Epson Color Stylus 880 not printing, blank pages only
I tried cleaning heads, no better. New ink cartridges, it printed one page with every third line almost white then nothing. It looks and sounds like it is printing but nothing!
Re: Epson Color Stylus 880 not printing, blank pages only
With some printers they need to be the recommended brand of ink cartridge. Are you using Epson's own cartridges? If not might be worth changing to them. It sounds as though the issue is with the cartidges and not the printer itself. Hope this helps.
Try going into the menu and cleaning your print heads. If that doesn't work, take out the cartridge and using a cotton swab and alcohol, clean the print heads.
Hi Good day!! try the Head cleaning.. to do that follow this method: 1. Click Start 2. Click Settings 3. Click Printer and Faxes now you should view your installed printer. 4. right click your printer and then properties. 5. click "Printing Preferences" and the Printer preferences box there are 5 tabs Choose the "Maintenance" 6. Click "Head Cleaning" to start the cleaning. and then try to print again see if your printing was fine.. if not you should start the head cleaning again..
I located a page on fixyourownprinter.com’s forum, which had plenty of details about similar issues. I hope this helps you. If you find this helpful, pls rate me.
Please follow the procedure your printer has which forces it printer to clean the print heads.
I have experience of other epson stylus models. I have previously spoken to epson about this exact problem. Repeating the head cleaning process a minimum 5 times cleared the problem.
Running head clean multiple times in succession builds up pressure in the print heads - causing (usually new) cartridges to work correctly.
kind regards
