Hi Teresa, Im AL the owner of Big As Auto Repair.
Teresa, sense I'm not sure if you have a "Touch Screen Radio" OR a "Regular Radio" I'll tell you how it's done on both style's.
FIRST THE TOUCH SCREEN: Simply touch the time. Example: let say it's 12:00 O'clock, simply touch the 12:00 and it will open the time set and adjust the time.
REGULAR RADIO: Touch and hold the "TIME" which is next to the disk opening that you slide your CD into. By holding the time it will cause the time to start flashing, while it's flashing simply turn the knob that says 'PUSH AUDIO / SELECT" this will adjust the HOURS, should you need to adjust minutes simply push the knob and it will switch to minutes for adjustment.
Hope this helps and please visit my auto-repair-website at: http://www.bigasautorepair.com/
SOURCE: Jack Location for Tire Change
under the back seats, jack is under the driver's side backseat, tire iron & rods are under passenger's side backseat.
SOURCE: 2004 Jeep Grand Cherokee - problem with power windows/locks
This seems to be the affects of a bad dinamo charging your battery . If you take a appart the dinamo you should fine a part called in mechanic terms "the bones" they look like 2 black magnets with a wire coming out of them . They are not expencive and you should not change your dinamo untill you try this first a car dinamo is very expencive .
SOURCE: Eject navigation disk in 2005 Jeep Grand Cherokee
Under the cd slot you will see a long thin rectangle that can be gently pryed out with a knife tip on the right side of the rectangle. under that cover there is a small button. push that and out comes the nav disc. Voila solved
SOURCE: how to change fog light bulb on 2004 jeep grand cherokee
There's a small space behind inside fender. You can get your hand in there to grab and twist the back of the bulb to release it. You need a flashlight.
SOURCE: windows and lock wont operate on a 2004 Jeep Grand Cherokee
I just had the same with mine, pull the rubber boot back on the drivers side front door and look for a severed wire, mine was black...simply spliced the wires back together and problem solved!
