Question about Suzuki Outboards - Zinc 115-140Hp Outboa
My Suzuki DT4 outboard motor has an ignition coil that measures over 13K ohms and I want to order a replacement, the P?N 33410-98610 is obsolete. What is a suitable substitute for this coil?
Posted by Fred Hoefer on
_-__-___-_
  • Suzuki Master
  • 20,706 Answers
What measures 13k?
the coil has a primary and secondary
and most all coils, made have secondary at 10k or more.
and suzuki sells them.
if they dont, then consider not owning any Suzuki,,,,
that leaves only NOS parts or used off ebay.
or get on craigs, list like I do and beg
WTB, wanted to by, "DT4 coil"
i moved you out of CARs to outboards....
Posted on Oct 30, 2016
Suzuki dt4 40hp outboard ignition what are wire color coded
Not sure what's the question. You can get a copy of wire color codes from local dealer or internet.
Sep 13, 2017 | Suzuki Boating
Tip
Misfiring Ford Escort ignition fault finding
1999 Ford Escort firing order and ignition troubleshooting.<br /><span>Refer to the diagram. Cylinders are connected as shown on the diagram in blue. 1 goes to cylinder 1(sparkplug furthest from coil pack), 2 to 2, 3 to 3 and 4 to 4(closets to coil pack).<br />To test the coil pack use a digital volt meter. Measure resistance between coil towers for coil 1(marked 1 in red on diagram) Value should be between 12000 and 14500 ohm. Do the same for coil towers 2. <br />Measure resistance between I and C1. If the measurement is more than 5 ohm the coil is defective. Do the same for I to C2.<br />Measuring voltage at I(Ignition start/run) to ground should be 10V.</span><br /><span>I is connected to the 15A engine fuse. The radio interference capacitor is connected between this line and earth at the coil. Disconnect it to see if it cures the misfire.<br />C1 and C2 connect to the powertrain control module. The module earths each line to make its respective coil fire.<br />Bear in mind that aftermarket coil wires may cause problems with misfiring</span> so use OEM parts where possible.<br /><img src="suzman_6.JPG" /><br />
on Nov 17, 2010 | Ford Escort Cars & Trucks
Hi I have a Suzuki DT 16 engine 1602 no 207668 I have no spark at the plugs I have put a volt test on the green going into the CDI unit about 3 to 4 volts when pulled what should it be Thanks Mike
With or without remote control??
Disconnect the black/red wire from the CDI, if you have sparks, kill circuit shorted.
No spark: check coils
1 . The two pulser coils are located at 1 80°angles to each other and the
condenser and battery charge coils are also located opposite of each other
under the flywheel.
2. Remove the engine cover.
3. On models equipped with electric starters, disconnect the negative
battery cable.
4. Disconnect the connector and black ground wire.
5. On the No. 1 pulser coil, connect the digital multi meter between the
black/red wire terminal in the connector and the black ground wire. And the
No.2 coil between the white/green wire terminal in the connector and the
black ground wire. Resistance should be 260-380 ohms.
6. On the condenser charge coil, measure the resistance between the
black/red and green wires. Resistance should be between 1 70-250 ohms.
7. If the resistance reading is not within specification, replace the faulty
coil.
8. On the battery charge coil, measure the resistance between the
yellow/red and yellow wires, red and yellow wires (DT1 5MC) or the red and
yellow wires (DT15CE). Resistance should measure between 0.2 and 0.5
ohms.
9. If the resistance reading is not within specification, replace the faulty
coil.
Jul 26, 2017 | Clymer Suzuki 2-225 HP Outboards Includes...
1998 gsxr 600 no spark
Instructions
Verifying the Spark
Remove the upper and side fairings, using a 4 mm Allen wrench to unscrew the fairing bolts. Unlock and remove the rider's seat, using the ignition key.
