Question about Kyocera Cameras
Kyocera finecam S3 error C2 - Kyocera Cameras
Posted by Alan Exelby on
5 Related Answers
Anonymous
SOURCE: Kyocera finecam S3R not working
Hi. I have exactly the same problem after owning this "camera" for under two years. Happened aftrer only 16mths.I also bought another battery(which I willl take back for a refund). The only solution that has been offered to me came from the supplier who said to buy ANOTHER one. Nice for them!!!!
Posted on Nov 21, 2006
Anonymous
  • 123 Answers
SOURCE: Where do I get a
http://www.batteryvalues.com/Kyocera-finecam_l3v-digital_camera-batteries-product-ch9700.aspx
You can buy one here.
Good Luck.
Posted on Apr 09, 2008
Anonymous
SOURCE: kyocera finecam
The camera has several ribbon cables inside, all of which disconnect in different ways! Which cables and why??
Posted on Oct 06, 2008
Anonymous
  • 180 Answers
SOURCE: Kyocera finecam 410 "cover open"
i had a camera that did the same thing. on mine there was a little tab on the memory card cover door thing that pushed a little button. i think a piece of the little tab on mine broke off so it wasnt pushing the button so i took a little piece of paper or something and folded it really small and set it on top of the little button thing and then closed the door and that worked for me
Posted on Feb 19, 2009
Ty Price
  • 11967 Answers
SOURCE: I have just bought a 8GB Panasonic memory chip for
The brand isn't important. The 8GB card is an SDHC(secure digital high capacity) card and the smaller one is an SD. Your camera may not be able to use an SDHC card. Try formatting it in the camera before giving up on it.
Posted on Feb 14, 2010
Although this camera will work when plugged into the mains and functions normally, it will not work off its battery - I have bought a new batttery and the camera does not seem to be able to charge it -...
The problem is clearly in the charging circuits of the adapter, the only other thing is check the connecting pins on the adapter, "by cleaning the points" if this fails, the unit will need to be dis-assembled for repair or replaced.
Mar 22, 2011 | Kyocera Finecam S3 Digital Camera
Is it possible to charge the batteries for a digital camera using the usb cable while the batteries are in the camera?
Some of the more recent digital cameras can indeed be charged using power supplied by a computer through the usb cable.
Your camera came with a battery that can only be charged using the included external charger and power cord.
You should be able to find a replacement charger on some of the more popular auction sites such as ebay.
Sep 23, 2010 | Kyocera Finecam S3 Digital Camera
I have just bought a 8GB Panasonic memory chip for my Kyocera Finecam M410R camera. But it comes up with card error on it. I put back my little old 124mg card and it is fine. Can I use a panasonic card...
Feb 14, 2010 | Kyocera Finecam M410R Digital Camera
Help ons aan een nederlandse gebruiksaanwijzing van de KYOCERA
we hebben inmiddels een gebruiksaanwijzing gevonden,zodat onze vraag gewist kan worden.
gerard en willeke
Dec 26, 2009 | Kyocera Finecam M410R Digital Camera
Feb 19, 2009 | Kyocera Finecam M400R Digital Camera
Kyocera finecam
Dec 18, 2007 | Kyocera Finecam M410R Digital Camera
Problem in the camera
The Kyocera web site tech support, will have that information Manually pulling and pushing a stuck zoom lens will run it, It is a very delicate mechanism, and there will be no service option if it is broken.
Jul 03, 2007 | Kyocera Finecam S4 Digital Camera
May 09, 2006 | Kyocera Finecam S3L Digital Camera
Cameras Logo
Top Kyocera Cameras Experts
Harrie
ADMIN Canada
ADMIN Canada
Are you a Kyocera Camera Expert? Answer questions, earn points and help others
