Question about Philips 50PFP5332D 50 in. Plasma Television
Phillips HDTV 50PFP5332D/37 Black Screen. Last used with DVD player. Power light comes on but no sound or picture. How do I decide what parts I need?
Posted by Charlie Thompson on
5 Related Answers
Anonymous
SOURCE: Black Screen after 5 mins. of use
It sounds like the entire screen goes blank with your problem. My problem is the lower half of the screen goes blank. Do you think the SSB is also the problem? What are your thoughts about the "Video Board" or the X Board?
Do you know where to purchase parts?
Posted on May 28, 2008
pwrblnc
Ricky Kendall
  • 4 Answers
SOURCE: TV will not Power Up / Blinking Green Light on Power Button
May be the same problem Magnavox is having with their 27MF231d. I found the fix on this site and it took care of the same problem with my set. Not the easiest thing to do, but it worked. If you do not know how to solder, get some help with this one. If you take it to a Magnavox Authorized repair location, they will just replace the bad capacitor with another bad capacitor of the same type and voltage. The problem is they have a 25w capacitor where a 35w capacitor should be. Mine was bulging, with black tar looking stuff coming out of it. It was obviously bad. Follw the instructions below.
1. Remove all screws around perimeter, one screw at the lower right at (Side A/V), and 2 1”round plastic knob s.
2. Remove back cover
3. At lower left side remove 2 screws for On/Off switch cut tie wrap that holds wire down for free movement.
4. Disconnect wire connector to side A/V at lower right side
5. Disconnect wire connector to right side circuit Board
6. Disconnect wire connector to left side circuit board
7. Remove the 2 mounting brackets upper left and upper right 2 screws each.
8. Remove 3 screws each side of the metal box in the middle
9. Fold back metal tape off bottom and top of metal box
10. 1 wire connector at top of box I left connected
11. Flip metal box over towards top of Tv. Be careful of wire at top thats still connected.
12. On left side in box is power supply board
13. Towards bottom of board you should see the numbers C2081 and C2074
14. Remove the six screws holding down power supply board
15. Flip board down towards bottom of Tv.
16. Unsolder capacitors replace with new 1200uf 35v and 2200uf 35v 105°C radial capacitors
17. Capacitors should be around 1/2” to 5/8” dia. X 1.25 long appox. 2 Wires come out of one end should be .030 dia.
18. Reassemble in reverse order and enjoy
Posted on Feb 28, 2009
tlm931
T.l. Moore
  • 273 Answers
SOURCE: i have a phillips 50 inch plasma- model
you have a problem on one of the boards in this unit you would have to start isolating the source to pit it down
its probably best you get some help form a servicer in your area this is a philips inside and made by samsung
Posted on Oct 24, 2009
Anonymous
  • 4 Answers
SOURCE: 50PFP5332D/37 has sound and no picture.
try restting push the menu button in on the side for 5-6 second
Posted on Apr 15, 2010
sabreusa
AAA TV Service
  • 271 Answers
SOURCE: My Philips flat screen tv
It could be a power supply problem. In this model at least 2 capacitors, go bad in the power supply I think they're 1000uf/10V. If you look at the power supply board you will notice a bad cap with a blister on the top. The whole power board is from $100 - $200. I fixed a lot of these sometime the Y or sustain board goes bad. Visual inspection then measuring voltages..
Best of luck
Nour Sabre
Posted on Nov 03, 2010
Phillips 50pfp5332d/37
take it back and exchange it...then you'll know for sure if they are incompatible or TV is on the fritz or a bad sound system
Jan 14, 2014 | Televison & Video
Philips tv model number 50PFP5332D 37 wont power up
I have the model Philips 37PF7320A/37 won't turn on and MOST articles on the Internet say it's the Capacitors capictors capictors..I checked all of them. My tv just blinked red lights, had the clicking sound at first power on, but then goes black. No sound. No picture. Nothing. Just blinking red lights.
MINE WAS RESISTOR no. 3318 , a 100 OHM RESISTOR ON POWER SUPPLY BOARD.
I BOUGHT REPLACEMENT FOR .99 CENTS SOLDER IT, AND EVERYTHING WORKED!!!
THAT WAS ALL IT TOOK.
JUST A SUGGESTION..
1. CHECK FOR BULGING CAPACITORS (90 PERCENT OF THE PROBLEM)
2. THEN CHECK FOR RESISTORS WITH MULTIMETER ( FALLS INTO THE OTHER 10 PERCENT OF THE PROBLEM.)
TELL ME IF THAT [email protected]
Oct 30, 2011 | Philips 50PFP5332D 50 in. Plasma...
My phillips 50 inch just went black screen but there was still sound and blue light now there is no sound but still blue light any ideas please
Darren, give ShopJimmy.com a shot. They have numerous parts for your set. I included a link to your model page from their site. Hope that helps!
[email protected]
http://www.shopjimmy.com/catalogsearch/result/?q=50PFP5332D
Sep 12, 2011 | Philips 50PFP5332D 50 in. Plasma...
We were watching tv last night and it the picture just turned off. the machine was on but no picture. i turned off the tv and tried again this am. no picture.
You either need this part (http://cgi.ebay.com/Philips-50PFP5332D-37-LJ92-01401-Buffer-Board-/150501144120?pt=LH_DefaultDomain_0&hash=item230a913638) or this one depending on your dead screen issue (http://cgi.ebay.com/Philips-50PFP5332D-37-LJ41-04216A-X-SUS-XSUS-Board-/170550290208?pt=LH_DefaultDomain_0&hash=item27b596e720)
Oct 20, 2010 | Philips 50PFP5332D 50 in. Plasma...
Only get black & white, double images
bad power circuit may cause such problems.
may be power ic or bad capacitors.....
Aug 18, 2017 | Philips 50PFP5332D 50 in. Plasma...
Sep 05, 2009 | Philips 50PFP5332D 50 in. Plasma...
My dvd player doesn't fill the screen on my Sharp
There are settings on most DVD players as well as TV's that allow you to adjust the type of display you want. Make sure both the DVD and TV are set to the same display type (usually either 16:9 for your type of TV). If that still does not fill the screen you will have to use the Zoom function on either your DVD or TV. This will cut off part of your movie, but should allow you to fill the screen. Most DVD movies will also allow you to choose widescreen or normal viewing from their menu. Again, you will lose a small part of either side of the movie, but at least you will fill your screen.
Jul 07, 2009 | Sharp Aquos LC37D44U 37 in. LCD HDTV
Picture and Sound flash from 'on' to a black screen
Hi, The problem lies within the unit. You have a hardware failure within the board. The power supply board needs to be repaired or replaced. If you are a handy person, you can easily swap the power supply board.. If not, bring it you to local reapir shop, they will find the parts and replace it for you. I wish I had a better solution like an easy fix for you. Sorry, but on hardware failure, there is no easy fix. Thanks, Mike
Nov 02, 2008 | Panasonic TH-37PX60U 37 in. Plasma HDTV
LG RZ 37LZ55 37 in HDTV LCD Screen Dead
This is likely due to a failed power supply. Replacing the power supply board should solve the problem.
http://www.reviewcentre.com/reviews110919.html
Cr1spy
Jan 10, 2008 | LG RZ-37LZ55 37 in. HD-Ready LCD...
Philips 50PFP5332D 50 in. Plasma Television Logo
121 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Muntejaya Ginting
Muntejaya Ginting
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
