Question about Bunn Coffee Makers & Espresso Machines
Lid is broken on my grxb bunn coffee maker can I purchase a new lid
Posted by Cheryl Bain on
Tom Chichester
    Top Expert:
  • Bunn Master
  • 57,296 Answers
Fixya does not sell replacement Bunn lids. Check with a local appliance parts supplier.
Posted on Nov 03, 2016
3 Related Answers
Anonymous
  • 136 Answers
SOURCE: Bunn coffee maker
Is the burner hot while your pouring water in?
Posted on Sep 15, 2007
atbsmmom
  • 189 Answers
SOURCE: The lid to the coffee
We will be happy to replace that lid free of charge for you. Please call customer service at 800-352-2866 and we will send you one out.
Posted on Jan 18, 2011
Bill Price
SOURCE: We have a bunn grxb coffee maker new. the coffee
if you are using a frine grind, try using a coarser grind
Posted on Dec 26, 2012
Is there a gasket between the filling tank and the lid of the tank
Yes. It's a tank gasket that can be purchased from www.bunn.com. You'll have to remove the trough above the tank, wires, fuse, temperature probe, water inlet, hot water output tube, and 8 nuts to get to it.
May 03, 2015 | Bunn Coffee Makers & Espresso Machines
The lid to the coffee pot itself is broken .. bunn model GRX-B - can I buy a new lid?
Dec 29, 2010 | Bunn GRX-B
How do we use the Bunn ..... it was given to us with no manual
The water is poured into the top lid and then swivel the lid closed. The brewed coffee will come out of the bottom of the funnel basket into the glass decanter.
Jun 09, 2010 | Bunn NHB Coffee Maker
Bunn coffee maker leaks all over the counter. What
there's probably a 'silicon rubber' hose that feeds hot water to the 'grounds basket'- it may be loose, or damaged. is it leaking water, or coffee?? we have a bunn 8-cup, which has a pre-heated water tank that brews a pot in about 3 min. energy waster, but when you need coffee, you need coffee!!! is your filter holder properly centered? is the carafe lid hole clean and un-obstructed?
if it's leaking water, and not too costly to replace- you may consider replacing it with a new one!
good luck!
Oct 09, 2009 | Bunn GRX-B Original 10-Cup Home Coffee...
No manual with Bunn NHBX coffee maker.
before plugging in place your empty filter basket in the coffee maker and place a pot under it. Slowly pour in two pots of water using the pour pitcher. Now you can plug it in. it'll take 15 min to heat up first time . when you brew your first pot leave your water level a little short,because the water will expand (only the first time)
May 06, 2009 | Bunn NHBX-B Contemporary 10-Cup Home...
Lid on carafe
Sadly, I have about 10 people who have this coffee maker. It is a wonderful little coffee maker and is very delicate.
the worst problem all the people here say is the lid leaks like a waterfall or it leaks by dripping non stop while pouring.
I had to call Bunn, who made this machine, and they have yet to figure out a solution to this problem other than having people who own this machine buy a whole new carafe with new seals.
You might try your local applianace repair store. Sometimes their engineers are smart guys who knows exactly what seals will work or where to get the parts you need better than the actual manufacter.
May 12, 2008 | Bunn BT10B Coffee Maker
Dripping
Is the burner hot when this occurs?
Sep 14, 2007 | Bunn A10 Coffee Maker
Bunn coffee maker
Sep 14, 2007 | Bunn NHB Coffee Maker
Coffee Makers & Espresso Machines Logo
35 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
gbob59
Marvin
Marvin
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
