Washing Machines Logo
D
DJ Theodoratus Posted on Nov 02, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
MAYTAG NEPTUNE WITH NF SYMBOL
NF SYMBOL APPEARING.
Marvin
Level 3:
Top Expert:
  • Maytag Master 85,242 Answers
  • Posted on Nov 02, 2016
Marvin
Maytag Master
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29055522
Points
266281
NF means no washer fill.(NF) this is not a water valve problem it is control board issue and there is a tech bulletin on it. Contact www.applienceparts.com for more precise assistance in repairing. You can also read about another owner's same problem at this link below. http://forum.appliancepartspros.com/washer-repair/21927-maytag-neptune-nf-code.html
Jerry Pitts
Level 2:
Habit-Forming:
New Friend:
  • Expert 53 Answers
Jerry Pitts
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
53
Questions
Helped
18892
Points
114
Symbol - 'Washer has tried to fill' Check water faucets & hoses for kinks. OR call Maytag 1-800-688-9900. Happy Washing!!!!
NF code may tag neptune front loader!
www.fixya.com > ... > Neptune > Maytag Neptune MAH5500B Front Load Washer
Apr 14, 2009 - CODE IN MAYTAG WASHING MACHINE Hello & Welcome to FixYa NF error in yourMaytag is displayed due to no fill condition, when the washer tries to fill but ... SOLVED: Maytag Neptune MAH6500AWW '03 front ...
Nov 9, 2016
SOLVED: HOW TO FIX NF CODE IN MAYTAG ...
Oct 2, 2011
SOLVED: Machine is flashing nF code
Jul 13, 2011
Maytag Neptune MAH9700 Front Load Washer Nf code ...
Jun 21, 2011
More results from www.fixya.com
1helpful
Maytag Neptune MAH6500AWW '03 front load nf code it is OVERFILLING won't shut off, water pouring out door! new drain pump last week & checked hoses in front 2 days ago. now this, help?
nf stands for no fill, so this means the washer's water level sensor is defective or plugged with dirt. That is why it is overfilling.
2answers
HOW TO FIX NF CODE IN MAYTAG WASHING MACHINE
NF error in your Maytag is displayed due to no fill condition, when the washer tries to fill but is unable to nf is displayed. Please check the water inlet valve for any clogs and obstructions, you can also clean the inlet to solve the issue. Please get back to me if you have any other questions.
Kevin
2answers
My Maytag Neptune will not spins and gives the code nf. I have been told that there is a reset code. Does anyone know the code?
Hi
Thanks for using FixYa. Error NF means No Fill. The washer has tried to fill but was unsuccessful. NF indicates No Flow. There is something that is interrupting the inbound flow of water to the washer, either hot or cold. Sometimes this happens when water service in the area is interrupted, creating an air pocket that causing the water valve not to sense water.
Try running the diagnostic test by—
  • Press the delicates and heavy soil keys together for 3 seconds.
  • You are in the service mode.
  • Now, press wrinkle free key, cold water should start entering.
  • Then, press the cotton sturdy and hot water should flow.
  • To exit the test mode, either unplug the machine or press the delicate and heavy soil again for 3 seconds.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
1helpful
Maytag Neptune nf error
My guess is that something got disturbed in the plug when you pulled it off/put it back on. You turn it to "hot wash" and it does nothing? Does it buzz?
Maytag Neptune Washer Problem
replace the door latch wax motor and check the drain pump for obstructions.
Maytag neptune TL
The machine needs to cut you a break;
“”i have a maytag neptune TL and there are several things wrong with it...1. I can't wash small loads it will stop at the spin cycle and flash dc””
This issue is a clutch issue see this post to DIY the repair.
“”it will wash fine on regular loads until it comes to spin cycle again and it will stop and flash nf””
This one is a little confusing the “nf” error is a No water fill error code. Check these two post for support regarding water inlet restriction or valve not opening properly.
nf post nf post 2
“”my fabric softener dispenser will not let the softener out neither will the bleach dispenser””
See this fabric softer post for support. The fabric softener dispenser may be clogged or the water dispenser valves feeding both dispensers may not be operating properly. The Service Manual on page 16 “Board Output Test” will give you support to turn on the Fabric Softener Valve and Bleach valve. See if you hear the valves operate in Service Mode”
My method may seem a little confusion for viewing water flow to the dispensers. This issue could be associated to the nf error you are receiving, restricted water flow (inlet screen clog) or cold water valve not working properly.
Post back for any questions or possible support I can offer. I’m an owner like you not a repair person but I’m very comfortable working on this machine. Rich
1helpful
Washer does not work!
NF = No Flow (water).
1.Is the water turned on? 2.Check inlet hose screens for restriction.
3.Check wire connections in harness leading from machine control board to pressure switch.
4.Check water valve.
5.Check inputs and outputs at machine control board.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
10helpful
MAYTAG NEPTUNE ERROR CODE NF
NF is a NO fill..
1 check that the water is turned on.
2 check the water pressure
3 check the nose filter screens
4 check the water valve is opening
5 check the conection on the water valve to the control.
6 replace control board
6helpful
My maytag neptune flashes code nf
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Top Maytag Washing Machines Experts
ZJ Limited
ZJ Limited
john h
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
