Kitchen Ranges Logo
c
carl johnson Posted on Nov 04, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need the Thermal fuze location for my Frigidare Model FEF366AWD Stove
Marvin
Level 3:
Top Expert:
  • Frigidare Master 85,242 Answers
  • Posted on Nov 04, 2016
Marvin
Frigidare Master
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29056660
Points
266281
4answers
Where are the fuses located in a frigidare stove
Good Afternoon Friend, this is Z. Thank you for your post!
I understand you are seeking the fuses location in your Frigidaire range. May I please have your model number? You can typically locate the serial tag (which lists your model number) in the storage drawer, on the right side. Please describe what your appliance is doing so that I can assist you better in pinpointing the problem before you take this step. Thanks!
Where is the control board plug on frigidare stove
Hello meikle1961 - Do you have exact model number to the unit? Are you speaking about a gas or electric range? Reason I ask is because depending on the model number, there are various controls on some ranges. With this information I can assist you better in pinpointing you the part location.
I have a frigidare electric stove. The oven got
Hi
Thanks for using FixYa. Error code F1 means a bad Electronic Range control (ERC) and to resolve this issue you’ll have to replace the Electronic range control (ERC). Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
1helpful
Dryer wont turn back on.
Hi!! Relax your thermal fuze has shorted out..replace your thermal fuze and all is fine..Good luck..the fuze is located by the motor blower inside the machine its white oval around 2 inches and has 2 wire leads to it good luckk.
1helpful
Kenmore gas dryer won't start.
Hi!!1 You have a shorted thermal fuze on the dryer..The thermal fuze is located in the back of the dryer its white and oval with 2 wire leads..replace it and you should be fine..good luck..
Need to replace knobs on Frigidare stove model #FGF316ASB
Go to searspartdirect.com. Type in your COMPLETE model number and use the part locator illustrations on the following page. There should be a complete listing of part numbers for you to order on line. They should be listed under the "Backguard" heading as items number 32 and 36. Part numbers 316102303 and 316009009, respectively. I hope this helps you.
No power to the oven, is breaker external or somewhere on the oven?
Go to your breaker box or fuze box and look for a dual circuit breaker It should be labeled stove. Turn the breaker off If a fuze box there usually is a black plastic fuze holder labeled stove pull it out. Confirm at the stove a lack of power.
Top Frigidare Kitchen Ranges Experts
Paul Carew
john h
ADMIN Andrew
ADMIN Andrew
Are you a Frigidare Kitchen Range Expert? Answer questions, earn points and help others
