Question about Lanier Office Equipment & Supplies
Lanier 7320 How can I put the auto feeder down as the screen asks
Posted by Steve on
5 Related Answers
MUKHTAR
mukhtar21 shaikh
  • 2022 Answers
SOURCE: black line when scanning though auto feeder
pls clean the side glas of scnner with tissue paper ther is two type of glass is there one is a4 size and second is normal slim one so pls clean the slim one with wet tissue paper and see is ti clean .
bye
Posted on Nov 30, 2007
Bubbabear64
Tim Babcock
  • 2794 Answers
SOURCE: Lanier 7320 - Makes only all black copies
Was the toner bottle removed before you moved the machine?
Posted on Jun 09, 2008
Anonymous
SOURCE: Auto document feeder
Did you make sure the tape is removed inside the Document feeder,or maybe you need to check to see if anything is stuck in the rollers. Open the door (if you have not already done so) to the document feeder and you will see pictures on the inside showing how you can remove and/or change the roller (make sure everything is put back as the picture. Good luck, I hope that is all that is wrong with it.
Posted on Dec 28, 2008
Phil Oellrich
  • 158 Answers
SOURCE: lanier 7320 error message c-41 can someone tell me whats wrong
I believe c-41 is a fuser problem. A trained copier tech may be required to troubleshoot.
Posted on Apr 29, 2009
Tim Swiercinsky
  • 1126 Answers
SOURCE: Lanier Model #7320 Copier SN 826255. Has a wrench
Press "clear/stop" and "8" at the same time. An error code will be displayed in the copy quantity window as long as those two button are held down. What is the error code? Each code is specific to different areas of the copier. I will be more than happy to assist you in resolving.
Posted on Sep 23, 2009
Very light copy in 2nd side copy
its a moisture issue in the paper. try nice new dry paper and i bet it works fine
Mar 17, 2012 | Lanier Office Equipment & Supplies
I have a black line on my copies. i have a lanier 7320 copier. Is it my drum?
It could likely be the drum. Is the line on copies and prints, or just copies? If it's just on copies, it's not the drum.
Jan 18, 2011 | Lanier 1205 Copier
I have a lanier 7328/7320. It reads side door open on screen. Only the door is closed. Any suggestions
How are you? This is a problem with front door switch.
Remedy
  • Place the machine on a level table and make sure all the four stands are landing freely on this table.
  • Check that the front door notch that closes the door switch is not broken and if it is replace that particular door or modify the notch.
  • Make sure the upper half of copier is well locked with the lower bottom part.
If all the above is correct, and still reads open, replace the door switch.
Good luck.
Nov 15, 2010 | Lanier Office Equipment & Supplies
Sep 23, 2009 | Lanier Office Equipment & Supplies
Lanier 7320 error message c-41 can someone tell me whats wrong
Mar 19, 2009 | Lanier 1205 Copier
Dec 26, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
Misfeed on lanier 7320
I like your pictures.... Have you tried to clean the feed roller with a slittly damp rag with Simple Green or WD-40? You can try that and wipe the extra off. They both clean the rubber roller's. If that works good, that means the feed rollers are worn and need replacing. But you may also need the paper pick-up feed clutch. You said you can still run paper throw the by-pass. Good Luck
Dec 11, 2008 | Office Equipment & Supplies
Jun 09, 2008 | Office Equipment & Supplies
Sounds like a dirty sensor or a small piece of paper stuck. Check the feeder, left side, underneath. There should be a switch actuator
in the paper path that is visible. Also, on the right side, check all of the openings for anything stuck. If you have no luck, get some canned air and blow out everything. If its still jammed, it can be easily unplugged in the back of the machine, and the machine section will still operate.
Apr 23, 2008 | Lanier 1205 Copier
Printer problem
You need service on your copier. It might just need a cleaning, or possibly a part. If they are random spots on your copies, then there is a good chance the cleaning unit seal needs to be replaced.
Jan 24, 2008 | Office Equipment & Supplies
23 people viewed this question
Top Lanier Office Equipment & Supplies Experts
Ekse
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Lanier Office Equipment and Supply Expert? Answer questions, earn points and help others