Pull the fuel lines off of the fuel valve under the left side of the fuel tank. Unscrew the pair of bolts from the base of the fuel tank, using a 10 mm socket. Pull the fuel tank to the rear of the motorcycle to remove it..
Pull the cables off of the two spark plugs on the right side of the motor. The spark plug cable furthest to the right is connected to the right ignition coil, while the second cable is connected to the left ignition coil. Unscrew the spark plugs from the motor, using a spark plug socket. Plug the ignition cables back onto the removed spark plugs.
Hold the spark plugs against the motor and start the motorcycle for a few seconds. Observe the gap between the electrode at the tip of both spark plugs for spark. Ideally, the spark should have a bright, blue appearance.
5
Replace the spark plugs with new DR8E spark plugs, if no spark is present. Repeat the test. Replace the corresponding ignition coil if there is still no spark present at the spark plugs' electrodes.
6
Proceed to Section 2 for further diagnosis, or reassemble the motorcycle following the reverse method of removal.
Testing the Windings
7
Remove the suspect ignition coil from the motorcycle's frame, using a 10 mm socket. Unplug the coil's cables from the remaining spark plug in the motor and from the spark plug removed in Section 1. Unplug the motorcycle's wiring harness connector from the back of the ignition coil. Remove the remaining ignition coil, if needed, using the same procedure.
8
Set your multimeter to read an R X 1 resistance range, using the meter's settings dial.
9
Measure the ignition coil's primary winding at the terminal that connects to the motorcycle's wiring harness, using your multimeter. Touch the meter's red probe to the coil's positive (+) terminal and the black probe to the coil's negative (-) terminal. Take note of the measurement on the meter's display. Replace the ignition coil if its primary winding has a resistance measurement less than 3 ohms or greater than 5 ohms.
10
Set your multimeter to read an R X 1,000 resistance range, using the meter's settings dial.
11
Measure the ignition coil's spark plug cables, using your multimeter. Touch the meter's probes to the metal connectors within the cable's end caps. Take note of the resistance measurement on the meter's display, indicated in ohms. Replace the ignition coil if the cables have a resistance measurement less than 25,000 ohms or greater than 45,000 ohms.
12
Reinstall the ignition coil if its primary winding and spark plug cables are within the specified resistance range, using the reverse method of removal. Replace the entire ignition coil if either the primary winding or the spark plug cables are within specification, as the ignition coil and its cables are a combined assembly.
13
Reassemble the motorcycle following the reverse method of removal. Connect the left ignition coil's cables to the pair of spark plugs in the middle of the motor's cylinder (#2 and #3), while the right coil's cable connect to the spark plugs on the sides of the cylinder (#1 and #4).
Jan 11, 2013 | 1998 Suzuki GSX-R 600
1999 ford escort I changed the plugs, but broke a plug cap. Bought a generic replacement spark plug wire that had to be modified to fit into the head. I cannot get the firing order correct. The car...
Remove the plugs from the head. Insert into the coil wires. Make sure they are properly earthed on the engine. Crank the motor and check for spark at each of the plugs.
I is connected to the 15A engine fuse. The radio interference capacitor is connected between this line and earth at the coil. Disconnect it to see if it cures the problem.
Bear in mind that aftermarket coil wires may cause problems with misfiring, so see if you cant find an OEM coil wire to replace the broken one before replacing anything else.
Nov 15, 2010 | 1989 Ford Escort
I have a yamaha fz750 and i want to replace the ignition coil, what are the coils that can be used to replaced such. I need some information on ignition coils with other brand and models that will fit tthe...
My FZ750 coils measure 3.9 ohms st the primary winding and was hard to start.
Spec is 2.7 ohm +/- 10%.
I have replaced them with used 1981 Kawasaki KZ750 (inline 4) coils, they measured 2.5 ohms.
They're larger so you have to make your own brackets.
May 24, 2010 | 1985 Yamaha FZ 750 FT (U.S.)
Where is the ignition coil located?
