Washing Machines Logo
Rhonda James Payne Posted on Nov 05, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What causes door to open during cycle
Door pops open during wash cycle nut not every time we use it. It has happened twice in two months
Marvin
Level 3:
Top Expert:
  • Washing Mach... Master 85,242 Answers
  • Posted on Nov 05, 2016
Marvin
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29059531
Points
266281
The door has an electrically actuated door lock/latch. it must be defective or hanging up at times.
Testimonial: "Is that something that we can replace ourselves?"
Mohamed Basith
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 22, 2017
Mohamed Basith
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1694
Points
og Youtube
og youtube
youcam makeup
Russell utakate
Level 1:
New Friend:
  • Posted on Dec 07, 2016
Russell utakate
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1694
Points
The door has a auto system that helps it open
2answers
Why does the door pops open when starting
I would check how level the dishwasher is. Might need to adjust the feet.
The door on my Hotpoint Aquarius Dryer CTD00 pops open during cycle is it the door catch that's worn?
If the door latches correctly at the time of wash then it is possible that there is a false trigger to release the door, if so you need to check on the lock.
check on this link for tips: Door lock
I was washing beach towels and during the rinse/spin cycle the door popped open on my whirlpool duet ht (model GHW9400PL4). I haven't been able to close the door since it opened before the cycle was...
those have a 2 latch system, sounds like the second latch that engages during the spin cycle never quite completed the safety lock , you could try and jumper the latch to see if that would release it, But it seems the secondary latch wasn't working properly in the first place, even the heaviest loads shouldn't pop the door open,
2answers
I have a GE Hydroheater washing machine. For the past few months I have had to restart it atleast once or twice during a wash cycle because it would stop in the middle of a cycle for no apparant...
try locking your settings by pressing your locking button for 3 or 4 secs till the red lock shows.and see what happens..it might work..good luck
KitchenAid KUDSO1FLSS5 - door pops open
I am an experienced techician and have tried all these solutions in the past sometimes at no avail. But replacing the tub which has a limited lifetime warranty along with hinge arms will solve the issue. This has such a margional clearance I can never see anything visible causing the door to pop open
1helpful
3answers
The dishwasher door keeps popping open
I have the same problem and it appears that everyone else who has replaced the door seal runs in top this issue. This is a new seal design that is different from the original. This new seal is obviously poorly designed is placing too much pressure on the door causing it to either not close, or open mid cycle. I am presently duck taping the door closed when running the machine in the hope that the heat cycling the new seal will eventually cause it to deform and relieve the pressure. I see that other have attempted to help the process by increasing the release pressure on the latch. This will be the last Kitchenaid large appliance I purchase.
Door popped open and now is locked and will not unlock
Sometimes unplugging it for a few minutes will cause it to reset itself. Also, if that doesn't work, when the power is back on, try pressing and holding the power switch for about 30 seconds.
2helpful
this is joyce
What I would do in this situation is fix the door lock first before I would do another load of clothes. you can go to Kenmore.com put in your model # and download your manual to your machine if you want to fix yourself
or you can call service tech out. I will help you find one in your area if you need.
thanks,
joyce
Whirlpool Washing Machine Quitting during rinse cycle
I would say that based on your problem description that the lid /door switch has a loose or faulty contact .. If you open and close it a few times..it starts to spin and yet when you open it.. it doesn't always stop the spinning.. It is either the switch or the actuator that bumps that switch.. That is where I would begin diagnosing the problem... Hope that helps..
Top Washing Machines Experts
john h
