Question about Connex Radio Communications
Connex 44oo turbo workrd fine took it to a tech to see the max watts it was doing hooked it up now chan 19 is 26.57 is there a pot i can turn and now no modulation
Posted by Corn Fed on
3 Related Answers
Anonymous
  • 40 Answers
SOURCE: Modulation with my linear
the radio you are trying to fry your amp with is driving the amp to hard. that radio has a toshiba 80 watt final inside the radio you are killing your radio with the dead key at 2 watts it causes the final to overheat and shut down because it is not built to be turned down that much. its best to turn the radio back up and use the radio.
Posted on Mar 08, 2009
Anonymous
  • 17 Answers
SOURCE: Need to know the internal mod limiter board number and the AM mod
check www.cbtricks.com
Posted on Oct 31, 2009
Melanie Rogers
  • 219 Answers
SOURCE: does anyone know the pod too turn for lowering the watts
You have to adjust the high key first so make sure you're rf power is on high, hope you have a meter set it on the 20 watt scale, key up and turn vr 13
located in back of radio infront of where you're coax connector is until it keys around 12 watts, thats where most connex 33hp should be set,now go to low power and key adjust vr 16 right net to the otherone down to about 3 watts, now you can drive a liners. Mod is Vr 2 right below them two. whistle in mic and turn to get the mod you want.
Posted on Nov 21, 2009
My friend just got a KOLE AUDIO QX1-30000.. he's wantin to know if its a 3,000 watt amp or what because it says QX1-30000 on it??
This is the specs on it:
  • RMS Power Rating:
    • 4 ohms: 1100 watts x 1 chan.
    • 2 ohms: 1800 watts x 1 chan.
    • 1 ohm: 2300 watts x 1 chan.
  • Max power output: 3000 watts x 1 chan.
What watt dead key and swing on CONNEX 3300 HP
A standard 3300 hp I seen get up to 40 watts peak,
normally I would turn the audio pot up all the way never snip anything and deadkey down to 2 watts. Than adjust for forward swing, I also never run a pwr mic. Good luck
1helpful
I recently bought a Connex CX366CE. I plan to install a SLMM-1 SUPER MOD AND SWING POWER MODULATION kit. I plan to hook it to a Viper 25,000 watt antenna. Is this going to work? Do I need an antenna tuner...
you should be fine, check your swr's before and after.a swing kit only throws the carrier and adds more modulation. the connex is a good radio to start with,you should be fine, with the mod kit and radio you will never reach 25k on that antenna with this setup. just make sure the antenna is tuned rite for optimum operation(low swr).
How many Watts is the A1300HCQ AUDIOBAHN amplifier
  • 2400W Max, High-Current Monoblock Car Amplifier
  • RMS Power Rating:
    • 300 watts x 1 chan. @ 4 ohms
    • 600 watts x 1 chan. @ 2 ohms
    • 1200 watts x 1 chan. @ 1 ohm
  • Max Power Output: 2400 watts @ 1 ohm
How many Watts is the a1300hcq Autobahn amplifier
A1300HCT Max Watts:
  • RMS Power Rating:
How many watts does a audiobahn a1502dp have
  • RMS Power Rating:
    • 150 watts x 2 chan. @ 4 ohms
    • 300 watts x 2 chan. @ 2 ohms
    • 450 watts x 2 chan. @ 1 ohm
    • Bridged, 300 watts x 1 chan. @ 4 ohms
    • Bridged, 600 watts x 1 chan. @ 2 ohms
  • http://www.sonicelectronix.com/item_2304_Audiobahn-A1502DP.html
    I need to tune my connex 3300 so I can run my linear.can someone send me directions on this...
    you will need a good watt meter and dummy load. or any cb shop can do it for $8.. thats the normal charge here in texas. keep the wattage low, so you don't damage the amp. less than 5 watts max
    A3200e wattage
    Here are some specs:
  • 4800W Max, High-Current 2-Channel Car Amplifier
  • RMS Power Rating:
    • 300 watts x 2 chan. @ 4 ohms
    • 600 watts x 2 chan. @ 2 ohms
    • 1200 watts x 2 chan. @ 1 ohm
    • Bridged:
      • 600 watts x 1 chan. @ 4 ohms
      • 1200 watts x 1 chan. @ 2 ohms
      • 2400 watts x 1 chan. @ 1 ohm
  • Max Power Output: 4800 watts @ 1 ohm
  • this is the web site I got the specs from
  • http://www.sonicelectronix.com/item_61_Audiobahn+A2300HCT.html
  • Hope this Helps...
  • 2helpful
    2answers
    Owners manual for connex 4600 turbo
    to cut down on noise i would hook it directly to the battery. make sure there is a fuse in the power cord first.
    Robert
    Please rate this solution thanks
    2helpful
    4answers
    Connex 4600 Turbo
    i have the same radio turn talk back off and there is enough power ull have talk back through you trucks radio speakers and it needs to be hooked up to the battery with at least 12ga wire
    Radio Communications Logo
    Top Connex Radio Communications Experts
    Damon Nesselrodt
    Damon Nesselrodt
    Tom Chichester
    Are you a Connex Radio Communication Expert? Answer questions, earn points and help others
