Car Radio Constant 12v+ Wire: Orange
Car Radio Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: White
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
SOURCE: Wiring harness
you should never cut the wires on your factory harness... metra and other companys have harnesses that fit your car and would provide you with a correct wire color code you need to hook up a aftermarket stereo keep that in mind but i will post the wire diagram u are looking for
SOURCE: installing after market stereo
Dave,
You will need to go buy a wiring harness adapter from your local Walmart (usually cheapest there) or Local Electronics place (ie Best Buy). The wire harness that goes out from the radio goes into the Adapter and the adapter plugs into the car harnesses. Also these Adapters come with the wiring diagrams for your vehicle. They typically run 10 - 15 bucks depending on where you get them. Thanks for using FixYa!
Sincerely,
JC
SOURCE: I want to install a stereo in a 2001 grand am se but the wires were cut.
Here are the wires colors of the harness and what they do.
2001 Pontiac Grand Am Car Audio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: The radio harness does not provide a switched power source. Run a wire to the fusebox for switched power.
Car Radio Ground Wire: Black/White
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: Pink
Car Stereo Amplifier Location: Mounted behind trim in the left side of the trunk.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
SOURCE: 2004 ford escape wiring diagram
This is for 2005 Escape, its possible that can helpfull... LINK
Hope this help.
