Question about Frigidaire Ovens
The push button to turn on oven does not work however the timer button does work. Frigidaire professional series year 2000
Posted by Christine mcm on
5 Related Answers
Anonymous
  • 7 Answers
SOURCE: F30 ERR message on Frigidaire Professional Series Range
I am a tech and just had this happen to me, so I can feel your frustration. I have replaced the temp probe, erc, and still had the problem.
Open the back, with the unit unplugged. On the lower right hand side there is a relay, beside the relay there is a "safety T-stat" disconnect from the circuit by removing one wire and read for continuity. If none is detected, replace t-stat and voila... stove works. Much cheaper than erc and probe...
Posted on Sep 12, 2009
Anonymous
SOURCE: I have a Frigidaire Gallery
Got a frigidaire gallery pro-series oven model #FGF379WECS the pervious owner had propane gas but i have natural gas. is there any way of switching ithe oven from propane to natural without buying a converter kit?
Posted on Oct 04, 2009
Anonymous
SOURCE: MY OVEN DOOR WONT UNLOCK ON MY FRIGIDAIRE
I cleaned my oven and now the door won,t open. The lock light is flaching.
Posted on Jan 04, 2010
Anonymous
SOURCE: Frigidaire Gallery Professional Series - No clock/oven functions
i have an old model of the fridgedare gallery professional series stove. After self cleaning, the ignition sparks for the burners will not come off, they keep clicking and only stops when i pull out the plug. can you help me with this situation?
Posted on May 31, 2010
Anonymous
SOURCE: I have a Frigidaire Custom Imperial double oven
A Frigidaire Custom Imperial double wall oven, circa 1966-1970, custom installed into brick wall needs to be replaced, in my home's kitchen. Is there a double wall oven currently available to replace the 1960's which measures less than 21 3/4 in. wide, 443/8 in. high, & 24 1/2 in. deep?
Posted on Dec 11, 2010
Frigidaire Gallery series model GLEB30T8CBA key pad not working
Hello Dana, thank you for your post!
From my understanding your Frigidaire oven is displaying an error code of "F8" and your keypad is not working properly. An "F8" error stands for runaway temperature (overheating). I would recommend performing a reset on your oven and you can do that by disconnecting the power cord for at least ten minutes.
If that does not help correct your issue then you could have a problem with your RTD (Resistance Temperature Detector) or the EOC (Electronic Oven Control). I would suggest having a professional technician out to perform a proper diagnosis and repair. I hope this information is helpful. -Matt
Jan 10, 2016 | Frigidaire 30 in. Electric Gallery Series...
Probe light on convection oven stays on. Clock won't display. Oven still works though.
Sounds like the control board is not communicating correctly with the rest of the unit, consult a professional.
Aug 10, 2012 | Frigidaire 30" Built-In Single Electric...
Timer shows F30
I had the same F30 error problem but fixed it. On my professional series Frigidaire, there are 2 resettable red button locations. I discovered that only one is in the rear of the oven. After going to the breaker box and shutting off the power, pull out the stove enough to work, unscrew the rear screws (I didn't unscrew all of them, just enough to work back there). The small red button is on a small black round piece with two purple wires feeding to it. That was not my problem. Mine was the other red button behind the control panel. Pull off all 4 knobs, unscrew by hand the large black rings that are underneath the knobs, pull out the whole panel. Look back and right (below where the right knobs were located) to find the 2nd red small button. Push to reset. Check this one first since it is easier to do.
Nov 04, 2010 | Kenmore Ovens
The self cleaning instructions for my Frigidaire Gallery Pro Series Model FEB798WCCH do not inform how long to set timer. Any instructions would be helpful as I've never operated a self cleaning oven...
Hello- The function is automatic when clean button is pushed. Oven will lock, and turn on at full power for about 90 mins. This 'feature' can, and usually does eventually burn out circuits in the control board. Techs call this the 'self-destruct' option, cheerfully promoted by the salesman. Avoid using 'self clean'!  Scrape and clean with light soap/water. Turn on to 450deg. for about 30 min. This is about half the temp. of a 900deg. 'clean' cycle and a lot less expensive in the long run. Please acknowledge this post if info is helpful- have more if needed.- Thanks- Ed
Mar 19, 2010 | Frigidaire 30 in. Electric Gallery Series...
I am trying to clean the oven,
you can try and hold the door closed by hand and push the self cleaning button.and it might work
if that does nothing for you there might be a problem with the door switch.
the other likely problem is a bad clock timer/main control panel
Jan 31, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Jun 11, 2009 | Frigidaire FEB27S6DC / FEB27S7DC Electric...
F8 Displayed
F1 Electronic oven control failure Replace electronic oven control (also called EOC or clock).
Apr 01, 2009 | Frigidaire 27 in. Electric Gallery Pro...
I have a Frigidaire Custom Imperial double oven which still works gret after all these years. But, the clock just died which means the timer doesn't work or the clock to turn the oven on using the timer. I...
Mar 24, 2009 | Ovens
Nov 01, 2008 | Frigidaire FGB24S5A Gas Single Oven
Ovens Logo
Top Frigidaire Ovens Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Alan Chouinard
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