For test:
  1. Follow the coil wire from the center terminal on the distributor cap to the end at the ignition coil. Make sure that the transmission is in Park (AT) or Neutral (MT) and that the ignition is turned OFF .
  2. Separate the wiring harness connector from the ignition module at the distributor. Inspect for dirt, corrosion and/or damage. Reconnect the harness if no problems are found.
  3. Attach a 12 volt DC test light between the coil TACH terminal and an engine ground, then crank the engine. If the light flashes or is continuous:
    1. Turn the ignition switch OFF .
    2. Detach the ignition coil connector on top of the coil and inspect for dirt, corrosion and/or damage.
    3. Using an ohmmeter, measure the ignition coil primary resistance from the BATT to the TACH terminals.
    4. The ohmmeter reading should be 0.8-1.6 ohms. If the reading is less than 0.8 ohms or greater than 1.6 ohms, the ignition coil should be replaced.
    5. Using an ohmmeter, measure the ignition coil secondary resistance from the BATT terminal to the high voltage terminal.
    6. The resistance should be 7,700-10,500 ohms. If the resistance is less that 7,700 ohms or greater than 10,500 ohms, replace the ignition coil.
For Removal:
  1. Disconnect the negative battery cable.
  2. Detach the coil electrical connector(s).
  3. Unfasten the retainers, then remove the ignition coil from the vehicle.
  4. Installation is the reverse of the removal procedure.
Hope helped with this.
Nov 11, 2009 | 1990 Mercury Cougar
Cino 95. ignition coil resistances
IGNITION SYSTEM
1993 Swift
DOHC ....................... .72-.88 .............. 10,200-14,000
SOHC ...................... 1.13-1.38 ............. 11,500-15,500
Measured my 1994 Suzuki Swift primary was 1.3 ohms. The secondary is similar to the above
Oct 27, 2009 | 1994 Suzuki Swift
Suzuki 4hp two stroke impellar
Dropp the lower unit, should be only 4 bolts holding it on. Impellar housing should be located right on top of the lower unit. four screws it the housing slides off the shaft, insall in reverse order with ne gaskets, make sure you re- align the waterhose/pipe from the lower unit back to the head
Mar 22, 2009 | Boating
Gsxr 750 no spark how do i test cdi
I've this data from my 1986 engine!
Under the left hand side cover there are 2 2-wire connections. One with a green and a black wire, one with a blue and a yellow wire.
Use an ohmmeter at R x 100 between both wires of a connector to check the pick-up coils: resistance must be between 130 and 180 Ohms.
The values of the ignition coil resistances are:
primary coil : 3-5ohms ( set ohmmeter at R x 1 )
Secundary coil : 25.000 - 45.000 ohms ( set ohmmeter at R x 1.000 )
For a correct measurement ALL leads must be disconnected ( also the spark plug leads )
The CDI cannot be tested with a simple measurement. Suzuki dealers have a special tool to test CDI boxes.
But checking the pick-up coils and ignition coils good will indicate an defective CDI.
The wires on the CDI:
Blue: PU coil 1 ( cyl 1-4 )
Yellow: PU coil 1
Green: PU coil 2 ( cyl 2-3 )
Blue : PU coil 2
Orange/white : +12v ign coil 1-4
White : switched coil negative side ign coil 1-4
Orange/white : +12v ign coil 2-3
Blue/yellow: switched coil negative side ign coil 1-4 ( and signal to tachometer )
Blue/white : ground
Thus, you must have +12V on both Orange/white leads.
Mar 15, 2009 | 1992 Suzuki GSX-R 750 WN
Suzuki Outboards - Zinc 115-140Hp Outboa Logo
700 people viewed this question
Top Suzuki Boating Experts
Marvin
Marvin
jws1013
Andrew Taylor
Andrew Taylor
Are you a Suzuki Boating Expert? Answer questions, earn points and help others
