Question about Belling Ovens
I need a new oven selector switch for a belling countrychef 924. The model num isn't visible but the serial num starts 07 100412. What part number do I need? Thanks
Posted by Laura mitchelmore on
Marvin
    Top Expert:
  • Belling Master
  • 85,239 Answers
Sorry but this is not a parts site. This site has no means of looking this up for you.
Posted on Oct 31, 2016
Where are the fuses located in a frigidare stove
Good Afternoon Friend, this is Z. Thank you for your post!
I understand you are seeking the fuses location in your Frigidaire range. May I please have your model number? You can typically locate the serial tag (which lists your model number) in the storage drawer, on the right side. Please describe what your appliance is doing so that I can assist you better in pinpointing the problem before you take this step. Thanks!
Jun 07, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
How to replace oven control on356 belling
how to replace a selector switch
Nov 26, 2012 | Belling Ovens
I have the serial number 06 1 00049 but need to clarify the model number which I dont have, in order to buy a part. I think it might be XOU493 after searching on Google
The model number is often located on a plate or sticker which is on the front of the oven chasis, usually running along an edge of an oven door.
If this is not visible or worn away, the manufacturer often has another sticker or plate either on the side or back of the oven. If it is a built in oven, you will need to undo the 4 or 6 screws holding the unit into the cabinet housing and then carefully pull it out. This task is best done with 2 people and a workmate or table to slide the oven onto.
Sep 07, 2011 | Belling Ovens
Hi there Have recently moved into a house with a Belling 626 white, electric cooker and the grill doesn't seem to be working. It has a mian oven, top ovem and "dual grill". The main oven...
ISOLATE THE MAINS POWER BEFORE CHECKING THE APPLIANCE
Run your fingers along the grill element, in this model it is accessible, check for raised areas or small hole or roughness not food burnt, if visible, it should be Black Grey colour at the blemish, you can obtain parts from www.whitegoods.co.uk you will need the model and serial numbers.
The grill elements come out but when unsrewed sometimes the ceramic holders crack, remove element before ordering as you may have to replace the element holders.
Hope this has been helpful
john
May 31, 2011 | Belling Ovens
There is no heat coming out of my fan oven, a Belling Countrychef 100df Range Cooker. The fan comes on and the light goes on to show it is on but there is just no heat ! It is about 7 years old. What is...
If the fan is working o/k, then it is sure to be the oven element that has failed.
This is located at the rear of the oven compartment behind a removeable cover.
Nov 17, 2010 | Ovens
Top burner stays on fire red and burns everything. Can't get oven back to "Bake"
This would be due to the relay contacts being stuck, the relay or control that contains the relay would need replaced. If you have the full model and serial number I can try and locate a part number for you. The model number is on the tag that is visible on the opening when the door is opened.
May 17, 2010 | Kenmore 42161 / 42169 Electric Single Oven
Belling multifunction user manual
modle number 44445847
is that all you need?
Jan 06, 2008 | Ovens
Ovens Logo
42 people viewed this question
Top Belling Ovens Experts
Marvin
Marvin
Lawrence Oravetz
Harrie
Are you a Belling Oven Expert? Answer questions, earn points and help others
