Parts for your riding mower (except engine) should be available through
www.searspartsdirect.com for at least 10 years from date of mfg and sometimes as long as 30 years. When you go to the website, you will need the tractors model number. It is located on a sticker on top of the rear fender assembly. Raise the seat to see it. It probably looks something like 917.385880 . The engine parts are available through sears or through other online sources such as
www.partstree.com or
www.milacalawn.com . For engine parts, you will need the model and serial numbers from the engine. These numbers are usually located on a metal plate that is riveted to the upper shroud, or on a sticker on the side of the upper shroud. Find a local mower repair shop, they will also have access to these parts for you. Your local shop will usually be alittle higher in price, but will offer installation advice that is priceless.
