Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348 Logo
Serapio Garza Posted on Nov 04, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hursqvarna yth2348 lawn tractor front alignment with no visible damage needs toe in. How do i do it?
One of the front wheels is turned outward and the tire keeps falling off. I dont see any damage to linkage nor anywhere to make adjustments.
tanawah
Level 2:
  • Expert 50 Answers
  • Posted on Nov 04, 2016
tanawah
Expert
Level 2:
Answers
50
Questions
0
Helped
10547
Points
120
Some of those are adjusted by bending the tie rod.
2answers
GOING BACKWORDS THE WHEELS TOE IN, GOING FRONTWORDS ONE WHEEL TURNS 90 DEGREES THE OTHER STAYS STRAIGHT AHEAD
You most likely have a broken tie-rod. (A part of your suspension. ) Don't try to drive it...it will not steer. It will have to be repaired.
May 01, 2016 • Mtd Garden
What causes the front wheels to spread out making turning and steering impossible on a husqvarna lawn tractor.
the tie rod between the two wheels has broken or come off
the steering rod works on that rod or on one wheel which is connected to the other wheel by that tie rod.
Poulan lawn tractor steering problem
streeting on poulan rider drops down you have to pull up on it to street it how to fix this mower is a yr old
My front wheels one is straight the other is turned out
Check your front axle the solid piece that goes from one front wheel to the other and attaches the front spindles and wheels. Your probably going to find the solid axle (which also goes underneath the front of the tractor) has been bent allowing that wheel to turn outward.
3helpful
2answers
The front wheels toe out about an equal amount and ther doesn't appear to be a way to adjust the toe in. The steel steering rodsdo not have adjusters. Any help would be appreciated.
I have the same problem on my YTH2348. I changed both linkage rods and still have the problem. Not sure what is going on. I don't think it is the axle as these are cast iron and would take alot to bend it. Anybody have a clue what I could do to fix it!!!
My lawn tractor pulls to the right when driving can i fix this?
The Toe In/Toe Out will have to be adjusted (if the steering rods to each front wheel have sleeves), just like on a car.
Toe-in is the operating angle of front wheels on a riding tractor. If the front edge of the wheels point inward, towards each other, then the wheels have toe-in. If the front wheels point outward, the unit has toe-out (or negative toe-in). Adjustment of toe-in is necessary to maintain proper steering control.
Unlike automobiles, our tractors have pre-set camber and caster settings. Therefore no camber or caster adjustment is necessary.
Acceptable toe-in adjustment range for all of our lawn & garden tractors is anywhere between 1/16"-5/16". With 1/8" serving as the optimal range.
Detailed toe-in adjustment procedures for the various models of tractors are reviewed in the "Adjustments" section of the Operators Manual for the tractor.
If tires are not toed-in properly after adjustment, it is likely that other part(s) need service or adjustment. axles, wheel bushings, control arms and other steering components may be worn or damaged and will need inspection. Service these items as needed.
You haven't stated your make and model, so I can't send you the manual with the exact procedure for your machine.
Jun 12, 2011 • Garden
2helpful
How do you fix the front wheel alignment on a 48 inch lawn tractor by Craftman. The wheels are turned to the outside. Theres no bent rods or anything. Whenthe wheels go one way in the frony. you mow the...
make sure tie rod between wheels is straight. if bent will cause wheels to turn outward. take tie rod loose at each wheel, straighten rod reinstall wheels should be straight.
Craftsman riding lawn mower wheel toe needs adjustment.
put it in reverse ton the wheel to the right and hit the wall again....or ir you were backing up when u hit the wall runn into foward
Top Husqvarna Garden Experts
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Thomas Perkins
Thomas Perkins
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
