4 burner Dacor stove top.no model # on this one.
Ask your question at this website.
http://www.appliancepartspros.com/questions-for-dacor-spark-module-86527-ap3395928-page2.html
SOURCE: Stove burner igniter does not work.
Your problem is not the igniter itself, but the burner switch that controls the igniter. All the igniters get their power from one spark module that is mounted somewhere in back of the oven. That's why you are able to get all the igniters to spark with only one burner control turned on. This is normal. That is also why you are able to light the burner in question buy turning on another burner. The spark is being provided by a switch that is working. To answer your question: the igniter is removable, but I don't think it's necessary. Cleaning them generally doesn't make them work better. I would check the wiring from the spark module to the burner switch and/or replace the switch. I hope this helps.
SOURCE: Kenmore Gas Range - burners won't ignite
its possible your gas regulator is bad or the gas line to the ignitor is stopped up look at the line and see if some type of food has blocked the outlet
SOURCE: stove top burners not igniting
I would check that the range is plugged in first and that any fuse in the range itself has not blown. Fuse in the stove should be near where the electric line from the wall plug goes into the back of the range. Just follow it down to where it plugs into the range itself.
If all those are fine, check the little wires from the igniters all the way to where they plug into some connector. But unless you had a really busy mouse I dont see that happening to all the wires from each igniter. good luck
SOURCE: Maytag MGR6775 Gas stove. One igniter not working.
Clean the burner with a wire brush around where the ignitor is. it needs a proper ground to ignite. When you turn the burner on do you hear a click click click? If so this should solve the problem.
