Question about Zenith Televison & Video
I have a old Zenith TV Model #TVBR1912Z. My son messed with the remote and now the picture has a huge black box over almost whole picture. How do I fix this/
Posted by Dana Schapersville on
bigdawg7299
  • 2,559 Answers
Turn off the closed captioning. Usually there is a button on the remote marked cc. Or you can do it thru the menu.
Posted on Oct 28, 2016
Jvc lt-47em59 picture too large in all aspect modes
Larger as in -- the screen looks fatter. 4:3 stretched to 16:9 or as in Larger as in, screen is longer but thinner? 16:9 / 10 fitting onto ratio 4:3?
Asuming... its the second one -- that ur screen is box 4:3 and the picture is huge 16:9 which is why u need to "zoom out" to get the full picture -- are u sure some idiot didnt mess with the settings and make the tv "zoom in" if it isnt a aspect ratio issue?
... if it is a aspect ratio issue, and ur using 4:3 (small old box televisions) there should be a ratio setting either on ur television OR on ur set top box, that would by defualt with digital tv have wide screen 16:9 -- id suggest finding the settings either on the tv or the set top box or...
just get a bigger tv that supports 16:9 cheap for 50 bucks.
Mar 17, 2014 | JVC Televison & Video
DVD viewing shows in black and white
you have to change color system of dvd(ntsc, pal,) normally dvd remote will p/n button..press it to change color system,,otherwise u have to change color system of ur tv
Mar 15, 2010 | Zenith Z25X22S 25" TV
27 inch Zenith TV Vertical too big
If you are using a DTV coverter box, you may have changed the aspect ratio with your remote control. look for a button marked "aspect" or "picture size" use that to change size.
If you have a cable box, you may have a similar button.
Or you may find a picture size adjustment on your TV remote.
If you do not have "aspect" button on your remote try going to set up menu and look for picture size.
Older TVs used to have a vertical size adjustment at the back. look in the manual.
If none of the above, you have a biiger problem with the TV internal parts needing attention
Mar 03, 2010 | Zenith C27A24T 27" TV
Problem programming Zenith Digital TV Converter DTT901 remote.
Be sure that your TV is set to channel 3 or 4 if you are using the RF cable or Video 1, etc if using the Audio/Video cable.  The Installation  Guide should appear.  The "improved" picture that you are seeing is simply the analog throughput, not the digital conversion.
Nov 21, 2008 | Zenith DBZN-311 Remote Control
Programing a remote
My son-in-law showed me how to pickup the code from the zenith TV, thanks for your concern.
Nov 09, 2008 | RCA 3-Device Universal Remote with...
Picture but no sound
press mute button on tv remote
Oct 20, 2008 | Zenith B27A11Z 27" TV
Universal zenith control zen450
You can d/l a free Zenith manual (PDF) here:
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=b8e8ed044c8bd982f885efd5f432012a&q=Zenith+ZEN100
Try these codes listed for Daewoo:
002, 102, 110, 203, 214, 221, 303, 311, 314, 403, 407, 502, 503, 505, 512, 611, 805
Good Luck!
Aug 12, 2008 | Zenith DBZN-311 Remote Control
Dvd only playing in black and white
Make sure that you connect all of these connections to the right colored cables.
It seems like you only have the green cable connected. Go back and connect the red and blue for both the tv and dvd.
Aug 06, 2008 | Sony DVP-S500D DVD Player
Mitsubishi ck3526r
I feel your frustration! Most all tv's share similar features,but
access varies with mfr & age.Some sets have an individual channel add and erase system as well as an auto-program
method.Others offer only one way to memorize.In your case,
analyze how to erase channels and thus learn to memorize!
If you need more help,please let me know in exact detail the steps you are taking......T.
Oct 25, 2007 | Zenith SY2751Y TV
Televison & Video Logo
Top Zenith Televison & Video Experts
Demonic-2011
Demonic-2011
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
