Question about GE Freezers
GE Refrigerator PSS26MSRDSS - loud fan / buzzing noise. Still cooling, but display for setting temperature is blank.
Pressing a button on the temperature display will make it briefly flash 0. Slight frost on inside of freezer.
Posted by Brad Bowski on
5 Related Answers
fridgetech
Craig Shelton
  • 473 Answers
SOURCE: Kenmore® (46-26072) Elite® 20.6-Cu. Ft. Frost-Free White Upright Freezer
Check these two things first.  1.  Is there a thick frost buildup on the back panel at the bottom half of the freezer?  2.  Do you hear the fan running inside the freezer?  Let me know what you find.
Posted on Oct 12, 2007
Jose Ramirez
  • 263 Answers
SOURCE: FREEZER SOUNDS VERY NOISY
that because the internal fan is hiting the ice or has bad bushings you can hear the noise just with the door close because when you open the door there is a switch the one turns off the internal fan so when you close the door it turn on the fan again if you wants to hear that with the door open just open the door and push the botton swich with your fingers and you'll hear the noise
Posted on Dec 29, 2007
Anonymous
  • 184 Answers
SOURCE: Loud buzzing noise
IF YOUR FREEZER HAS A TEMP ALARM, USUALLY LOCATED IN FRONT,BOTTOM, RIGHT CORNER, THE TEMP IS PROBABLY ABOVE THE SAFE TEMP FOR FREEZERS, (10 DEGREES) AND SO THE ALARM WILL SOUND.
THERE SHOULD BE A SWITCH IN FRONT TO SHUT OFF THE ALARM UNTIL THE TEMP GETS BACK DOWN TO ZERO. THEN YOU CAN TURN THE ALARM BACK ON.
IF YOU PLUG IN THE FREEZER AND TURN IT ON, IT SHOULD BE BACK DOWN TO NORMAL TEMP (IF IT IS EMPTY) IN ABOUT 24 HOURS. IF IT ISN'T, YOU HAVE OTHER PROBLEMS. CHECK TO BE SURE THE COMPRESSOR IS RUNNING.
Posted on Apr 05, 2008
duby1990
Justin Duby
  • 370 Answers
SOURCE: ice/frost build up inside the freezer
You have a defrost problem. The coils freeze up behind the freezer wall and the air does not flow properly. Replace the heater, defrost timer, and thermostat. get me the model number and i will give you the part numbers so you can order the parts.
Posted on Nov 19, 2008
Raz Mataz
  • 389 Answers
SOURCE: whirlpool upright freezer evl209nbtq making noise
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Posted on Apr 21, 2010
Setting the controls
These are computer run items now. If you unplug it for 2 or 3 minutes does it reset itself? If not try pressing refrigerator an ice buttons together. If that does not work the evaporator fan or control panel needs to be replaced. That about all one can do these days other than keeping the air ways clean so fan is clear. But ecen that will not stop these voltage spikes on the line from ruining good appliances.
Jan 29, 2015 | Kenmore 27.6 cu. ft. French-Door...
My Samsung Refrigerator is making a noise that sounds like an old style door bell. It a loud buzz that occurs several times a day. Do you have any ideas?
User manual and parts list and diagrams.
SAMSUNG Refrigerator Parts Model RF217ACPN XAA
Your refrigerator has at least three motors with fans in addition to the compressor motor. The one most suspect is the one that passes air from the freezer to the refrigerator.
samsung refrigerator noise YouTube
Oct 19, 2014 | Samsung RF217ACPN - 20 cu. ft. French Door...
Freezer alarm
Hi Clair, thank you for allowing me to assist you.
When the refrigerator is beeping or buzzing, it may be a warning sign of a possible malfunction or an unsafe, interior temperature. To silence the buzzer, you can depress the ALARM OFF button. However, if you have already done this, try unplugging the unit or flipping the household circuit breaker for about ten minutes.
If the alarm continues, it could possibly be experiencing a communication problem with the temperature control/board or wiring failure. I would recommend connecting with a professional appliance tech for a clear-cut diagnosis.
Sep 06, 2013 | Electrolux Freezers
Display ligts up.Compressor not running!
