Question about Samson Audio Players & Recorders
Is there more than one fuse on the Samson L615 Loud Speaker
Posted by Cory on
One of our samson auro d412 monitors is making a loud noise when it is powered up....any idea what the problem is
A snapping, crackling or popping sound?
One of the big capacitors on the power board is going South.
Fixing/replacing it is cheap and easy, just Google for the instructions specific to this speaker.
There is a wealth of information for repairing this speaker online, just poke around the interwebs.
Feb 25, 2015 | Computers & Internet
Samson l615 schematic
Try using Google and search for it on line.
Dec 21, 2013 | Audio Players & Recorders
Samson db1800a stoped working
push on the speaker lightly to see if it moves in and out easly if not the speaker could be blown if thats ok pull the speaker out of the box and check out the terminal see if they are worn
Sep 24, 2012 | Samson dB1800a Subwoofer Speaker
Hi, I have one Samson Auro d412a active speaker plugged into the output channel of a 12 channel passive mixing board. When I sing into the mic, the speaker shuts down and the red light on the back...
If you read the TRUE specs on this speaker it is really a 200 Watt RMS unit. Make sure you are using balanced lines to the speaker XLR or TRS cables. The mixer should NOT be a passive mixer as these do NOT generate true balanced lines. Make sure the mic can't "hear" the speaker or you may be getting supersonic feedback that is above your hearing range that saturates the amp. If *********** can't stand to be ain a 15 foot square room with teh level you are generating, it is TOO loud for this unit to handle.
Aug 01, 2011 | Samson Auro D412A Speaker PA Active
Hi There the fuse just blew in one of my Samson
Hi there
To answer your question;
If it is not indicated near the fuse holder then look closely at the metal end caps of the fuse.
The value will be written on one of them,
It may look like 2A/250v for 2amps.
Hope this help
Cheers
Jun 14, 2010 | Samson Resolv 65a Main / Stereo Speaker
MT HT-TX52 WORKED FOR A COUPLE OF MONTHS, THEN THE SUB WOOFER WOULD MAKE A VERY LOUD CRACKELING NOISE ALL OF A SUDDEN, BUT ONLY ONCE IN A WHILE, SO I UNPLUGGED IT AND JUST RAN THE OTHER 4 SPEAKERS. WORKED...
Maybe a capacitor in the amp section is making this problem.The only way to find out is to check receiver in service and find which capacitor is bad...but this is not so easy
Apr 18, 2009 | Samson Audio Players & Recorders
Samson Rubicon 5 Studio Monitor speaker is Popping
It seamns like its pretty commom =(
We should organize and complaint with samson!!
Read this:
http://www.gearslutz.com/board/low-end-theory/314545-samson-rubicon-r5a-problem.html#post5794093
Mar 12, 2009 | Car Audio & Video
Samson Resolv 65a Speaker - No Power!
There's a fuse input just underneith the mains input plug.A small screwdriver will open the small latch.You can get new fuses at Maplins.
Jan 07, 2008 | Samson Resolv 65a Main / Stereo Speaker
Samson sx1800 power surge
Hi There,
Manufacturers install protection devices in their audio systems that are there for that purpose, any loud 'thump' or 'crack' trips the protection device so the loud speaker wont be burnt out. Speakers are expensive so the manufacturer does his best to allow you to listen to very loud sound and yet provided protection in case you exceed the sound rating of the output protection device.
In your case it sounds like the protection device has done its job but has not reset, to allow more listening...
Check the operational manual that came with the amp system to see if there are re-set instructions available to you....
If you dont have the reset detail, then phone/e-mail the manufacturer to obtain the reset information...
If there is no resetting you can do as a consumer then it should be no problem for a service shop to do the reset for you...
It may be a simple internal fuse that has blown but if its not accessible from the outside then I dont suggest you go inside and make changes unless you are skilled and trained in electronic servicing...
Cheers for now YUBEUT
Oct 31, 2007 | Samson SX1200 Amplifier
97 people viewed this question
Top Samson Audio Players & Recorders Experts
 Grubhead
Grubhead
ray gallant
Are you a Samson Audio Player and Recorder Expert? Answer questions, earn points and help others
