Question about Bunn Coffee Makers & Espresso Machines
My Bunn home coffee maker is not making coffee the way it always has. Coffee is extremely weak even though it is the same brand. Even changed brands to be sure. Same weak results. Thankyou
Posted by Ann Toy on
  • Brad Brown Oct 29, 2016
    Hi Ann Toy, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Model number
Marks concession repair
    Habit-Forming:
    New Friend:
  • 76 Answers
It may not be getting hot enough you have to have it at the correct brewing temp..
Posted on Apr 13, 2018
5 Related Answers
Kelley Hopper
  • 67 Answers
SOURCE: my bunn coffee maker CWTF-15 21604-0001
It sound like you are either missing the sprayhead or the temperature isn't hot enough. Check first to see if the sprayhead is there. It fits under the brew basket and looks like a little shower head - it's round and has usually five or six little holes in it. If it is missing your coffee will be weak due to the water not being spread across all of the grounds evenly.
The other thing to check is the temperature. Depending upon where you live the water should be between 185F - 200F. If the water is below that temperature the coffee may look like tea.
Posted on Feb 01, 2008
Kelley Hopper
  • 67 Answers
SOURCE: weak coffee
It sounds like you may have lost the sprayhead. It is under the brew basket (above the place where you put the basket with the filter and the coffee). Sometimes they get loose and you don't realize it and it can fall in the grounds and get tossed out after brewing.
Posted on Jul 18, 2008
Gord Thurston
  • 131 Answers
SOURCE: Bunn coffee maker leaks water
There are 3 seals in your unit that could cause your problem. there is a silicon seal right under the pour-in tray, and two on the top of the tank. one of those is for the thermostat, the other is for the sprayhead tube. any of these could leak, causing water to come out the bottom of the brewer. One other thing that can cause this is a scale buildup between the pour-in tray and the tank.
Posted on Feb 13, 2009
Anonymous
SOURCE: My Keurig B60 is Suddenly Brewing WEAK Coffee
I don't have a solution but have just experienced the same problem and am baffled. I am using the same beans same grind. In fact using the exact same grind it went from great one day to weak the next day.  I always run it for 15 - 16 secs to get the shot and that hasn't changed. Pressure and temperature appear fine. I cleaned the top of the top filter which was a little dirty but not seriously bad - no change. The coffee flow which is normally chocolate coloured to start with is just mid brown.
Posted on Feb 28, 2010
Jafu
Jafu Bumbalini
  • 9 Answers
SOURCE: Bunn Coffee Maker Leaks out the bottom
I have an older BUNN B10 pour-o-matic that I thought was leaking from the bottom. Upon close inspection, I found that it was leaking from the worn out washers located on the top of the tank, allowing water to run down the sides of the stainless steel tank. There's a great fix offered on Fixya.com that suggests going to a hardware store and buying a Gardner Bender GHG-1575 rubber grommet with a 3/4" hole and install it into the large hole in the basin. Then place a metal washer on top of the grommet and snug it up with the threaded fitting. Many folks say it's a great fix. I went a different route. I called BUNN customer service and spoke to a very nice woman who understood my needs and sent out a free repair kit that contained a new fitting, washer, and seal. I received it in a few days and it's working great. Beats going out and buying parts for a work around repair. BTW, the repair kit is called "Universal Retail Seal Replacement Kit #37091.0000"
Posted on Jun 25, 2012
Brand new bunn, can't get it to make coffee
if the coffee pot does not work right, take it back and get another one...
May 11, 2016 | Bunn GRX-B Basic 10-Cup Home Coffee Brewer...
My Bunn bx-b coffee maker has no power / lights. It was working fine and then our powerto our home was lost when it came back on the coffee maker wouldn't work.
Hello, grahamz
I was trying to help you out here. Maybe this will help some? I was going backto some customers that asked questions in the recent past and even fartherback. It appeared that no one answeredsome of them, So, I thought I would take some of my personal time to see if Ican help. Even though this Informational site may not have your exact model orbrand, this site will help you a lot. Here is a site link about everything you want to know about CoffeeMakers and possibly yours, from
repair to trouble shooting it. b>http://home.howstuffworks.com/coffee-maker4.htm
Please if this helped you at all, if you can find the time and in your heart torate my help and some kind words written would be appreciated for my free help, I would appreciate it.
Here is also my direct link to my own pages of other areas of my expertise forother problems you might have in Automotive, Appliance, and Electronics. DropIn anytime for my help.
Thanks, Mike
http://beta.fixya.com/users/mc1bean
Oct 18, 2011 | Bunn 10 Cup Home Coffee Brewer
Unless I use two filters, the coffee is weak. Are the Bunn filters thicker than others?
I have seen so many complaining about this. It is kind of taste. Some people like, some not. I have to buy some other brands filters to get a little bit stronger coffee. Try other brands of filters.
Mar 01, 2011 | Bunn 10 Cup Home Coffee Brewer
What is the best way to remove lime scale and other mineral build up from a Bunn VPR coffee maker? Water flow has been reduced to a trickle even though we used filtered water.
I always use CLR to clean my coffee maker. You don't need much more than 1/4 cup and mix with 8 cups of water and brew it like you would make a pot of coffee, then dump it out and run 2-3 more pots of just water, that should work fine. Also, run vinegar thru the machine once in awhile to help keep it clean
Apr 13, 2010 | Bunn VPR Coffee Maker
I haveBX-B . I had the pot set up for me to push the on button for Monday Morning, but the water ran throug and it was not on.So now I have cold coffee in the Decanter.
The Bunn coffee maker does not operate as most coffee makes do. You cannot leave the Bunn in the off position and then just flip the switch to on and pour the water in. You will always get cold coffee if you do this. It takes time for it to heat the water. The On/Off switch should be left in the On position all the time. This keeps the water hot in the tank, thus providing hot water when you need to make coffee. You then just pour the cold water in the top, shut the lid, and have a pot of coffee in 3 minutes. The On/Off switch is a vacation switch, and you use it only when you are not going to use the coffee maker for a couple of days. Older Bunn coffee makers did not even have an On/Off button. You simply unplugged them when going on vacation. So turn the switch to the On position and leave it there. The unit will then work as designed. Forget how other coffee makers work, this is a Bunn and it is the fastest coffee maker you can buy and must be left on all the time. that way the water stays hot and the unit will keep it that way.
Nov 16, 2009 | Bunn BX HOME BREWER 10-Cup Coffee Maker
Bunn Coffee maker leaking out of the bottom of the coffee maker when the coffee maker is not making coffee.
that needs to go back to bunn for a replacement tank, they will likely only charge you for return shipping
Dec 10, 2008 | Bunn NHB Coffee Maker
Weak coffee
Jun 13, 2008 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
My bunn coffee maker CWTF-15 21604-0001
Feb 01, 2008 | Bunn -O-Matic Corp. 2 Warmer Auto Brewer...
Coffee Makers & Espresso Machines Logo
226 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
gbob59
Marvin
Marvin
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
