to the switch and put it in the in port. then you can plug in your computers from there. now if you have anew er one and it is wire less you still will hav to run a wire to the router. unless you get a repeter then all you have to do is log onto your routher and then use it like your main router
Apr 13, 2015 | Canon CanoScan LiDe110
I have problem with my canon Scanner 110 lide
Disconnect the USB (which is the power source) and install the driver. Then reconnect the USB. The driver should be detected automatically. Go into "Device Manager" to check.
Jan 01, 2015 | Canon CanoScan LiDe110
I cannot scan with my scanner: " it says RELEASE THE LOCK SWITCH,DETACH THE USB CABLE
Hi ,
Disconnect your unit from your pc ( usb and power)
Insert your install cd and run the program
Restart your pc
When Windows has settled , connect scanner back to pc .
It should run normaly .
Best regards.
Aug 15, 2014 | Canon CanoScan LiDe110
Canoscan Lide 110 driver
Perhaps you have forgotten to unplug the scanner before
scanning? That's what happened to me. I kept getting
different error codes, 5,202,63 or 5,202,52 or 5,202,54 and
also a message that the driver was not in the TWAIN folder.
According to the help file the problem might have been due
to my nfts file system. I also tried downloading various
new drivers. Nothing helped until I noticed that I had not
unplugged the scanner!
Jun 27, 2012 | Canon CanoScan LiDE110 Flatbed Scanner Inc...
I have no driver in canoscan lide 110, I wanted to download this driver but i dont know how
Hi! Welcome to FixYa,
You may download the driver for Canoscan Lide 110 by clicking this link: http://files.canon-europe.com/files/soft40595/software/sd68-win-lide110-17_0_2-ea24.exe after that. it will prompt you to download the driver, just download it and install. Evertying will be self-explanatory.
Thanks have a great day!
Jun 19, 2011 | Computers & Internet
It says to release the lock switch. Where is the
Look on the bottom of the unit for a sliding switch that shows an icon of an open padlock on one side, and a locked padlock on the other.
Feb 19, 2010 | Canon CanoScan LiDE 70 Flatbed Scanner
Canon CanoScan LiDe110 Logo
3,140 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
Ekse
