Cars & Trucks Logo
R
Rose li Posted on Oct 27, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can AC and DC Power Modules Be Used in the Same Switch?
Switch
Monica
Level 2:
Habit-Forming:
Scholar:
  • Expert 57 Answers
  • Posted on Oct 27, 2016
Monica
Expert
Level 2:
Habit-Forming:
Scholar:
Answers
57
Questions
56
Helped
10789
Points
242
Fixed Switches Product Series Model AC and DC Power Module Mixing S3700/S5700/S6700 S3700-26C-HI Supported S5710-28C-EI Supported S5710-52C-EI Supported S5700-28C-HI Supported S5700-28C-HI-24S Supported S5700-EI (non-PoE) Supported in V200R005 S5700-SI (non-PoE) Supported in V200R005 S6700 Supported in V200R005 S5710-HI AC and DC power modules cannot be used together, but 350 W and 1150 W AC power modules can be used in one switch. S5720-HI Supported Modular Switches · When a switch does not use a PoE power module:
AC and DC power modules cannot be used together in the same type of power slots. Power modules with different power values cannot be used together either.
· When a switch uses a PoE power module:
Version PoE Power Module System Power Module V200R005C00 and earlier versions AC AC DC power module not supported - V200R006C00 and later versions AC AC DC DC AC DC ·
AC and DC power modules cannot be installed in the slots of the same type (system or PoE) in the same switch, and the power modules of different power values cannot be used in the same switch.
S5720 Switch Thunder link com
I have a 1998 cadillac saville none of the windows will roll down checked all fuses under the back seat and under the hood all fine.
The power windows on your vehicle are controlled by a electronic module .
Each power window is connected to a permanent magnet motor. The motor raises or lowers the glass when the door module applies voltage to the motor. The direction the motor turns depends on the polarity of the supply voltage provided by the associated door module. All four doors have their own separate modules.
A serial digital communications link, called the simple bus interface, is used for communications between door modules and the driver's door power window switches. The use of serial digital communications allows the use of a single wire to convey switching information between the LH front power window switch and the driver's door module. The serial communication is also used to transmit switching information from the driver's door module to the other three door modules.
The door modules apply battery voltage of the correct polarity to the respective window motor when any local, or power door lock switch, UP switch is operated, driving the window up. Battery voltage is applied to the respective window motor in the opposite polarity when any local, or power window switch, DOWN switch is operated, driving the window down.
The first place to start when diagnosing a problem like ths would be to hook up a factory scan tool , checking DTC'S - diagnostic trouble codes. Without a factory scan tool ,forget it , you have no chance of fixing this . Take it to a cadillac dealer . Could have problem with the
Simple Bus Interface (SBI) Serial Data Link
The simple bus interface is a serial data link. This serial data link replaces vehicle cables between various door modules with a single wire. The same amount of information is sent by multiplexing (time-sharing) data to and from each device over that wire. The serial data signals are referenced to ground. If the simple bus interface is lost, the RFDM, LRDM, and RRDM will enter the sleep mode. With the door modules in sleep mode, no power window operations are possible.
002 Introduction to Communications
1helpful
2000 cadilac seville occasionally doesnt respond when ignition key is inserted, no memory position adjustments, no starter when key turned. is it key or ignition switch. everything usually works fine
Is the security light lit on the instrument when it doesn't start ? The ignition switch on your vehicle doesn't work like you would probably think it does . The ignition switch is input signal to the body control system .
Body Control System Description
The body control system consists of three modules and their associated electrical controls. These modules are as follows:
• The dash integration module (DIM), located on the right hand side of the instrument panel, near the blower motor.
• The instrument panel integration module (IPM), located in the center of the instrument panel, above the radio.
• The rear integration module (RIM), located on the right hand rear of the passenger compartment, behind the rear seat.
