SOURCE: Cant get clutch cover off new Husqvarna 235e chain saw
Mine did this when nearly brand new. You likely have a nasty jam of oil and sawdust stuck between the chain brake and the flywheel. It can be loosened by either careful prying of the case or precise shots of carb cleaner up in the housing. While you are in there look for a buildup of oil around the chain brake connection to the kickback paddle.
SOURCE: homelite chainsaw sprocket and clutch for chain
You can get the parts at your local tool rental store.. They should be able to do the service themselves to if you dont want to do it.. Let me know how you make out..
SOURCE: hi how to tune homelite 330 chain saw carby, idle
Before adjusting anything, check the fuel filter, air filter, and muffler for plugging. Check the condition of the fuel lines for decay or other damage. Tighten all carburetor fasteners. Make sure you have fresh fuel mix in the tank. Does the primer bulb pull fresh fuel into itself when pumped? Turn both jet screws CW to stops (lightly), then back out CCW 1-1/2 turns each. This is a basic setting and should allow the engine to start and run. Start the engine and allow it to warm up, then pull the throttle full on. Adjust H needle CW until the engine starts to speed up, but still 4-stroking. Proper final adjustment is when the engine 4-strokes unloaded, but immediately 2-strokes when cutting. Release the throttle and adjust L needle CW for fairly good idle, but still allows the engine to 'follow the throttle'. Adjust idle speed screw so that the chain stops turning, but the engine will continue to run. Hope this helps!
SOURCE: just got a homelite 33cc
Yes you do! The ratio is 50:1 fuel to oil. Be sure to use a modern synthetic saw oil available at home centers, hardware stores, and saw dealers. Be sure to use fresh fuel and mix the two in it's own container. Be sure to shake the container thoroughly each time just before refueling to prevent oil starvation in the engine. Don't make up more than one gallon at a time unless sawing is your business. Hope this helps!
SOURCE: how do I get the brake band ,located inside the
You need to load the brake, clamp it in a vice, be carefull not to damage the cover, if the hand gaurd is connected to the brake pull it fully back until the locks off, this may take a fair amount of force as it is compressing a large spring, if the hand guard is on the machine, remove it and use this as a tool to load the brake, the only other way is to remoce the clutch and sprocket, now refit the brake onto the saw, now pull the hand guard fully back to load the brake.
Press in on the clutch cover lock knob and rotate
counterclockwise until the clutch cover can be
removed. You will see the arrow on the outer cover that will direct you in the right direction.
