My Gaggia Titanium machine has a problem. It drips coffee very slow. I thought, oh, I would just clean the Brewing Unit, and I did. I have cleaned the Brewing Unit, all the pluming including that shower screen. Still no luck. Then I tired to use bypass doser with ground coffee, it works great, no issue with it. So that means, issue is not with the brewing unit. I looked in to the grinder, it seems to be grinding only a fine mode, disassembled whole grinder unit, cleaned all the coffee out of it, cleaned upper grinder and lower grind mills. Calibrated the gear grind adjustment, but it produces very fine ground coffee only which gets clogged when it is brewed. I have tried different coffee types, tried to pick not greasy coffee, it doesn't help. It only works through Bypass Doser. Please help me understand what is the problem.
SOURCE: I have a GAGGIA SYNCRONY DIGITAL COFFEE MACHINE,
The grind is set too fine adjust to a coarser grind.
SOURCE: why does it now stop at prebrewing and not give me
Hi
Try reprogramming the machine. Push and hold the button for the coffee you want, but hold it all the way through the process. Don't release the button until you get the amount of coffee you want for that button, then release the button. That should get you the same amount next time. You can do this for each coffee button. If that didn't fix it you might have a bad flow meter
