Question about Connex Radio Communications
Where to get the display lights for connex 3600hp
Posted by Bobby Byrd on
Will a connex 4600 turbo cb radio operate cool enough in a dash enclosure?
I have CX-4600-T too. Mine gets way hot as well, I had a mod kit installed n it swings 215W peak power now. But the excessive heat is annoying, I think mine does have a fan in it though cause I know I felt air coming out the back before.
May 26, 2014 | Connex 4600 Base CB Radio
Why does the red light for antenna stay on
This means that your swr is high. you can damage the radio using it in this condition, check antenna and coax for damage or misinstallation
Feb 27, 2014 | Connex Cx-3600Hp 3600Hp 10 Meter 100 Watt...
I have a connex cx-3600hp cb and it sounds like it has no power
your power switch it faulty as there is a drop in voltage
does the meters dim down?? then the voltage supply past the power switch it dropping as it draws more current or... the audio ic has damage or one of its associated capactors sometimes a diode can become leeky its used for AM modulation also
Feb 25, 2014 | Connex Cx-3600Hp 3600Hp 10 Meter 100 Watt...
Has low volume with volume all the way up
You've been close to another big radio......you think that was a question but I believe it is the answer. The rf amp transitor or the diodes in that circuit have been damaged. So that stage of amplification is not stepping it up for the next. Resulting in the electrical power converted to air audio by speaker isnt available. Cb shops refer to this as a blow front end. Tr17 is the transistor location .......just a side note some radios have a mic circuit check that dulls audio levels this is not the case here.
I BOUGHT THE CX 3600HP 2 YEARS AGO. IT WOULD STOP WORKING FROM TIME TO TIME AND NOW IT WON'T WORK AT ALL. WHO DO I CONTACT ABOUT SENDING IT BACK FOR REPAIRS
Great Question. I'm not sure if Galaxy would work on a Connex . Copper Electronics has a repair department and would probably fix it for you. I'd offer but I don't have a lot of spare time right now. It's probably the power connection inside of the radio or one of the legs on the main volatage regulator broke loose from the pc bpaurd. That's a common problem with those radios.
Feb 20, 2014 | Connex Cx-3600Hp 3600Hp 10 Meter 100 Watt...
Need more receive
Use a longer antenna or get it higher..
102" whip for mobiles.
maco v 5/8, army big stik, or Bandit for base. or a long beam 5 or 6 element type.
for example..
May 05, 2013 | Connex Cx-3600Hp 3600Hp 10 Meter 100 Watt...
When i turn on my connex 4800 dxl all that lights up is the power meter no chanel display or freq display no sound either
The voltage regulator on the right side of the radio (with the parts side up ) is located in between the 2 side screw holes is ether bad or the legs are broke loose . it is a A1869 transistor.can be replaced with a A473 Transistor . Basically it's the same as a Galaxy Radio ,Ranger makes the boards for (RCI ,Galaxy , Connex , North Star ,Super Star, General Lee .) Hope this Helps.
Oct 31, 2010 | Connex 4800-DXL 480-Channels Base CB Radio
How do you dim display lights on a connex cx 3400 hp
O the front you should have a dim switch its on of 4 up & down switches ? if not check on the back ? was it bought as a new cb or was it 2nd hand as the dimmer switch may of been used for something else
Mar 09, 2010 | Connex 3300 240-Channels Base CB Radio
Radio Communications Logo
109 people viewed this question
Top Connex Radio Communications Experts
Tony Raia
Marvin
Marvin
Are you a Connex Radio Communication Expert? Answer questions, earn points and help others
