Home Logo
Question about Home
I am trying to configure dibal scales series but i have 1 problem which is i need to remove the comma from the price i.e on the scale it showing like this 21.36 but it must be 2136 how can i solve it?
Posted by fadi on
Bashar Telesi (TerraceDS)
    Novelist:
  • 200 Answers
To remove the comma from the price, you can use a string manipulation function such as replace(). Here's an example of how you can use it in Python:
Copy code
price = "21.36" price = price.replace(",", "") print(price) # Output: "2136" This will replace all occurrences of the comma character with an empty string, effectively removing the commas from the price.
You can also use this function to remove the decimal point, if desired. For example:
Copy code
price = price.replace(".", "") print(price) # Output: "2136"
Posted on Jan 06, 2023
5 Related Answers
Anonymous
SOURCE: Scales show weight in kg. How to get them to show lbs.
Body Fat Monitor/Scales: TBF-611, TBF-612, TBF-621, TBF-622, BF-541, TBF-560, TBF-572. UltimateScales: 2000, 2001, 2001T. BF-662, BF-555, BF-556, BF-558, BF-559, BF-625, BF-626.
Press the Set and Up Arrow buttons at the same time. Release the buttons, the display will flash. Press the Arrow button to cycle through each weight mode until just the mode that you require is displayed. Then press Set. The display screen will flash to confirm your selection and store in memory.
Note: If weight mode is set to pounds or stone-pounds, the height programming mode will be automatically set to feet and inches. Similarly, if kilograms is selected, height will be automatically set to centimeters.
Posted on Mar 14, 2009
Anonymous
  • 59 Answers
SOURCE: instruction manual soehnle scale
I have looked and maybe you have the model number wrong the scale you are talking about 63700 Calando Quattrotronic scale is a simple digital scale and does not provide bmi, and hydration.
here is a link to the manual, http://www.leifheitusa.com/manual/63700.pdfit is in several languages including english as the company is european and sells to many countries. If you look english is there it is a very simple manual as the scale is only desinged to weight in either lbs or kgs nothing more. Sorry. If you would like a bmi chart you can get that here http://www.healthdiscovery.net/links/calculators/body_massindex_chart.htm and figure out your bmi based on height and weight in the chart.
Posted on Apr 24, 2009
Anonymous
SOURCE: Err 1 message on Taylor Lithium Elec Scale model 7346
This is a reply I received from Taylor customer support. I have followed this procedure enough times to wear out the original battery and still get the Err 1 message. You may have better luck.
Thank you for your e-mail. The reboot below may clear the error from
your scale. You may need to do this several times to completely reboot
the system. Please let us know if you have any questions or continue to
display the Error.
1. Remove the battery from the scale
2. Set the scale on the floor without the battery in place.
3. Stand on the scale for 10 seconds (still without the battery)
4. Carefully replace the battery without turning the scale on.
5. Using only one foot, tap the scale or apply just enough pressure to
turn on the display. (It should show dashes or zero's) IMMEDIATELY
REMOVE YOUR FOOT.
6. Let the scale turn off
7. Step on the scale for a weight reading
Regards,
Linda DLT
Consumer Relations
Taylor Precision Products
& Salter Housewares
2220 Entrada del Sol, Suite A
Las Cruces, NM 88001
Toll free - 800-289-0944
866-843-3905
Direct - 575-526-0944 ext 3172
Posted on Jun 24, 2009
Anonymous
SOURCE: HealthSmart bathroom scale displays "Err"
Put scale in round file can. Buy another cheap scale.
Posted on Oct 05, 2009
Testimonial: "The new scale works great and was on sale at Wal-mart for only $29."
Anonymous
  • 3 Answers
SOURCE: How do I remove old batteries from Escali BFBW200 scales. The batteries are hard to remove.
Use a pen to push the batteries down towards the flexible metal contact tabs and continue to push the pen underneath the batteries. The batteries should pop out.
Any further questions call us at 1-800-467-6408.
-Noah Harber, Escali Scales
Posted on Oct 09, 2012
My digital kitchen scales have started showing 12.00 on the screen. I've tried removing the battery for r10 mins and replacing but problem is not solved. Help!
Remove all batteries from the back of your scale.
Leave the scale without its batteries for at least 10 minutes.
Reinsert the batteries. Check that the batteries have the correct polarity and are firmly in place.
Place your scale on a flat, even surface without carpet.
Press the center of the scale with one hand to wake it up. The scale will calibrate and display a series of dashes.
"0.0" will appear on the screen. Press on the center of the scale.
I need to reset my whole producx bath scale I lost the directions
I could not find that scale itself, maybe a typo or no model #. Here basic scale reset info: Follow these instructions to reset your scale.
  1. Remove all batteries from the back of your scale.
  2. Leave the scale without its batteries for at least 10 minutes.
  3. Reinsert the batteries. Check that the batteries are firmly in place.
  4. Place your scale on a flat, even surface without carpet.
  5. Press the center of the scale with one foot to wake it up. The scale will calibrate and display a series of dashes.
  6. "0.0" will appear on the screen. Step on the center of the scale.
  7. Remain on the scale until your weight appears. You will hear a short beep when your weight registers.
  8. Step off the scale. A series of dashes will move across the display.
~Heather
How do I reset my Taylor 5576 body fat analyzer scale?
Buy valif Oral Jelly 20 Online is used to treat erectile dysfunction (impotence) in men. valif oral jelly is manufactured by Ajanta Pharma. Its Generic of Vardenafil Oral Jelly. avail best price in USA. by your doorsteps . Free shipping on order above $249. Order Now!
2answers
What does 500 mean
Main Motor error(stuck). Replace Photo Conductor Unit.
2answers
My Dibal scale stop printing
problem. I have no digital display on my bathroom scales.Do you think I should purchase another set from HoMedics. Jeffrey Olsen
How much does it cost
Bachmann parts catalog shows the 44871 Graduated Pier Set as a track accessory for HO track. the catalog price is $23.00But...Internet Hobbies
http://www.internethobbies.com/bachmann-n-scale-accessories.html
Shows 44871 as an N Scale 16 piece E-Z track pier set.
Their retail price is $22.00
sale price is $14.99
Follow the link to their web site & call them to check on current price and availability.
18helpful
4answers
display the Error.
REMOVE YOUR FOOT.
Regards,
Linda DLT
Consumer Relations
& Salter Housewares
866-843-3905
Open Questions:
Top Home Experts
Tom Chichester
ADMIN Andrew
ADMIN Andrew
Are you a Home Expert? Answer questions, earn points and help others
