Didn't give a model number, but try the following:
For a mechanical clock, push the center knob in and turn the clock hands to the correct time. (If the Minute Timer pointer should move also, let the knob out, turn the Timer pointer to OFF.)
For a digital clock, push in the center knob of the Minute Timer and turn Knob in either direction to set the Digital Clock numerals to the correct time.
For an electronic clock, touch the Clock pad. Touch the number pad. Touch the start pad until the time of day shows in the display. Note: On double wall ovens, you can only set the Timer for one oven.
(From the GE website)
Check the oven to ensure that it is off and that the timer isn't running. The buttons used to set the clock are the same buttons that adjust the oven, and you may end up making unintended adjustments to the oven.
Press the "Clock" button to enter the clock setting mode. The LCD will show the current time set on the oven.
Use the "Set Temp/Time +" or "Set Temp/Time -" buttons to adjust the clock to the current time. Depending on your model of stove you may need to use the "Hour," "Min" or the "Temp/Hour" up and down arrow buttons to set the time.
Save the new clock setting by pressing the "Start" button. Depending on your stove model, you may need to press the "Clock" button a second time if the "Start" button does not work.
