Question about X-Micro Technology (XWL11GRIX) Router
Won't connect online
I recently changed my phone over to comcast and they put a new modem in. My main computer goes online but I can no longer get on with my laptop. Help!
Posted by kattman on
  • kattman Nov 19, 2007
    The laptop I am using is an old Sony VIAO with Windows ME
    i am connected with a wireless router. They didn't remove the router just a new modem. I have not been able to turn off the modem yet as it is the only way I have phone service. I did try the router and that did not work.
Anonymous
    Novelist:
  • 201 Answers
This just happened to my siste and a frind of mine recently. It can be a few things.
Are you connecting via wire from your laptop or wireless? I'm hoping they did not remove a wireless router and not explain this to you.
With a new modem your main IP address would change. First I would try turning off everything, unplug the modem and any connected switches or routers. Wait at least 10 minutes, better yet, unplug them and go to work, go shopping etc.. Then plug the modem back in, wait 2-5 minutes, plug in any routers and switches, wait 1 minute then turn the laptop back on. See if that solves the problem.
Posted on Nov 19, 2007
  • Anonymous Nov 19, 2007
    Try shutting off the modem when you get a chance and for at least 10 minutes. I didn't believe 30 seconds was not long enough until I had seen similar problems not solved by a 1-2 minute shut down but they were resolved with a 10-15 minute shutdown. (more than once) It has something to do with the cable internet service resetting some settings after seeing an extended period of no response from the modem.
I have a Netgear WNR2000 that I want to connect to a comcast modem. My pc picks up an ip from the router but the router does not get an ip from comcast. I have tried a manual setup using the settings...
Make sure that your computer is able to go online through the modem.
If your computer is not able to go online through the modem then you will need to call ISP first.
If your computer is able to go online through the modem
then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Jul 28, 2010 | Computers & Internet
I HAVE A NEW HP DESKTOP AND AN OLD LINKSSY WIRELESS G
Hi Vivian,
Chweck you cables and where they are conencted.
You will need to make sure that the Comcast modem is providing internet, you can do this by connecting your laptop to it using ethernet directly if it connects to the internet, that will be a good thing.
From your comcast Modem, the ethernet Cable should go to the linksys where it says "WAN". this should give you an internet connection and make your comcast modem communicate with your linksys Router.
Jul 22, 2010 | Linksys Wireless-G Broadband Router
Comcast unhooked it and i dont know how to hook it back up
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
Click Here for more information about the routers and network
May 10, 2010 | Belkin (F5D7230-4) Router (587009)
I have a Zonet Router that I am hooking up to Comcast DSL internet. i show that i am connected but i can not get online. i duplicated the MAC address i just dont know what else can be wrong. is there a...
The first thing is that Comcast is Not a DSL connection it is Cable connection. Now first make sure that your computer will be able to go on line when connected directly to the modem. Connect your main computer directly to the comcast modem and check if that goes on line. If not then you will need to contact Comcast and get main computer on line. If it is online then reset your router for 30 seconds. release the reset and wait for 1 minute. Now connect the main computer to the router and comcast modem to the router. open the set up page and Clone the MAC address of the " Main " computer.
power cycle the modem and the router. See if it works.
Click here for more information about router and networking
Apr 19, 2010 | Zonet ZSR1104WE Wireless Router
I have recently moved from Pittsburgh, PA to Charleston, SC. My linksys Wireless G 2.4 gHz router worked great with the ISP in Pittsburg (Comcast). Now, with Time Warner's Road Runner, I get an error and I...
Connect your main cmoputer directly to the time warner modem. make sure that your computer will be able to go on line when connected directly to the modem. If not then call Time warner.
If your computer is able to go on line when connected to the modem then your modem is working properly. You will need to change the settings of the router.
First reset the router for 30 seconds. On the router you will find a small reset button. Hold it down for 30 seconds. release it. wait for 1 minute. now unplug the power to the router and plug it back in. wait for 30 seconds till the power light on the router will be solid.
Now connect the modem and the computer to the router.
Now you will need to clone the MAC address of your main computer to the router. you will neeed to open the set up page of the router.
once your main computer is online , you can change the wireless settings of the router and connect to the wireless network on the laptop.
Click here for step by step solution
Apr 10, 2010 | Linksys Wireless-G Broadband Router
D-link has stopped working with comcast internet.
Are you trying to install the router.You can do it manually
without the CD.
MAke sure that your computer is able to go
through the modem
Then you need to connect the computer to the
router ad the modem to the router.
ISP.
Jan 16, 2010 | D-Link AirPlus Xtreme G DI-624 Wireless...
Re-Connectivity to Comcast Modem
All you need to do is "MAC ADDRESS CLONING". Access the router's setup page and look for MAC Clone settings. Enable that and clone the mac address of your main PC. After that, perform a power cycle. Turn off the router then the modem. Wait for 30 seconds then power on the modem first, wait for all the lights to go solid then power on the router. That should do it.
Apr 15, 2009 | NetGear RangeMax WPN824 Router
New desktop pavilion model a6600f will not connect to my internet server (comcast). I can't get your phone support to answer. Waited on hold several times for as much as an hour. After talking with other...
i also have comcast and go threw the same thing .and if i go some wear els the pc works fine it is some thing with comcast un plug every thing then try again
Dec 09, 2008 | Computers & Internet
Arimex comcast router won't talk to belkin wireless g plus mimo router
Comcast has a little known "trick" that they use when setting up users. Here's how it works:
When Comcast first comes to setup your new cable modem service, they insist on connecting it to your computer and "testing" it. Most people think nothing of it, and that it's good customer service ...truth be told, what they are doing is attaching your computer's MAC address to that cable modem, so that you cannot create a wireless network. This is because they want you to pay them $150 to do this for you.
In this situation, since the modem is a modem/wireless router in one, my guess is that the MAC address on your machine now does not match the MAC address on the new router, which is what Comcast has stored in their database(s).
Try this: on your computer (while connected to the modem), perform a release on your IP address (start, run, cmd, then type "ipconfig /release"). Disconnect the ethernet cable from the computer. Turn computer off completely. Hold down the reset button on the cable modem until it performs a reset. Once it's back up and running, boot up your computer with the cable back in the ethernet port.
The cable modem should assign a new address to your computer. However, that may or may not work ...this is an easy workaround with a Linksys router, but not necessarily with the all-in-one devices.
Worst case scenario: contact Comcast and notify them that the new modem is not recognizing your computer's MAC address and that it needs to be updated in their system. They will scan your computer (through the telnet interface on your modem) and get your computer's MAC address, then (hopefully) make the necessary changes on their end.
After that, everything should work flawlessly. If not, insist on a Comcast tech to "fix" the service that you are paying for.
Good luck - hope this helps :)
Sep 29, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Can't connect to the Internet via router
Well, this is a very generalized problem that others have, so i'll give you some starting tips. If you can connect when you plug your computer directly into the modem, then it sounds like your modem is bonding to your computer. There are a couple ways to fix this. The easiest is to ask your router to clone your MAC addess (not to be confused with a mac computer, a MAC address is a 10 digit code that uniquely identifies your computer on a network). See the attached image to find where it should be. c26d492.jpg
Once you set it to clone your machines mac address, unplug the computer from the modem, and plug in the router. If this doesn't fix it, please comment back and we'll try some other things. If it does, then give a good rating :-)
Steven
Aug 10, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
X-Micro Technology (XWL11GRIX) Router Logo
70 people viewed this question
Top X-Micro Technology Computers & Internet Experts
Ekse
Marvin
Marvin
Are you a X-Micro Technology Computer and Internet Expert? Answer questions, earn points and help others