Each module integrates input and output controls for two or more functional areas. The inputs and outputs are wired to the closest module to minimize the lenth and amount of the wiring used. All three modules communicate on the Class 2 serial data line, allowing data to be shared among them, as well as with other Class 2 modules on the vehicle as needed.
Each of the three body control modules integrate a number of functional systems under the control of a single module. Each of the modules are connected to the Class 2 serial data line.
Dash Integration Module (DIM)
The dash intergration module (DIM) functions include the following:
• Power moding control (ignition switch states) over Class 2 serial data line
• Control of exterior lamps
• Interior lamps and incandescent dimming
• Steering wheel controls
• Horn relay control for theft activation
• Low side temperature for HVAC compressor
• Hood ajar switch input (export)
• Storage of the clock settings and, sending a message on the class 2 serial data line in response to requests from other modules.
Instrument Panel Integration Module (IPM)
The instrument panel integration module (IPM) functions include the following:
• Front HVAC air delivery and temperature controls
• Ambient light sensor input and twilight delay input for headlights control
• Foglight switch inputs
• I/P dimmer switch input
• Traction control switch input
• Interior lamps switch input
• Key in ignition switch input from the ignition switch
• Fuel door and rear compartment lid release switch input
• Ignition switch headlight control
Rear Integration Module (RIM)
The rear integration module (RIM) functions include the following:
• Fuel level sensor input
• Heated seat controls
• HVAC blower control
• Rear defogger control
• Park brake relay controls
• Various controls for the interior lamps
• Reverse control for the backup lamps and automatic day/night mirror
• Rear foglights control
• Fuel door and rear compartment lid release controls
• Retained accessory power (RAP) control for the sunroof control module
• Ajar switch and tamper switch inputs from the rear compartment lid
• Content theft alarm
At the dealer we would hook up a scan tool and look at the ignition switch inputs to the DIM to see if has correct inputs . Also we would check DTC'S diagnostic trouble codes .
DTC B1805 Ignition Switch Problem
Normal vehicle Class 2 communication does not begin until the system power mode has been identified. The dash integration module (DIM) monitors four discrete wires from the ignition switch contacts in order to determine the present power mode (ignition switch position). The DIM communicates the system power mode to all Class 2 modules on the Class 2 serial data line.
http://www.public.asu.edu/~pheanis/documents/VBI_CLASS2.pd
Dc voltge use
Dc stands for Direct current its a constant non varying current
the only disadvantage is it will now able to travel over a long distance
http://www.instructables.com/answers/Why-DC-current-is-not-used-in-Homes What Are the Uses of Direct Current eHow Why do we use Alternating Current AC instead of Direct Current DC in power...
Jawa 90 roadster motorcycle charging panel with battery fitted
diodes do not regulate charge
simply put diodes are one way valves for electricity and are used to rectify alternating current (AC) to direct current(DC)
you use a voltage regulator after a rectifier pack to control the voltage from an alternator of maintain a max voltage of 14.5 volts dc
take it to an accredited bike electrician
1helpful
Can i fix or replace my pcm power diode
Power diode is crystalline semi conductor device that is mainly used for converting AC or Alternate Current to DC or Direct Current. This process is called rectification. http://www.whatisall.com/technology/what-is-a-power-diode.html
Hi i need a power supply ac adapter veco21 for power on board 400 amp instant starting power
Hi Khosravifar,I believe you may be asking about an inverter. Its a piece of equipment used to convert DC electrical supply to AC applications. They should be available at any store supplying good electronic parts and equipment regards John
1helpful
How to install 12 volt led light bulbs in the 220v Power Supply
Buy a lamp holder and 220V AC to 12V DC power supply, power supply should exactly be connected with the positive and negative holder, plug in the power, 12 volt led light bulbs can be used.
2answers
The driver seat heater just quit. all fuses are good. how do you tell if the relay is good?
Swap it with a relay you know to be good and see if it works again,pick a relay that is not important to the function of your car.
Top AC Experts
old marine
old marine
vince
Are you an AC Expert? Answer questions, earn points and help others
