Question about Panasonic Televison & Video
Panasonic 42PX600 plasma TV switching channels
Our plasma tv has started switching to TV/AV by itself. If we use the terrestrial channels it will after a short period of time switch to TV/AV. Unfortunately, it will attempt to switch again even though we are already on TV/AV. So the screen keeps going blank then carrying on where it left off (very annoying).
Keano
Posted by keanonwuk on
5 Related Answers
Anonymous
SOURCE: Problem starting a plasma
I have the same plasma TV and had the same problem. The problem is three caps. Change the cap 2663, 2664 both 100µ/25V and 2662,1000µ/25V. After you have changed them your TV will work again.
Posted on Apr 02, 2007
Anonymous
SOURCE: plasma TV with vertical lines
Help! My Plasma by Magnavox is putting black verticle lines on the right side of the screen - comes and goes - and I replaced the entire Direct TV-HD unit - wires, everything - and had TV company repair - and it still came back. The TV repair refuses to take TV back because it does not show up when they come. Although I videotaped it and showed them which has the date and time - they still refused to take it - and tried to get me to sign a paper saying it was working while they were there - which of course I refused to sign - so they left and nastily said they will not be back-find someone else. I still have the lines - and do not know what to do! Can anyone help?
Posted on Aug 21, 2008
Anonymous
SOURCE: Panasonic Viera TH-42PV7HS Plasma keeps shutting down
Hi to all, My 42" Panasonic plasma have the same problem. It turned itself off and now red light flashes 7 times, than after short pause 7 times again. And so on. Any ideas what is wrong??
Posted on Oct 23, 2008
Anonymous
  • 5 Answers
SOURCE: 19'' Dynex TV does not come up as a Computer Monitor.
I had this same problem with the 19" model as well. I had to reinstall video driver with the tv hooked up in order for the resolutions to work properly. In order to do this I used an S-video cable which worked well enough to reinstall the video driver. I did not try safe mode which might have been easier, I just did not think of it at the time. With the video driver reinstalled while the TV is attached to my computer, I know enjoy a crisp 1440x900 screen resolution. Hope this helps.
Posted on Jan 06, 2009
Anonymous
  • 27 Answers
SOURCE: Sky remote wont control on/off , volume, or terrestrial channels
Press tv on the Sky remote
press and hold select and red until the led blinks twice
type in 0 0 6 0
press the power button, if the tv turns off then the press select and the remote should work all the tv functions.
If the tv does not turn off then press tv then the power button and keep doing this until the tv turns off, once it turns off press select and it should work.
If you have any problems let me know
Dazz
Posted on Apr 04, 2009
My Panasonic plasma tv is stuck on one channel. The remote has new batteries but only works for the volume. I tried changing channels on the set itself and now the screen is black
If the screen is still on but is black, try changing the channel on the set itself back to the channel it was originally on. If you can provide me with the model name of the TV (usually somewhere on the back of the TV), I might be able to find out how to re-set up your remote with it.
Dec 13, 2016 | Panasonic Televison & Video
I am trying to use a Panasonic Showstopper DVR
It records on one channel only, not a tuner itself...........
May 24, 2010 | Panasonic PV-HS2000 Showstopper 30-Hours...
Panasonic TX P50V10B Plasma TV
In order to get any of the Freesat channels, you need to connect a Satellite dish to your TV. If you have a Sky dish, you simply need to run an extra Cable from the LNB from the dish and connect to your socket on the back of your TV.
In order to get Freeview channels and Analogue channels, you need to connect a aerial to the back of the TV.
There is a menu option for the TV to start straight to the AV input (your Sky HD box). It is Menu > Setup > Other Settings > Power on Preference. Select 'AV' for your TV to start on Sky HD.
Also even if you have your TV to start on TV, when you turn on your Sky HD box, it should automatically switch to the Sky box.
Oct 28, 2009 | Panasonic Televison & Video
Panasonic plasma won't change channel or volume
Also had the same problem with our Panasonic 50" Plasma...could not change the channel or the volume (with the remote control nor with the actual TV controls). Before I called for repair, I UNPLUGGED the TV and then plugged it back after a minute. I was surprised....the TV started working again. (Switching the TV on and off is not sufficient). I could change channels and volume, etc. So this saved me a repair this time. Might be worth trying this solution. Wouldn't hurt one bit, but rather save you a repair fee.
Aug 26, 2009 | Televison & Video
Installing a receiver
plug the receiver directly to the tv first without the panasonic. set up the receiver . then add the panasonic. the panasonic probably doesnt have a digital tuner so use composite av cables (yellow, red, white) from the reciever to the player
Dec 30, 2008 | Samsung HDTV Digital Terrestrial Receiver
Finding AV channel to connect DVD to TV
first check if you are plugged in the right place,(you're tv as 2 a/v inputs).then you should be able to acces a/v by the menu button on you're remote,or even on the t.v. itself.well good luck then buddy,hope this helps.. btw,are you plugged in a/v (yellow,white,red) style,s-video(1cable)style,componentstyle(green,blue,red).check that out man!
Nov 16, 2008 | Sanyo DP42746 42 in. Plasma Television
Panasonic 50 inch Plasma
it could have over heated you can try to reset it first unplug it for about five minutes and try to turn it on if that dont work the remote might have a set button try holding that down until the red light flashes twice, then turn it on if not then hold the power button down on the set for a good five seconds to see if that resets it. if none of that works you will have to go to panasonic .com for the reset instructions.with the red light blinking the power supply is most likely good you just need to reset i.
Dec 24, 2007 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Televison & Video Logo
65 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Muntejaya Ginting
Muntejaya Ginting
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
