You have to make sure whether your DVD player supports the 4K playback. Some DVD player doesn't support the 4K video and then it can not read the disc.
But you can play your 4K video on your computer with free 4K video player. Here is the one. You can have a try. Or you can make 4K to 1080P so that you can play on the TVs that don't support 4K playback.
www.leawo.org/blu-ray-player/?fixya=1410
Is your disc burned or purchased? If it's burned then it could be that you used a wrong format when burning the DVD. In this case try another DVD burning program like Leawo. How to Burn and Convert MP4 to DVD on Window 10 8 7 Easily
Are you still need help? If so, how about giving another Free DVD/Blu-ray Player a try?
Leawo Free DVD/Blu-ray Player contains all media playback solutions you need for your leisure entertainment. It acts as free Blu-ray disc player, free DVD disc player, free CD player (video-CD), free HD video player (free 4K video player), free ISO file player, and free audio player (free music player). Being a free Blu-ray disc player software app, it plays Blu-ray discs for totally free, and downward compatible with DVD disc and CD discs playback, no matter they are commercial or regular. It's the best free software to play Blu-ray on Windows (including Windows Vista, XP, 7, 7, 8, 8.1, and 10).
Meanwhile, as free DVD player, it's not only a free DVD disc player, but also free DVD player to play back DVD folder and DVD ISO image file for totally free. It's also a free 4K video player to deliver extraordinary image and audio experience via 4K displays. It's cable of playing 4K video in MKV, MP4 and TS formats, 1080P videos in HD MP4, HD MKV, HD MOV, etc., 720P videos in MP4, AVI, MKV, and other formats, be it camcorder reordered footage, downloaded online video, or streamed video.
Hope it it anther choice for you an other users. :)
Best Free Blu ray Player Software for Windows Leawo Free Blu ray Player
SOURCE: Bose 321-GSX.
Adelina, I recently purchased this unit. After having four units lock up, I finaly got one that seems to be working fine. If you still have warrenty remaining, I suggest returning the unit to Bose as they are apperently having signifigant issues whit this product line. Unfortunatly you may be without a unit for a while.
SOURCE: bose 321 system reads bad disc on all dvds
if will not read a laser lens cleaning disc , then it will need to be opened up and the laser lens will need to be cleaned manually with the cleaning solution and a cotton tip , but do it easy and dry the lens with the cotton tip
if that don't do it then the laser mechanism will need replacing
electech
SOURCE: Running my Blu Ray DVD thru the Bose Lifestyle 18
hi there,
1-connect the blu-ray to your tv via hdmi cable and this will run picture.
2-connect the blu-ray via digital optical cable to the optical input on the bose system. then using your bose menu, (system menu)set your auxillary sound output to digital optical.
when watching dvd thru bluray player select aux on the bose and you're away.
good luck
SOURCE: DVD WONT PLAY...DISPLAY SAYS READING
try a cleaning disc or clean the laser .could be just a bit of dust..good luck .farr64
SOURCE: bose dvd player door want open
You just unplug the cord form the wall for 4 hours, after 4 hours plug it again. The purposed of unplugging is to dissipitate the
stored current in the memory IC so it will gone.
Good luck:
Regards;
VOTIT
Don't forget to rate;
