Question about Drills
Need battery 18volt d c for power glide drill motor can I get it here? 60101230?
Posted by Bill C. Pace on
jhnolson
  • 822 Answers
Posted on Oct 30, 2016
18volt cordless drill battery charger will not charge batteries
Fist you should check that if there is problem with your battery or charger. Do you store your batteries in right way when you don't use them?
You can come here (Power Tool Batteries Drill Batteries Replacement) and find if there is batteries or chargers for you.
Mar 26, 2014 | Drills
Milwaukee 18volt impact wrench has no power batteries are good, motor brushes seems to be ok
i have the same impact an replaced trigger switch. i think it was 38,00, had the same thing happen with my de walt xp hammer drill.U can check switch continuity before replacing
Jan 06, 2011 | Milwaukee 0879 22 V18 Impact Wrench Kit
My black and decker kc1882f 18volt drill battery will not recharge whenever plugged in it shows battery full ,and when used only as weak power
Hi the problem is with the cells in the battery what happens is the cells go bad and then dont hold the charge this then causes the battery to seem full when its actually nearly flat, all you need to do if you want to keep using it is get the battery replaced
replacing the battery with a new one will solve your problem
Aug 17, 2010 | Black & Decker Drills
Pro tech 18volt. Item number 6810
http://www.sears.com/shc/s/p_10153_12605_00981808000P?vName=Tools&cName=PowerToolAccessories&sName=Batteries%20and%20Chargers&psid=FROOGLE01&sid=IDx20070921x00003a
Mar 27, 2010 | Dewalt 7.2-18.0 Volt One Hour Charger
Where can i get a coleman powermate 18v power supply for a cordless drill?
I'm looking for an 18volt batterie transformer for my coleman powermate drill, my transformer stopped working, and can't find one.
Thank You
Douglas Jonatzke
[email protected]
Sep 25, 2009 | Drills
Drills Logo
557 people viewed this question
Top Drills Experts
Marvin
Marvin
Tom Chichester
Bill Boyd
Are you a Drill Expert? Answer questions, earn points and help others