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 13, 2011 | GE FUF17SVRWW Upright Freezer
My freezer clicks (I guess it's trying to do something because the ceiling lights dim a little or brighten when this happens, so I think it's going on or off), but there is no fan noise, and the freezer is...
Refrigerator
heatman101
Jan 17, 2011 | Whirlpool 11.8 cu. ft. / 334 liter Upright...
I have a kenmore upright frost free freezer mod #253.26432100. A couple of months ago everything defrosted and the unit was not running at all. I unplugged it cleaned it and plugged it back in, it turned...
You have a problem with the ADC.
Frigidaire has also jumped into the market with an adaptive defrost board. The fresh food section light switch and light bulb must work. To initiate a defrost cycle, open the door and push the light switch in and out 5 times within 6 seconds. The compressor and fans should shut off and the defrost heater should come on. Open the door and push the light switch in and out 5 times within 6 seconds to remove the refrigerator from the defrost mode and back into a cooling mode.
This product comes equipped with an Adaptive Defrost Control (ADC). To activate manual defrost, press and hold the Freezer temperature UP (WARMER) key while pressing the Fresh Food temperature DOWN (COLDER) key 5 times within 6 seconds. A "d" in the freezer temperature window and "F" in the refrigerator temperature window will display when the heater is activated. To deactivate manual defrost, press and hold Freezer temperature UP (WARMER) key while pressing the Fresh Food temperature DOWN (COLDER) key 5 times within 6 seconds. "d" and "F" will be displayed until the defrost cycle is complete. (approx. 8 minutes)
Nov 23, 2010 | Frigidaire 20.3 cu. ft. / 575 liter...
I need to learn how to control the tempature setting
The temperature controls are located at the top front of the refrigerator or freezer compartments.
The recommended setting should be correct for normal household refrigerator use. The controls are correctly set when milk or juice is as cold as you like and when ice cream is firm.
Wait 24 hours for your refrigerator to completely cool before adding food. If you add food before the refrigerator has completely cooled, your food may spoil.
NOTE: Adjusting the refrigerator and freezer temperature controls to a colder-than-recommended setting will not cool the compartments any faster.
If the temperature is too warm or too cold in the refrigerator or freezer, first check the air vents to be sure they are not blocked before adjusting the controls.
To turn Off/On:
Style 1 Press the freezer down arrow touch pad until a dash (-) appears in both the refrigerator and freezer displays. Neither compartment will cool.
Style 2 Turn the freezer control to the word Off. Neither compartment will cool when the freezer is set to Off.
Energy Saver option (on some models)
The Energy Saver option turns off the heater which helps to reduce moisture on the door hinge seal. The refrigerator uses more energy when Energy Saver is off.
Press the control to On to save energy when the environment is less humid.
Press the control to Off when the environment is warm and more humid, or if you notice moisture on the door hinge seal.
Adjusting controls
If you need to adjust the temperature in either the refrigerator or freezer compartment.
NOTES:
For Style 1 control, press the up and down arrow touch pads; for Style 2 controls, turn the dial to adjust the temperature.
Except when starting the refrigerator, do not adjust either control more than one setting at a time.
Wait 24 hours between adjustments for the temperature to stabilize.
Hope this guideline will helpout.....
Aug 10, 2010 | Traulsen Reach in Freezer - G22010
BUZZES
This sounds like the temperature monitor is alarming because the temperature has not cooled down enough yet in your freezer. turn the monitor off until the freezer reaches proper temperature then you can turn it back on.
Jul 20, 2010 | GE 14.8 cu. ft. / 419 liter Chest Freezer...
My maytag Wide by Side refrigerator started making this buzzing noise coming from the freezer section every few minutes and now it no longer cools.
It is possible that the door was not closed tighly, so the humidity built up in the duct line and the low temperature from the freezer make it turned into ice causing the clogging. The Buzzing noise turns on due to the sensorsomewhre along the disigne path. Unplug the fridge for a day and a half so the the ice in the duct line could melt down then when you turn on the sensor won't turn on the buzzing any more. Good luck.
Jul 04, 2009 | Maytag Freezers
Dec 29, 2007 | Freezers
Freezers Logo
145 people viewed this question
Top GE Freezers Experts
Muntejaya Ginting
Muntejaya Ginting
John Tripp
John Tripp
Are you a GE Freezer Expert? Answer questions, earn points and help others
